Hi,
I have just plugged a Creative Sound Blaster Recon3D into my system and… it doesn’t work. I have no sound output, nor microphone input.
Here goes system info, just in case it helps.
inxi --full --system --verbosity=7 --filter --no-host --admin
System: Kernel: 5.9.3-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=2867bf66-978f-467b-9da8-0b0c09e48967 rw apparmor=1
Desktop: Cinnamon 4.6.7 tk: GTK 3.24.23 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Micro-Star model: B450M MORTAR TITANIUM (MS-7B89) v: 2.0 serial: <filter>
UEFI: American Megatrends v: A.D0 date: 06/12/2020
Memory: RAM: total: 31.37 GiB used: 2.44 GiB (7.8%)
CPU: Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 family: 17 (23) model-id: 71 (113)
stepping: N/A microcode: 8701021 L2 cache: 3072 KiB bogomips: 86425
Speed: 3600 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3600 2: 2054 3: 2053 4: 2047 5: 2057
6: 3249 7: 2048 8: 2049 9: 3600 10: 2054 11: 2050 12: 3587
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht
hw_pstate ibpb ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GM107GL [Quadro K2200] driver: nvidia v: 455.38 alternate: nouveau,nvidia_drm bus ID: 26:00.0
chip ID: 10de:13ba
Display: x11 server: X.Org 1.20.9 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3") s-diag: 583mm (23")
Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3") diag: 584mm (23")
OpenGL: renderer: Quadro K2200/PCIe/SSE2 v: 4.6.0 NVIDIA 455.38 direct render: Yes
Audio: Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series] driver: snd_hda_intel v: kernel
bus ID: 25:00.0 chip ID: 1102:0012
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] driver: snd_hda_intel v: kernel bus ID: 26:00.1
chip ID: 10de:0fbc
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 28:00.4 chip ID: 1022:1487
Device-4: Trust Widescreen 3MP Webcam type: USB driver: snd-usb-audio,uvcvideo bus ID: 3-3:2 chip ID: 145f:0167
Sound Server: ALSA v: k5.9.3-1-MANJARO
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 21:00.0 chip ID: 8086:2723
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: f000 bus ID: 22:00.0 chip ID: 10ec:8168
IF: enp34s0 state: down mac: <filter>
Drives: Local Storage: total: 698.65 GiB used: 623.34 GiB (89.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 250GB size: 232.89 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXM7 scheme: GPT
ID-2: /dev/sda vendor: Hitachi model: HDP725050GLA360 size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A5CA scheme: MBR
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 232.59 GiB size: 227.94 GiB (98.00%) used: 187.13 GiB (82.1%) fs: ext4 block size: 4096 B
dev: /dev/nvme0n1p2 label: N/A uuid: 2867bf66-978f-467b-9da8-0b0c09e48967
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 280 KiB (0.1%) fs: vfat block size: 512 B
dev: /dev/nvme0n1p1 label: N/A uuid: 608D-4D6A
ID-3: /mnt/C0D0CC01D0CBFFA0 raw size: 465.76 GiB size: 465.76 GiB (100.00%) used: 436.21 GiB (93.7%) fs: ntfs
block size: 4096 B dev: /dev/sda1 label: Datos uuid: C0D0CC01D0CBFFA0
Swap: Alert: No Swap data was found.
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-5:2 info: Wacom ACK-40401 [Wireless Accessory Kit] type: HID driver: usbhid,wacom interfaces: 3
rev: 2.0 speed: 12 Mb/s chip ID: 056a:0084
Device-2: 1-6:3 info: Realtek Mass Storage Device type: Smart Card,Mass Storage driver: usb-storage interfaces: 2
rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0161 serial: <filter>
Device-3: 1-7:4 info: HP HP USB Smartcard CCID Keyboard type: Keyboard,Smart Card,HID driver: hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 03f0:104a serial: <filter>
Device-4: 1-8:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 8087:0029
Device-5: 1-10:6 info: Avago Pte. ADNS-5700 Optical Mouse Controller (3-button) type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s chip ID: 192f:0416
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 3-3:2 info: Trust Widescreen 3MP Webcam type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4
rev: 2.0 speed: 480 Mb/s chip ID: 145f:0167
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 38.1 C mobo: 37.0 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): fan-1: 0 fan-2: 937 fan-3: 0 fan-4: 0 fan-5: 0 gpu: nvidia fan: 43%
Info: Processes: 338 Uptime: 23m Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 8/9 clang: 10.0.1 Packages: 1660
pacman: 1637 lib: 472 flatpak: 19 snap: 4 Shell: Bash v: 5.0.18 running in: gnome-terminal inxi: 3.1.08
