Hi,
installed plasma via architect on my new laptop but sound is low compare to windows 11 installed on second ssd
Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=b5031071-2e55-4a02-a3df-c8989de8da0e rw ipv6.disable=1
watchdog=0 quiet udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20Y3CTO1WW v: ThinkPad P1 Gen 4i
Mobo: LENOVO model: 20Y3CTO1WW serial: <superuser required> UEFI: LENOVO
v: N40ET34W (1.16 ) date: 04/08/2022
ID-1: BAT0 charge: 93.7 Wh (100.0%) condition: 93.7/90.1 Wh (104.0%)
volts: 17.7 min: 15.5 model: SMP 5B11B79217 type: Li-poly serial: <filter>
status: full cycles: 13
Info: model: 11th Gen Intel Core i7-11850H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8D (141) stepping: 1 microcode: 0x3E
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1085 high: 1323 min/max: 800/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1237 2: 1204 3: 1306
4: 997 5: 1080 6: 799 7: 1052 8: 1072 9: 995 10: 948 11: 1138 12: 1077
13: 1063 14: 914 15: 1164 16: 1323 bogomips: 79888
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: Luxvisions Innotech Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-8:3 chip-ID: 30c9:0031 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: AU Optronics 0x6a9f built: 2021 res: 2560x1600
hz: 60 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 2560x1600
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.0.4
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: no
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
Device-2: Lenovo USB-C to LAN type: USB driver: r8152 bus-ID: 2-2:2
chip-ID: 17ef:720c class-ID: 0000 serial: <filter>
IF: enp0s13f0u2 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 942.7 GiB used: 79.48 GiB (8.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 960 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 4B6QCXP7 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 426.41 GiB size: 418.64 GiB (98.18%)
used: 79.48 GiB (19.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 428 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 8.01 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 2291
Processes: 298 Uptime: 9m wakeups: 551 Memory: 15.33 GiB
used: 3.2 GiB (20.9%) Init: systemd v: 250 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 841 lib: 189
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.17
