Pinephone Manjaro phosh not found by manjaro amd64 computer
The phone isn’t showing up on thunar or lsblk for that matter.
Is that normal?
That will depend on how you connect it …
USB-A to USB-C.
The device does not become visible like an andriod - you will have to make it visible e.g. by using the - on pinephone pro - towboot and volume-up to get a device you can mount
