After fresh install, time was correct but after editing i3status.conf, I noticed the time has changed to UTC, rather than local time. Read up on how on archwiki to setup the sync but got totally confused. I manually setup time using timedatectl set-time but would like to setup automatic sync…
not sure i understand, what exactly did you do, the commands you ran.
maybe post the section you edited in i3status.conf.
if all else fails you can copy the conf & start again.
i did a minimal+sway & it’s all just winging it.
The recommended method on Manjaro is as follows
- Ensure your symlink
/etc/localtime
link to the correct timezone. - Instruct the system to sync the hardware clock in UTC.
- Then enable and start the
systemd-timesyncd
service.
thanks, systemd-timesyncd was not enabled…, now seem to be running
