Lost keyboard functionality after "Reset to Defaults"
Hi everyone.
I was messing around with keyboard settings as my new keyboard isn’t linux compatible out of the box.
And just to make it clear, I did not add any application shortcuts my self, so everything was as when I installed manjaro xfce (= as default).
I then pressed “Reset to Defaults” in the keyboard > application shortcuts window thinking the worst thing that could happen would be no change.
Now a lot of the application shortcuts that originally were set are now gone and I’ve lost keyboard functionality, for instance my windows key are dead.
It would be perfect if I could somehow reset the shortcuts to what they were.
Have I misunderstood something regarding the “Reset to Defaults” or is this a bug?
Best regards
See this post for information:
You can run the command mentioned at the end of the post to copy the predefined keyboard shortcuts to your home directory.
I would suggest to make a backup copy of the ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xml file first.
This seems like what I need, too bad I didn’t found that my self. Will try it when I get home.
To understand what the “Reset to Defaults” does, could it be the case that it ignores what DE there is installed and just wipes out almost everything except for some basics? Seems kinda odd if you ask me.
Maybe @bogdancovaciu or someone else from the manjaro team can provide some knowledge regarding this?
Thanks a lot though @bill_t . I’m quite sure this is what solves my problem!
Is resetting to the XFCE defaults. We can’t change that, and XFCE doesn’t follow our /etc/skel files from what i understand …
I’m not sure, but I think that when you press the Reset to Defaults button, the system restores some pre-configured shortcuts from the file /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xml.
This file seems to contain some basic/default Xfce shortcuts.
Really appreciate your help @bill_t and @bogdancovaciu. Thanks.
My problem is almost solved. I’ve got my shortcuts back. But it is being kinda delayed. There’s a ~5 min delay from logging in until the shortcuts start working.
For instance, if I press the Super key a couple of times right after login, nothing happens. After ~5 mins the whisker menu starts opening and closing as the previously Super presses are being registered and shortcuts are now working?
I do not have slow keys turned on.
In order to get my keyboard to work properly I had to follow the instructions under “Function keys do not work” from this link:
https:// wiki.archlinux. org/index.php/Apple_Keyboard#Function_keys_do_not_work
But dunno if that would play any role in the delay.
edit: I tried to reroll what I did regarding the function keys not working, and the problem is still present, so it shouldn’t have anything to do with that.
I’ve also tried with my old keyboard which I know worked perfectly fine before all of this, and the problem is also present with that keyboard.
I’ve logged the output from journalctl -f from after logging in until the shortcuts start working:
Sep 07 16:36:58 chr1s-manjaro dbus-daemon[717]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.11' (uid=0 pid=718 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Sep 07 16:36:58 chr1s-manjaro systemd[1]: Starting Network Manager Script Dispatcher Service...
Sep 07 16:36:58 chr1s-manjaro dbus-daemon[717]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 07 16:36:58 chr1s-manjaro systemd[1]: Started Network Manager Script Dispatcher Service.
Sep 07 16:36:58 chr1s-manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:36:58 chr1s-manjaro kernel: audit: type=1130 audit(1599489418.777:81): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:03 chr1s-manjaro systemd[1]: Stopping User Manager for UID 969...
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopped target Main User Target.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopping Accessibility services bus...
Sep 07 16:37:03 chr1s-manjaro gvfsd[1080]: A connection to the bus can't be made
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopping D-Bus User Message Bus...
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopping Virtual filesystem service...
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: dbus.service: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopped D-Bus User Message Bus.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: at-spi-dbus-bus.service: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopped Accessibility services bus.
Sep 07 16:37:03 chr1s-manjaro systemd[1109]: run-user-969-gvfs.mount: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: run-user-969-gvfs.mount: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1]: run-user-969-gvfs.mount: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: gvfs-daemon.service: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopped Virtual filesystem service.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopped target Basic System.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopped target Paths.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopped target Sockets.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Stopped target Timers.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: dbus.socket: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Closed D-Bus User Message Bus Socket.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: dirmngr.socket: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Closed GnuPG network certificate management daemon.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: gpg-agent-browser.socket: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: gpg-agent-extra.socket: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: gpg-agent-ssh.socket: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: gpg-agent.socket: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Closed GnuPG cryptographic agent and passphrase cache.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: p11-kit-server.socket: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Closed p11-kit server.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: pipewire.socket: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Closed Multimedia System.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: pulseaudio.socket: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Closed Sound System.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Reached target Shutdown.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: systemd-exit.service: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Finished Exit the Session.
Sep 07 16:37:03 chr1s-manjaro systemd[1058]: Reached target Exit the Session.
Sep 07 16:37:03 chr1s-manjaro systemd[1059]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Sep 07 16:37:03 chr1s-manjaro systemd[1]: user@969.service: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1]: Stopped User Manager for UID 969.
Sep 07 16:37:03 chr1s-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:03 chr1s-manjaro systemd[1]: Stopping User Runtime Directory /run/user/969...
Sep 07 16:37:03 chr1s-manjaro kernel: audit: type=1131 audit(1599489423.814:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:03 chr1s-manjaro systemd[1109]: run-user-969.mount: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1]: run-user-969.mount: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1]: user-runtime-dir@969.service: Succeeded.
Sep 07 16:37:03 chr1s-manjaro systemd[1]: Stopped User Runtime Directory /run/user/969.
Sep 07 16:37:03 chr1s-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:03 chr1s-manjaro kernel: audit: type=1131 audit(1599489423.821:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:03 chr1s-manjaro systemd[1]: Removed slice User Slice of UID 969.
Sep 07 16:37:08 chr1s-manjaro systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Sep 07 16:37:08 chr1s-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:08 chr1s-manjaro kernel: audit: type=1131 audit(1599489428.684:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:17 chr1s-manjaro systemd[1]: systemd-hostnamed.service: Succeeded.
Sep 07 16:37:17 chr1s-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:17 chr1s-manjaro kernel: audit: type=1131 audit(1599489437.871:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:18 chr1s-manjaro systemd-timesyncd[651]: Initial synchronization to time server [2a00:1f98:1001::123]:123 (2.manjaro.pool.ntp.org).
Sep 07 16:37:20 chr1s-manjaro dbus-daemon[717]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Sep 07 16:37:20 chr1s-manjaro pulseaudio[1191]: E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Sep 07 16:37:25 chr1s-manjaro systemd[1]: blueman-mechanism.service: Succeeded.
Sep 07 16:37:25 chr1s-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:25 chr1s-manjaro kernel: audit: type=1131 audit(1599489445.105:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:37:54 chr1s-manjaro msm_notifier[1233]: "qt5-translations"
Sep 07 16:38:50 chr1s-manjaro audit[1434]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=1434 comm="xfsettingsd" exe="/usr/bin/xfsettingsd" sig=11 res=1
Sep 07 16:38:50 chr1s-manjaro kernel: xfsettingsd[1434]: segfault at 564ea82bd ip 00007f66d07c7403 sp 00007fff1e4e5a48 error 4 in libICE.so.6.3.0[7f66d07c2000+e000]
Sep 07 16:38:50 chr1s-manjaro kernel: Code: 48 83 c4 08 5b 5d c3 48 8b 07 ff 60 50 66 2e 0f 1f 84 00 00 00 00 00 48 8b 07 ff 60 58 66 2e 0f 1f 84 00 00 00 00 00 48 8b 07 <ff> 60 60 66 2e 0f 1f 84 00 00 00 00 00 48 8b 07 ff 60 68 66 2e 0f
Sep 07 16:38:50 chr1s-manjaro kernel: audit: type=1701 audit(1599489530.512:87): auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=1434 comm="xfsettingsd" exe="/usr/bin/xfsettingsd" sig=11 res=1
Sep 07 16:38:50 chr1s-manjaro systemd[1]: Created slice system-systemd\x2dcoredump.slice.
Sep 07 16:38:50 chr1s-manjaro systemd[1]: Started Process Core Dump (PID 1502/UID 0).
Sep 07 16:38:50 chr1s-manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1502-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:38:50 chr1s-manjaro kernel: audit: type=1130 audit(1599489530.532:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1502-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:38:50 chr1s-manjaro systemd-coredump[1503]: [🡕] Process 1434 (xfsettingsd) of user 1000 dumped core.
                                                      Stack trace of thread 1434:
                                                      #0  0x00007f66d07c7403 _IceTransWrite (libICE.so.6 + 0xa403)
                                                      #1  0x00007f66d07c9b80 _IceWrite (libICE.so.6 + 0xcb80)
                                                      #2  0x00007f66d07c9c65 IceFlush (libICE.so.6 + 0xcc65)
                                                      #3  0x00007f66d1be1ec2 xfce_sm_client_set_restart_style (libxfce4ui-2.so.0 + 0xbec2)
                                                      #4  0x00007f66d1be1fda xfce_sm_client_disconnect (libxfce4ui-2.so.0 + 0xbfda)
                                                      #5  0x00007f66d1be2042 n/a (libxfce4ui-2.so.0 + 0xc042)
                                                      #6  0x00007f66d108f651 g_object_unref (libgobject-2.0.so.0 + 0x1f651)
                                                      #7  0x0000564ea6687635 n/a (xfsettingsd + 0x6635)
                                                      #8  0x00007f66d0aee152 __libc_start_main (libc.so.6 + 0x28152)
                                                      #9  0x0000564ea668769e n/a (xfsettingsd + 0x669e)
                                                      Stack trace of thread 1436:
                                                      #0  0x00007f66d0bbb46f __poll (libc.so.6 + 0xf546f)
                                                      #1  0x00007f66d0d51168 n/a (libglib-2.0.so.0 + 0xa0168)
                                                      #2  0x00007f66d0d01c03 g_main_loop_run (libglib-2.0.so.0 + 0x50c03)
                                                      #3  0x00007f66d11c81a8 n/a (libgio-2.0.so.0 + 0x1001a8)
                                                      #4  0x00007f66d0d2b511 n/a (libglib-2.0.so.0 + 0x7a511)
                                                      #5  0x00007f66d0c983e9 start_thread (libpthread.so.0 + 0x93e9)
                                                      #6  0x00007f66d0bc6293 __clone (libc.so.6 + 0x100293)
                                                      Stack trace of thread 1501:
                                                      #0  0x00007f66d0bc0d5d syscall (libc.so.6 + 0xfad5d)
                                                      #1  0x00007f66d0d4bc9b g_cond_wait_until (libglib-2.0.so.0 + 0x9ac9b)
                                                      #2  0x00007f66d0cd3803 n/a (libglib-2.0.so.0 + 0x22803)
                                                      #3  0x00007f66d0d2fd5b n/a (libglib-2.0.so.0 + 0x7ed5b)
                                                      Stack trace of thread 1435:
                                                      #2  0x00007f66d0d02221 g_main_context_iteration (libglib-2.0.so.0 + 0x51221)
                                                      #3  0x00007f66d0d02272 n/a (libglib-2.0.so.0 + 0x51272)
Sep 07 16:38:50 chr1s-manjaro systemd[1]: systemd-coredump@0-1502-0.service: Succeeded.
Sep 07 16:38:50 chr1s-manjaro kernel: audit: type=1131 audit(1599489530.829:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1502-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 07 16:38:50 chr1s-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1502-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
edit:
Renaming ~/.Xmodmap to ~/.Xmodmap.old made the shortcut delay issue go away.
