I did something that changed Dolphin’s [Alt-Return or right click on a file to get to] “Properties>Details.” There used to be a place there that I could click on and enter information. It was called “Remark” or “Comment” – I can’t remember which (but NOT “Comment” in the menu bar}. It is no longer there and I have been unable to figure out how to get it back. I have searched through “Settings>Configure Dolphin,” tried enabling “Comment” in “View>View Display Style—Dolphin,” tried “View>Show Additional Information,” and other things, including restoring defaults and re-installing Dolphin. Can anyone tell me how to get this back?
Kernel: 6.6.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=837c4445-d72c-4f7d-85c9-da3a06e79088 rw quiet splash
resume=UUID=28e59c87-02a4-44b7-bba3-d5bcc321aa68 udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.4.0
Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx serial: <superuser required>
part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 2403
date: 05/11/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
status: discharging
Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x35
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 800 min/max: 800/4800:4900:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 84500
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 54.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
s-diag: 1064mm (41.9") monitors: <missing: xrandr>
Monitor-1: DVI-D-1 model: Samsung SyncMaster serial: <filter> built: 2007
res: 1920x1200 dpi: 94 gamma: 1.6 size: 518x324mm (20.39x12.76")
diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200 min: 720x400
Monitor-2: HDMI-A-1 model: Acer G276HL serial: <filter> built: 2016
res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
polaris10 LLVM 18.1.8 DRM 3.54 6.6.41-1-MANJARO) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv
v: 24.1.3-manjaro1.1 device-ID: 1002:67df surfaces: xcb,xlib
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
API: ALSA v: k6.6.41-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 5.49 TiB used: 673.68 GiB (12.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 37.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 2000GB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 04RL scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 3.0
size: 28.87 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 0000 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD20SDRW-11VUUS0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1034 scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 111.03 GiB (6.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 25.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 784
Memory: total: 64 GiB available: 62.54 GiB used: 3.02 GiB (4.8%)
Processes: 384 Power: uptime: 22m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1554 pm: pacman pkgs: 1549 libs: 431 tools: pamac,yay pm: flatpak
pkgs: 5 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.35
