Low brightness issues
Hi,
I have been using Manjaro for 1 month without any problem but suddenly, after a reboot, brightness went at its minimum level. I’ve tried to edit /etc/default/grub adding i915.enable_dpcd_backlight=0 but nothing has changed. I’ve tried to install xbacklight too but it doesn’t work. Any advice?
Thank you in advance.
  Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 wm: xfwm4 dm: LightDM
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X571GT_X571GT
  v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: X571GT v: 1.0 serial: <filter>
  UEFI: American Megatrends v: X571GT.308 date: 12/17/2020
  ID-1: BAT1 charge: 5.9 Wh (98.3%) condition: 6.0/42.3 Wh (14.1%)
  volts: 12.5 min: 11.6 model: ASUS A32-K55 serial: N/A status: Charging
  Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
  arch: Kaby Lake note: check rev: A cache: L2: 12 MiB
  bogomips: 62399
  Speed: 900 MHz max: 800 MHz Core speeds (MHz): 1: 900 2: 900 3: 898 4: 849
  5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 849
  Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:3e9b
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
  driver: N/A bus-ID: 01:00.0 chip-ID: 10de:1f91
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus-ID: 1-7:4 chip-ID: 13d3:56a8
  Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting
  resolution: 1920x1080~60Hz s-dpi: 96
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.3
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a348
  Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: no
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
  v: kernel port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370
  vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
  chip-ID: 10ec:8168
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 bus-ID: 00:17.0 chip-ID: 8086.282a
  Local Storage: total: 1.38 TiB used: 57.79 GiB (4.1%)
  ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
  speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 29.9 C
  ID-2: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
  speed: 6.0 Gb/s serial: <filter>
  ID-1: / size: 228.77 GiB used: 57.75 GiB (25.2%) fs: ext4
  dev: /dev/nvme0n1p5
  ID-2: /boot/efi size: 96 MiB used: 36.9 MiB (38.4%) fs: vfat
  dev: /dev/nvme0n1p2
  System Temperatures: cpu: 44.0 C mobo: 27.8 C
  Fan Speeds (RPM): cpu: 0
  Processes: 280 Uptime: 27m Memory: 15.49 GiB used: 1.67 GiB (10.7%)
  Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1118 pacman: 1112
  snap: 6 Shell: Bash v: 5.1.4 running-in: xfce4-terminal inxi: 3.3.04
P.S. when I do “sudo powertop --calibrate” brightness is ok, but after calibration returns low.
