I tried to look at the lutris forums about my problem and looking on the internet for my problem, but their doesn’t seem to be an answer.
My problem is this when I choose a data center from the start screen it acts like its going to the character screen but doesn’t. Instead it just shows a black screen with the loading icon on the bottom right of the screen and stays there. I am not sure what I could do to get the game past the loading screen if anything at all.
if by any chance you have the game installed in windows and running all you need to so is locate the files in Documents/My Games/FINAL FANTASY XIV - A Realm Reborn/ copy those files and paste it in lutris(wine) equivalent directory and it should be good to go. At least it worked for me.
i am unable to try this myself now but check the FFXIV.cfg file and it might look like this
CutsceneMovieOpening 0
try to change the 0 for a 1. the problem is that the game after you hit start is trying to load the opening cutscene and it gets stuck at that point. Again I am unable to try it at the moment to confirm if this works.
I didn’t have a FFXIV.cfg file and had to make a new one besides CutscenMovieOpening and using the CutsceneMovieVoice and CutsceneMovieCaption. Is their suppose to be anything else in the file besides those three?
The game is still in stuck infinite loading after choosing data center
this is the full cfg file you need to add the > symbol at the beginning of each column that that has the < symbol in it. also my graphics setting might be different to yours you might need to edit that.
Thank you I added those to the cfg. You said to try to move the game files of the game from my games in documents in windows to wine right? I used rclone to connect to my onedrive and did that, but the game is still stuck trying to load into a data center.
I transferred those files into my installation folder in wine and overwritten when asked. The game still is stuck at the loading screen to enter a data center.
