Lutris and Vulkan prefixes?
Good morning,
Since the last big update I can no longer select the desired Vulkan prefixes.
Some games only work with one driver (rdr2, amdgpu) which I cannot select.
It seems to me that there is a current problem with AMDVLK but I can no longer find the source.
Do you have any information on this problem?
Thanks. :wink:
inxi -Gxxx :
  Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
    vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2 pcie: speed: 16 GT/s
    lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3,Writeback-1
    bus-ID: 09:00.0 chip-ID: 1002:73df class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
    display-ID: 0
  Monitor-1: DP-2 pos: right res: 1920x1080 size: N/A modes: N/A
  Monitor-2: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
    device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
    drv: radeonsi inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi
    navi22 LLVM 17.0.6 DRM 3.57 6.9.0-1-MANJARO) device-ID: 1002:73df
    display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 11 surfaces: xcb,xlib,wayland device: 0
    type: discrete-gpu driver: amd device-ID: 1002:73df
Thank you Stephane :wink:
Helllo @Skwal :wink:
Probably this:
# AMDVLK
VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/amd_icd32.json:/usr/share/vulkan/icd.d/amd_icd64.json
# Mesa RADV
VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/radeon_icd.i686.json:/usr/share/vulkan/icd.d/radeon_icd.x86_64.json
https://www.reddit.com/r/linux_gaming/comments/h8b7zv/amd_gpu_vulkan_driver_how_to_easily_switch/
