All my desktop icons are gone. Only wallpaper is left. Desktop area is not sensible to mouse actions (left or right clicks do nothing, I can’t select areas either).
The bottom panel is fine and working, but the rest of the desktop is gone, leaving the wallpaper as a shadow of its former glory, lets say.
Rebooting did not help. Restarting cinnamon from the panel did not help.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
