I am unable ot get SABNZBD working. Last time I succeeded in doing so, there were too many errors. Can´t remember what I exactly did , buy after re-installing the program, it doesn´t show up. Download-folders are stuck in VAR, errors about not found API etc.
Is there a solution for this? My Python has version 3.9 I followed instructions on SABNZBD website, an googled around, but nothing works. My last hope was to install it from pamac again, but it doesn´t show up in my browser.
Thnx in Advance
I know this does not answer your query, but it may be of some help.
Pan is a very good standalone newsreader that can handle .nzb and is SSL capable, . It is available in the repositories. It is similar to the old Windows software Microplanet Gravity (SuperGravity) and Forte Agent.
I strongly encourage to use docker for this purpose.
docker run \
--name=sabnzbd \
-e PUID="$(id -u)" \
-e PGID="$(id -g)" \
-p 127.0.0.1:8080:8080 \
-p 127.0.0.1:9090:9090 \
-v "$HOME/.config/sabnzbd:/config" \
-v "$HOME/Downloads:/downloads" \
ghcr.io/linuxserver/sabnzbd
Afterwards, you have it running on localhost:8080.
