Hi there Iβve read up and believe I am supposed to share this to give you all more details:
inxi --admin --verbosity=7 --filter --width ξ²
Kernel: 5.10.93-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ced01be0-a715-4511-9f74-9f4d250fe5c9 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: LENOVO product: 90RC00NVMH v: Legion T5 26AMR5
serial: Chassis: type: 3 serial:
Mobo: LENOVO model: 3716 v: SDK0J40709 WIN 3259726840836
serial: UEFI: LENOVO v: O4MKT1DA date: 04/14/2021
RAM: total: 15.53 GiB used: 2.49 GiB (16.0%)
RAM Report:
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000B
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2632 high: 3204 min/max: 1400/3900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3204 2: 2472
3: 2395 4: 2950 5: 2300 6: 2637 7: 2411 8: 2395 9: 2549 10: 2994 11: 2721
12: 2567 bogomips: 93467
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vaes
vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:21c4 class-ID: 0300
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.93-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: N/A port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8852
class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: d000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-10:4 chip-ID: 0bda:4852 class-ID: e001 serial:
Local Storage: total: 14.09 TiB used: 844.31 GiB (5.9%)
model: PC SN730 SDBQNTY-512G-1001 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: rev: 11170101 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: rev: 054 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: rev: 030 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
model: Backup+ Hub BK size: 10.91 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: rev: D781 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: Expansion
size: 1.36 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: rev: 0707 scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 125.54 GiB (26.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ced01be0-a715-4511-9f74-9f4d250fe5c9
label: NO_LABEL uuid: 2F52-DDAC
ID-3: /run/media/luc/691a18fb-d7bd-436d-adaa-8022ae118ed4
raw-size: 447.13 GiB size: 439.04 GiB (98.19%) used: 40.38 GiB (9.2%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 691a18fb-d7bd-436d-adaa-8022ae118ed4
ID-4: /run/media/luc/New Volume raw-size: 976.56 GiB
size: 976.56 GiB (100.00%) used: 240.68 GiB (24.6%) fs: ntfs dev: /dev/sdc2
maj-min: 8:34 label: New Volume uuid: 02F07E86F07E7FA9
ID-5: /run/media/luc/New Volume1 raw-size: 9.96 TiB
size: 9.96 TiB (100.00%) used: 418.8 MiB (0.0%) fs: ntfs dev: /dev/sdc3
maj-min: 8:35 label: New Volume uuid: 4422FC0122FBF630
ID-6: /run/media/luc/Seagate Expansion Drive raw-size: 1.36 TiB
size: 1.36 TiB (100.00%) used: 204.56 GiB (14.6%) fs: ntfs dev: /dev/sdd1
maj-min: 8:49 label: Seagate Expansion Drive uuid: 18F2A222F2A203DA
ID-7: /run/media/luc/e84fe4e8-1547-4035-ba9b-a6002a6af544
raw-size: 931.51 GiB size: 915.81 GiB (98.31%) used: 232.74 GiB (25.4%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: e84fe4e8-1547-4035-ba9b-a6002a6af544
ID-1: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs:
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 3-6:2 info: China Resource Semico USB Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:4094 class-ID: 0300
Device-2: 3-7:7 info: Lenovo ITE Device(8297) type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 17ef:c955 class-ID: 0301
Device-3: 3-10:4 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-2:2 info: Logitech G600 Gaming Mouse type: Mouse,Keyboard
power: 500mA chip-ID: 046d:c24a class-ID: 0300 serial:
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-7: 7-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-8: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-9: 7-1.4:3 info: Seagate RSS LLC Backup Plus Hub ports: 3 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 0bc2:ab44 class-ID: 0900
Hub-10: 8-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-11: 8-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Hub-12: 8-1.4:3 info: Seagate RSS LLC Backup+ Hub ports: 3 rev: 3.0
speed: 5 Gb/s chip-ID: 0bc2:ab45 class-ID: 0900
Device-1: 8-1.4.1:4 info: Seagate RSS LLC Backup Plus Hub (Mass Storage)
type: Mass Storage driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s
chip-ID: 0bc2:ab38 class-ID: 0806 serial:
Device-2: 8-1.4.3:5 info: Seagate RSS LLC Expansion Portable
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 0bc2:231a class-ID: 0806 serial:
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 33 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 21%
Processes: 331 Uptime: 3m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1244 pacman: 1237 lib: 332
flatpak: 0 snap: 7 Shell: Zsh v: 5.8 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.12
sudo journalctl --boot | tail -n 100 ξ²
[sudo] password for luc:
jan 26 08:05:17 luc-90rc00nvmh rtkit-daemon[985]: Supervising 9 threads of 4 processes of 1 users.
jan 26 08:05:19 luc-90rc00nvmh rtkit-daemon[985]: Supervising 9 threads of 4 processes of 1 users.
jan 26 08:05:20 luc-90rc00nvmh rtkit-daemon[985]: Supervising 9 threads of 4 processes of 1 users.
jan 26 08:05:20 luc-90rc00nvmh rtkit-daemon[985]: Successfully made thread 1996 of process 1838 owned by β1000β RT at priority 10.
jan 26 08:05:20 luc-90rc00nvmh rtkit-daemon[985]: Supervising 10 threads of 5 processes of 1 users.
jan 26 08:05:21 luc-90rc00nvmh systemd[1]: systemd-timedated.service: Deactivated successfully.
jan 26 08:05:21 luc-90rc00nvmh audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=βunit=systemd-timedated comm=βsystemdβ exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=successβ
jan 26 08:05:21 luc-90rc00nvmh kernel: audit: type=1131 audit(1643180721.345:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=βunit=systemd-timedated comm=βsystemdβ exe="/usr/lib/systemd/systemd" hostname=? addr=? t
jan 26 08:05:21 luc-90rc00nvmh audit: BPF prog-id=17 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh audit: BPF prog-id=16 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh audit: BPF prog-id=15 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180721.365:110): prog-id=17 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180721.365:111): prog-id=16 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180721.365:112): prog-id=15 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh systemd[1]: systemd-hostnamed.service: Deactivated successfully.
jan 26 08:05:21 luc-90rc00nvmh audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=βunit=systemd-hostnamed comm=βsystemdβ exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=successβ
jan 26 08:05:21 luc-90rc00nvmh kernel: audit: type=1131 audit(1643180721.675:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=βunit=systemd-hostnamed comm=βsystemdβ exe="/usr/lib/systemd/systemd" hostname=? addr=? t
jan 26 08:05:21 luc-90rc00nvmh audit: BPF prog-id=14 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh audit: BPF prog-id=13 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh audit: BPF prog-id=12 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180721.808:114): prog-id=14 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180721.808:115): prog-id=13 op=UNLOAD
jan 26 08:05:21 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180721.808:116): prog-id=12 op=UNLOAD
jan 26 08:05:22 luc-90rc00nvmh rtkit-daemon[985]: Supervising 10 threads of 5 processes of 1 users.
jan 26 08:05:23 luc-90rc00nvmh dbus-daemon[554]: [system] Activating via systemd: service name=βorg.freedesktop.timedate1β unit=βdbus-org.freedesktop.timedate1.serviceβ requested by β:1.12β (uid=0 pid=557 comm="/usr/lib/snapd/snapd β)
jan 26 08:05:23 luc-90rc00nvmh audit: BPF prog-id=22 op=LOAD
jan 26 08:05:23 luc-90rc00nvmh audit: BPF prog-id=23 op=LOAD
jan 26 08:05:23 luc-90rc00nvmh audit: BPF prog-id=24 op=LOAD
jan 26 08:05:23 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180723.985:117): prog-id=22 op=LOAD
jan 26 08:05:23 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180723.985:118): prog-id=23 op=LOAD
jan 26 08:05:23 luc-90rc00nvmh systemd[1]: Starting Time & Date Serviceβ¦
jan 26 08:05:24 luc-90rc00nvmh dbus-daemon[554]: [system] Successfully activated service βorg.freedesktop.timedate1β
jan 26 08:05:24 luc-90rc00nvmh systemd[1]: Started Time & Date Service.
jan 26 08:05:24 luc-90rc00nvmh audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm=βsystemdβ exe=β/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=successβ
jan 26 08:05:25 luc-90rc00nvmh rtkit-daemon[985]: Supervising 10 threads of 5 processes of 1 users.
jan 26 08:05:25 luc-90rc00nvmh rtkit-daemon[985]: Successfully made thread 2080 of process 1651 owned by β1000β RT at priority 10.
jan 26 08:05:25 luc-90rc00nvmh rtkit-daemon[985]: Supervising 11 threads of 6 processes of 1 users.
jan 26 08:05:26 luc-90rc00nvmh rtkit-daemon[985]: Supervising 11 threads of 6 processes of 1 users.
jan 26 08:05:26 luc-90rc00nvmh rtkit-daemon[985]: Successfully made thread 2090 of process 1772 owned by β1000β RT at priority 10.
jan 26 08:05:26 luc-90rc00nvmh rtkit-daemon[985]: Supervising 12 threads of 7 processes of 1 users.
jan 26 08:05:33 luc-90rc00nvmh xdg-desktop-portal-kde[1134]: xdp-kde-background: GetAppState called: no parameters
jan 26 08:05:44 luc-90rc00nvmh rtkit-daemon[985]: Supervising 12 threads of 7 processes of 1 users.
jan 26 08:05:54 luc-90rc00nvmh systemd[1]: systemd-timedated.service: Deactivated successfully.
jan 26 08:05:54 luc-90rc00nvmh audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=βunit=systemd-timedated comm=βsystemdβ exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=successβ
jan 26 08:05:54 luc-90rc00nvmh kernel: kauditd_printk_skb: 2 callbacks suppressed
jan 26 08:05:54 luc-90rc00nvmh kernel: audit: type=1131 audit(1643180754.072:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=βunit=systemd-timedated comm=βsystemdβ exe="/usr/lib/systemd/systemd" hostname=? addr=? t
jan 26 08:05:54 luc-90rc00nvmh audit: BPF prog-id=24 op=UNLOAD
jan 26 08:05:54 luc-90rc00nvmh audit: BPF prog-id=23 op=UNLOAD
jan 26 08:05:54 luc-90rc00nvmh audit: BPF prog-id=22 op=UNLOAD
jan 26 08:05:54 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180754.092:122): prog-id=24 op=UNLOAD
jan 26 08:05:54 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180754.092:123): prog-id=23 op=UNLOAD
jan 26 08:05:54 luc-90rc00nvmh kernel: audit: type=1334 audit(1643180754.092:124): prog-id=22 op=UNLOAD
jan 26 08:06:03 luc-90rc00nvmh xdg-desktop-portal-kde[1134]: xdp-kde-background: GetAppState called: no parameters
jan 26 08:07:19 luc-90rc00nvmh rtkit-daemon[985]: Supervising 12 threads of 7 processes of 1 users.
jan 26 08:07:59 luc-90rc00nvmh kwin_x11[839]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16797, resource id: 39846037, major code: 18 (ChangeProperty), minor code: 0
jan 26 08:07:59 luc-90rc00nvmh systemd[774]: Started Konsole - Terminal.
jan 26 08:07:59 luc-90rc00nvmh plasmashell[918]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:377: Unable to assign [undefined] to QString
jan 26 08:07:59 luc-90rc00nvmh kwin_x11[839]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17109, resource id: 14686124, major code: 3 (GetWindowAttributes), minor code: 0
jan 26 08:07:59 luc-90rc00nvmh kwin_x11[839]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 17110, resource id: 14686124, major code: 14 (GetGeometry), minor code: 0
jan 26 08:08:04 luc-90rc00nvmh sudo[2449]: luc : a password is required ; TTY=pts/1 ; PWD=/home/luc ; USER=root ; COMMAND=/sbin/file -s /dev/sdc1
jan 26 08:08:05 luc-90rc00nvmh polkitd[556]: Registered Authentication Agent for unix-process:2473:19888 (system bus name :1.107 [/sbin/flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
jan 26 08:08:05 luc-90rc00nvmh polkitd[556]: Unregistered Authentication Agent for unix-process:2473:19888 (system bus name :1.107, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
jan 26 08:09:37 luc-90rc00nvmh kwin_x11[839]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43509, resource id: 4194312, major code: 18 (ChangeProperty), minor code: 0
jan 26 08:09:46 luc-90rc00nvmh dbus-daemon[554]: [system] Activating via systemd: service name=βorg.freedesktop.home1β unit=βdbus-org.freedesktop.home1.serviceβ requested by β:1.108β (uid=0 pid=2526 comm=βsudo journalctl --boot β)
jan 26 08:09:46 luc-90rc00nvmh dbus-daemon[554]: [system] Activation via systemd failed for unit βdbus-org.freedesktop.home1.serviceβ: Unit dbus-org.freedesktop.home1.service not found.
jan 26 08:09:46 luc-90rc00nvmh sudo[2526]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jan 26 08:09:50 luc-90rc00nvmh audit[2526]: USER_AUTH pid=2526 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct=βlucβ exe=β/usr/bin/sudoβ hostname=? addr=? terminal=
/dev/pts/1 res=successβ
jan 26 08:09:50 luc-90rc00nvmh audit[2526]: USER_ACCT pid=2526 uid=1000 auid=1000 ses=2 subj==unconfined msg=βop=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct=βlucβ exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 r
es=successβ
jan 26 08:09:50 luc-90rc00nvmh audit[2526]: CRED_REFR pid=2526 uid=1000 auid=1000 ses=2 subj==unconfined msg=βop=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct=βrootβ exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/p
ts/1 res=successβ
jan 26 08:09:50 luc-90rc00nvmh sudo[2526]: luc : TTY=pts/1 ; PWD=/home/luc ; USER=root ; COMMAND=/usr/bin/journalctl --boot
jan 26 08:09:50 luc-90rc00nvmh kernel: audit: type=1100 audit(1643180990.882:125): pid=2526 uid=1000 auid=1000 ses=2 subj==unconfined msg=βop=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct=βlucβ exe="/usr/bin/sudo
" hostname=? addr=? terminal=/dev/pts/1 res=successβ
jan 26 08:09:50 luc-90rc00nvmh kernel: audit: type=1101 audit(1643180990.882:126): pid=2526 uid=1000 auid=1000 ses=2 subj==unconfined msg=βop=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct=βlucβ exe="/usr/bin/sudo" hostname=?
jan 26 08:09:50 luc-90rc00nvmh kernel: audit: type=1110 audit(1643180990.882:127): pid=2526 uid=1000 auid=1000 ses=2 subj==unconfined msg=βop=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct=βrootβ exe="/usr/bin/sudo" host
jan 26 08:09:50 luc-90rc00nvmh sudo[2526]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
jan 26 08:09:50 luc-90rc00nvmh audit[2526]: USER_START pid=2526 uid=1000 auid=1000 ses=2 subj==unconfined msg=βop=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct=βrootβ exe="/usr/bin/sudo" hostname=? addr=
jan 26 08:09:50 luc-90rc00nvmh kernel: audit: type=1105 audit(1643180990.888:128): pid=2526 uid=1000 auid=1000 ses=2 subj==unconfined msg=βop=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct=βrootβ exe="/us
r/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=successβ
I hope Iβve given enough information now, thanks in advance.
