Just looking for a tweak or dconf setting to make the mouse cursor disappear while typing, like on MacOS.
Thanks all!
inxi system info
$ inxi -Fxxxza --no-host
System: Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=c3b1cff2-ed37-4ee0-af3b-d404097c96ef rw quiet
cryptdevice=UUID=eb7684b1-691d-476a-81d7-9f553231a205:luks-eb7684b1-691d-476a-81d7-9f553231a205
root=/dev/mapper/luks-eb7684b1-691d-476a-81d7-9f553231a205 apparmor=1 security=apparmor
resume=/dev/mapper/luks-1aa70ee5-d740-4f20-a0ae-699cefa5a54f udev.log_priority=3
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Desktop System: Apple product: iMac12,1 v: 1.0 serial: <filter> Chassis: type: 13 v: Mac-942B5BF58194151B
serial: <filter>
Mobo: Apple model: Mac-942B5BF58194151B serial: <filter> UEFI: Apple v: 85.0.0.0.0 date: 04/16/2019
CPU: Topology: Quad Core model: Intel Core i5-2400S bits: 64 type: MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
stepping: 7 microcode: 2F L2 cache: 6144 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20007
Speed: 1948 MHz min/max: 1600/3300 MHz Core speeds (MHz): 1: 2066 2: 2175 3: 2309 4: 2340
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0102
Device-2: Advanced Micro Devices [AMD/ATI] Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M] vendor: Apple
driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:6741
Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo bus ID: 1-2:3 chip ID: 05ac:850b
serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: gnome-shell driver: ati,intel,radeon unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3") s-diag: 1055mm (41.6")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 103 size: 475x267mm (18.7x10.5") diag: 545mm (21.5")
Monitor-2: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 103 size: 475x267mm (18.7x10.5") diag: 545mm (21.5")
OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 5.8.3-2-MANJARO LLVM 10.0.1) v: 3.3 Mesa 20.1.7 compat-v: 3.1
direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series] vendor: Apple driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 1002:aa90
Sound Server: ALSA v: k5.8.3-2-MANJARO
Network: Device-1: Broadcom and subsidiaries NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3 v: kernel port: 2000
bus ID: 02:00.0 chip ID: 14e4:16b4
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter vendor: Apple AirPort Extreme driver: ath9k v: kernel
port: 2000 bus ID: 03:00.0 chip ID: 168c:0030
IF: wlp3s0 state: down mac: <filter>
Drives: Local Storage: total: 1.36 TiB used: 5.98 TiB (438.4%)
ID-1: /dev/sda vendor: Western Digital model: WD5000AAKS-402AA0 size: 465.76 GiB block size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1D02 temp: 52 C scheme: GPT
ID-2: /dev/sdb model: Mercury Electra 6G SSD size: 931.51 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 7B0 temp: 48 C scheme: GPT
Partition: ID-1: / raw size: 918.37 GiB size: 902.95 GiB (98.32%) used: 396.25 GiB (43.9%) fs: ext4 dev: /dev/dm-0
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 12.85 GiB used: 3.86 GiB (30.0%) priority: -2 dev: /dev/dm-1
Sensors: System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1197
Info: Processes: 313 Uptime: 21d 2h 31m Memory: 11.68 GiB used: 6.65 GiB (56.9%) Init: systemd v: 246 Compilers:
gcc: 10.2.0 clang: 10.0.1 Packages: pacman: 1774 lib: 401 flatpak: 0 Shell: Bash v: 5.0.18 running in: guake
inxi: 3.1.05
