Hello people! How are you?
Sorry for the inconvenience, but I have a problem and it’s giving me a headache.
I have lost internet connection intermittently. It started happening to me a few months ago, at that time I had kernel 5.10, I decided to go back to version 4.19 and seeing that it was unsuccessful I reinstalled everything with version 5.15.
I have searched the forums for similar problems, but I can’t find an answer that helps.
I leave you the commands I have executed and if you need any more, do not hesitate to let me know. I appreciate any help provided.
Regards!
$ sudo inxi --verbosity=7
Host: dell-manjaro Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 12.1.1 Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34
wm: gnome-shell dm: GDM v: 42.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A serial: 2XL4DT2
Chassis: type: 9 serial: 2XL4DT2
Mobo: Dell model: 0P3WF2 v: A00 serial: /2XL4DT2/CNWSC0092P001S/
UEFI: Dell v: 2.9.0 date: 01/17/2019
ID-1: BAT0 charge: 1.5 Wh (100.0%) condition: 1.5/41.4 Wh (3.6%)
volts: 16.2 min: 14.8 model: SMP DELL GR43778 type: Li-ion serial: 8289
status: N/A
RAM: total: 15.49 GiB used: 2.43 GiB (15.7%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM A type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: spec: 2400 MT/s actual: 2133 MT/s volts: 1.2
width (bits): data: 64 total: 64 manufacturer: 0198000080AD
part-no: 9905700-011.A00G serial: D450AE4E
Device-2: DIMM B type: DDR4 detail: synchronous unbuffered (unregistered)
width (bits): data: 64 total: 64 manufacturer: 01980000830B
part-no: 9905624-058.A00G serial: C1A842A2
Info: dual core model: Intel Core i3-7020U bits: 64 type: MT MCP
smt: enabled arch: Amber/Kaby Lake note: check level: v3 rev: 9 cache:
L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2300 min/max: 400/2300 volts: 0.7 V ext-clock: 100 MHz
cores: 1: 2300 2: 2300 3: 2300 4: 2300 bogomips: 18406
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Device-1: Intel vendor: Dell driver: i915 v: kernel arch: Gen-9.5 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5921
class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-5:3 chip-ID: 1bcf:28c0 class-ID: 0e02
Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: BOE Display 0x0808 res: 1366x768 hz: 60 dpi: 101
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2F) v: 4.6 Mesa
22.1.6 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: speed: 2.5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp1s0 state: up mac: 48:5f:99:55:62:af
IP v4: 192.168.0.122/24 type: noprefixroute scope: global
broadcast: 192.168.0.255
IP v6: fe80::26a:9568:14ab:7d8b/64 type: noprefixroute scope: link
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp2s0 state: down mac: 6c:2b:59:55:5a:68
IF-ID-1: enp0s20f0u3 state: unknown speed: -1 duplex: half
mac: 2e:71:f6:82:a7:ef
IP v4: 192.168.186.173/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.186.255
IP v6: fe80::2520:88de:d800:31de/64 type: noprefixroute scope: link
WAN IP: 179.40.67.123
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
chip-ID: 0cf3:e009 class-ID: e001
Local Storage: total: 1.13 TiB used: 13.32 GiB (1.2%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: ZDEEZ2PB rev: SDM3 scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WDS240G2G0A-00JH30
size: 223.58 GiB speed: 6.0 Gb/s type: SSD serial: 19222E804835 rev: 0000
scheme: GPT
ID-1: / size: 108.49 GiB used: 13.29 GiB (12.3%) fs: ext4 dev: /dev/sdb6
label: N/A uuid: b7081c0a-e3dd-4563-959b-d7cd2f816c72
ID-2: /boot/efi size: 96 MiB used: 25.3 MiB (26.4%) fs: vfat
dev: /dev/sdb1 label: N/A uuid: 3EE8-BD4C
ID-1: /dev/sda1 size: 127 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/sda2 size: 638.42 GiB fs: ntfs label: data
uuid: 01D547126D8D0700
ID-3: /dev/sda3 size: 292.97 GiB fs: ext4 label: N/A
uuid: 40913f7f-c095-4d1f-b921-639ad18ca3a2
ID-4: /dev/sdb2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-5: /dev/sdb3 size: 111.17 GiB fs: ntfs label: N/A
uuid: 64727460727438BE
ID-6: /dev/sdb4 size: 521 MiB fs: ntfs label: N/A uuid: 4022691F22691AE4
ID-7: /dev/sdb5 size: 1024 MiB fs: swap label: N/A
uuid: f807d92a-e0a9-4f67-a4ad-e46ac7258f33
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: SHARKOON GmbH 2.4GHz Wireless rechargeable vertical
mouse [More&Better] type: Mouse driver: hid-generic,usbhid interfaces: 1
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 1-3:7 info: Motorola PCS one fusion type: CDC-Data
driver: rndis_host interfaces: 2 rev: 2.1 speed: 480 Mb/s power: 500mA
chip-ID: 22b8:2e24 class-ID: 0a00 serial: ZE222JBNDV
Device-3: 1-5:3 info: Sunplus Innovation Integrated_Webcam_HD type: Video
Device-4: 1-6:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: 20100201396000000
Device-5: 1-8:5 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e009
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 42.0 C pch: 42.0 C mobo: 41.0 C
Fan Speeds (RPM): cpu: 0
Processes: 246 Uptime: 19m wakeups: 2 Init: systemd v: 251
default: graphical Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: 1228
pm: pacman pkgs: 1221 pm: snap pkgs: 7 Shell: Zsh (sudo) v: 5.9
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.21
$ hwinfo --netcard --wlan --bluetooth | grep -Ei "model:|driver:|status:|cmd:|file:|detected:" | grep -v "Config Status"
Model: "Realtek RTL810xE PCI Express Fast Ethernet controller"
Driver: "r8169"
Device File: enp2s0
Link detected: no
Driver Status: r8169 is active
Driver Activation Cmd: "modprobe r8169"
Model: "Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter"
Driver: "ath10k_pci"
Device File: wlp1s0
Link detected: yes
Driver Status: ath10k_pci is active
Driver Activation Cmd: "modprobe ath10k_pci"
Model: "Qualcomm Atheros Bluetooth Device"
Driver: "btusb"
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
Model: "Motorola PCS motorola one fusion"
Driver: "rndis_host"
Device File: enp0s20f0u3
Link detected: yes
Driver Status: rndis_host is active
Driver Activation Cmd: "modprobe rndis_host"
$ sudo dmesg | grep ath10k
[ 7.646890] ath10k_pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 7.649301] ath10k_pci 0000:01:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 7.933720] ath10k_pci 0000:01:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 1028:1810
[ 7.933729] ath10k_pci 0000:01:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[ 7.934349] ath10k_pci 0000:01:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
[ 8.015100] ath10k_pci 0000:01:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[ 8.108458] ath10k_pci 0000:01:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 8.193500] ath10k_pci 0000:01:00.0 wlp1s0: renamed from wlan0
