Hello, everyone!
At some point in the last weeks, I am experiencing a bad performance on my PC. When gaming (Euro Truck 2, CS2, Cities Skyline), my GPU usage is getting low. The value depends on the game, but never above 80% usage, even with gamemode on.
The crazy thing is that on the menus it gets 100%.
When the Wayland update came to NVIDIA, everything went good, it starts after the lastest stable updates (2025-05-14 and 2025-05-19).
Hope someone can give a direction here to fix that.
Info about the system:
inxi --admin --verbosity=6 --filter --width --raid --bluetooth --logical --extra 3 --flags --filter-label
Kernel: 6.6.90-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=d6ecda09-ff35-416a-9f44-94f281802154 rw nvidia_drm.modeset=1
quiet udev.log_priority=3
Desktop: GNOME v: 48.1 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 48.0 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
UEFI-[Legacy]: American Megatrends v: 2202 date: 07/14/2020
System RAM: total: 16 GiB available: 15.55 GiB used: 5.07 GiB (32.6%)
Device-1: DIMM_A1 type: no module installed
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KHX2666C16/8G serial: <filter>
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen+ gen: 1+
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1547 min/max: 1550/3200 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1547 2: 1547 3: 1547
4: 1547 5: 1547 6: 1547 7: 1547 8: 1547 9: 1547 10: 1547 11: 1547 12: 1547
bogomips: 76674
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm lbrv
lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean
vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia
v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current
(as of 2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 08:00.0 chip-ID: 10de:1c82
class-ID: 0300
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: 0
Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAWIDE serial: <filter>
built: 2016 res: 2560x1080 dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15")
diag: 869mm (34.2") modes: max: 2560x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
memory: 3.91 GiB display-ID: :0.0
API: Vulkan v: 1.4.313 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti driver: nvidia v: 570.144 device-ID: 10de:1c82
surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: kscreen-doctor
gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
bus-ID: 08:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK
bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Generalplus Usb Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-4:4 chip-ID: 1b3f:2008 class-ID: 0300
serial: <filter>
API: ALSA v: k6.6.90-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.58 TiB used: 899.26 GiB (55.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A02 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: WDC WDS240G2G0B-00EPW0
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0400 scheme: GPT
ID-1: / raw-size: 456.96 GiB size: 448.72 GiB (98.20%)
used: 222.11 GiB (49.5%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: d6ecda09-ff35-416a-9f44-94f281802154
ID-2: /mnt/0730390f-64f7-4722-8644-0b147af0a682 raw-size: 931.51 GiB
size: 915.82 GiB (98.31%) used: 675.69 GiB (73.8%) fs: ext4 dev: /dev/sda1
maj-min: 8:1 label: <filter> uuid: 0730390f-64f7-4722-8644-0b147af0a682
ID-1: swap-1 type: partition size: 8.8 GiB used: 1.46 GiB (16.5%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18 label: <filter>
uuid: b1b7c693-1d50-44de-b647-e3f032335bfa
ID-1: /dev/sdc1 maj-min: 8:33 size: 223.57 GiB fs: ext4 label: <filter>
uuid: 0a8dbb6f-1615-4fe7-869d-f847134b304d
Device-1: 3-1:2 info: Logitech G213 Prodigy Gaming Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c336 class-ID: 0300 serial: <filter>
Device-2: 3-2:3 info: Holtek Gaming Mouse [Redragon M711]
type: mouse,keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 04d9:fc30 class-ID: 0300
Device-3: 3-4:4 info: Generalplus Usb Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
chip-ID: 1b3f:2008 class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 44.2 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 405 Power: uptime: 3h 24m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: gsd-power,
tool: systemctl
Packages: 2161 pm: dpkg pkgs: 0 pm: pacman pkgs: 2104 libs: 568
tools: gnome-software,pamac,yay pm: flatpak pkgs: 51 pm: snap pkgs: 6
Compilers: clang: 19.1.7 gcc: 15.1.1 alt: 13/14 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.38
Thanks!
