I’m having long boot times, or it just doesn’t boot at all. After checking the logs, it looks like an Xorg or Nvidia issue, but I’m not sure. I have only been able to successfully boot by switching TTYs, then switching back to the GUI TTY. This happened when I switched to 5.4 because my Nvidia drivers weren’t working with 5.10.
Any help would be appreciated!
Output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.4.123-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ce8d1243-41e5-4421-ba3f-16021d4e6982 rw
i915.enable_dpcd_backlight=0 quiet splash apparmor=1 security=apparmor
resume=UUID=b2c6f5e3-7888-44aa-8eef-0105d9f1d4bb udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Dell product: XPS 15 7590 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0VYV0G v: A00 serial: <filter> UEFI: Dell v: 1.8.1
date: 07/03/2020
ID-1: BAT0 charge: 64.1 Wh (100.0%) condition: 64.1/97.0 Wh (66.1%)
volts: 12.6 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: Full
RAM: total: 15.28 GiB used: 4.06 GiB (26.5%)
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: D6 cache: L2: 12 MiB bogomips: 62431
Speed: 897 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 897 2: 900 3: 900
4: 898 5: 900 6: 900 7: 900 8: 893 9: 900 10: 901 11: 900 12: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:4 chip-ID: 0c45:6723 class-ID: 0e02
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.4.123-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks driver: iwlwifi
v: kernel port: 3000 bus-ID: 3b:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
Local Storage: total: 931.51 GiB used: 242.25 GiB (26.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 rotation: SSD serial: <filter> rev: S5Z42102 scheme: GPT
ID-1: / raw-size: 178.85 GiB size: 175.04 GiB (97.87%)
used: 29.22 GiB (16.7%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: ce8d1243-41e5-4421-ba3f-16021d4e6982
ID-2: /boot/efi raw-size: 681 MiB size: 679.6 MiB (99.80%)
used: 312 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: CB2B-CB05
ID-3: /home raw-size: 726.87 GiB size: 714.46 GiB (98.29%)
used: 213.03 GiB (29.8%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
label: N/A uuid: ff381680-0b03-4d02-a4e7-45e762e5e6c7
ID-4: /home/<filter>/NAS raw-size: N/A size: 41.9 TiB
used: 18.62 TiB (44.4%) fs: nfs remote: 192.168.0.143:/volume1/zNAS
label: N/A uuid: N/A
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: b2c6f5e3-7888-44aa-8eef-0105d9f1d4bb
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: BAEA7F57EA7F0F3F
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 14.79 GiB fs: ntfs label: Image
uuid: E6347F9E347F7103
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 1.24 GiB fs: ntfs
label: DELLSUPPORT uuid: 1264CFFF64CFE417
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-7:3 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
serial: <filter>
Device-3: 1-12:4 info: Microdia Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 344 Uptime: 34m wakeups: 21736 Init: systemd v: 247
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1362 lib: 378
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04
Potentially Relevant Journal Logs
Jun 08 22:54:43 zArch gnome-session[2665]: gnome-session-binary[2665]: WARNING: Lost name on bus: org.gnome.SessionManager
Jun 08 22:54:43 zArch gnome-session-binary[2665]: WARNING: Lost name on bus: org.gnome.SessionManager
Jun 08 22:54:43 zArch gsd-sharing[2769]: Error releasing name org.gnome.SettingsDaemon.Sharing: The connection is closed
Jun 08 22:54:43 zArch gsd-usb-protect[2771]: Error releasing name org.gnome.SettingsDaemon.UsbProtection: The connection is closed
Jun 08 22:54:43 zArch gsd-rfkill[2775]: Error releasing name org.gnome.SettingsDaemon.Rfkill: The connection is closed
Jun 08 22:54:43 zArch gsd-print-notif[2774]: Error releasing name org.gnome.SettingsDaemon.PrintNotifications: The connection is closed
Jun 08 22:54:43 zArch gsd-smartcard[2779]: Error releasing name org.gnome.SettingsDaemon.Smartcard: The connection is closed
Jun 08 22:54:43 zArch gsd-screensaver[2798]: Error releasing name org.freedesktop.ScreenSaver: The connection is closed
Jun 08 22:54:43 zArch gsd-datetime[2785]: Error releasing name org.gnome.SettingsDaemon.Datetime: The connection is closed
Jun 08 22:54:43 zArch gsd-sound[2802]: Error releasing name org.gnome.SettingsDaemon.Sound: The connection is closed
Jun 08 22:54:43 zArch gsd-a11y-settin[2803]: Error releasing name org.gnome.SettingsDaemon.A11ySettings: The connection is closed
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) UnloadModule: "libinput"
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:80
Jun 08 22:54:43 zArch gsd-housekeepin[2812]: Error releasing name org.gnome.SettingsDaemon.Housekeeping: The connection is closed
Jun 08 22:54:43 zArch polkitd[673]: Unregistered Authentication Agent for unix-session:8 (system bus name :1.118, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8) (disconnected f>
Jun 08 22:54:43 zArch gsd-color[2212]: failed to connect to device: Failed to connect to missing device /org/freedesktop/ColorManager/devices/xrandr_Sharp_Corporation_gdm_120
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:69
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:73
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:71
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:70
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:83
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:82
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:81
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:66
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:65
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:68
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) systemd-logind: releasing fd for 13:67
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA(GPU-0): Deleting GPU-0
Jun 08 22:54:43 zArch gnome-session[2947]: Unable to init server: Could not connect: Connection refused
Jun 08 22:54:43 zArch gnome-session-f[2947]: Cannot open display:
Jun 08 22:54:37 zArch gnome-shell[2039]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Jun 08 22:54:37 zArch gnome-shell[2039]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Jun 08 22:54:37 zArch gnome-shell[2039]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Jun 08 22:54:37 zArch gnome-shell[2039]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Jun 08 22:54:37 zArch gnome-shell[2039]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Jun 08 22:54:43 zArch /usr/lib/gdm-x-session[2650]: (II) Server terminated successfully (0). Closing log file.
Jun 08 22:54:43 zArch audit[2634]: USER_END pid=2634 uid=0 auid=120 ses=8 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" ex>
Jun 08 22:54:43 zArch audit[2634]: CRED_DISP pid=2634 uid=0 auid=120 ses=8 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=zArch addr=? terminal=/d>
Jun 08 22:54:43 zArch systemd[1]: session-8.scope: Succeeded.
Jun 08 22:54:43 zArch kernel: audit: type=1106 audit(1623164083.925:187): pid=2634 uid=0 auid=120 ses=8 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam>
Jun 08 22:54:43 zArch kernel: audit: type=1104 audit(1623164083.925:188): pid=2634 uid=0 auid=120 ses=8 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" host>
Jun 08 22:54:43 zArch systemd-logind[681]: Removed session 8.
Jun 08 22:54:43 zArch systemd[2639]: pulseaudio.service: Succeeded.
Jun 08 22:54:43 zArch gdm[718]: Gdm: Child process -2648 was already dead.
Jun 08 22:54:54 zArch systemd[1]: Stopping User Manager for UID 120...
Jun 08 22:54:54 zArch systemd[2639]: Stopped target Main User Target.
Jun 08 22:54:54 zArch systemd[2639]: Stopping D-Bus User Message Bus...
Jun 08 22:54:54 zArch systemd[2639]: dbus.service: Succeeded.
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA(G0): Setting mode "NULL"
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (==) NVIDIA(G0): Disabling shared memory pixmaps
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (==) NVIDIA(G0): Backing store enabled
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (==) NVIDIA(G0): Silken mouse disabled
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (==) NVIDIA(G0): DPMS enabled
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Loading sub module "dri2"
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) LoadModule: "dri2"
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Module "dri2" already built-in
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA(G0): [DRI2] Setup complete
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Initializing extension Generic Event Extension
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Initializing extension SHAPE
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Initializing extension MIT-SHM
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Initializing extension XInputExtension
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Initializing extension XTEST
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Initializing extension BIG-REQUESTS
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Initializing extension SYNC
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: compiled for 1.6.99.901, module version = 1.0.0
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: Module class: X.Org Server Extension
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA GLX Module 465.31 Thu May 13 22:16:59 UTC 2021
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA: The X server supports PRIME Render Offload.
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce GTX 1650 (TU117-A) at PCI:1:0:0
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA(G0): (GPU-0)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (--) NVIDIA(G0): Memory: 4194304 kBytes
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (--) NVIDIA(G0): VideoBIOS: 90.17.1c.40.4b
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA(G0): Detected PCI Express Link width: 16X
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA(G0): Validated MetaModes:
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA(G0): "NULL"
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (WW) NVIDIA(G0): Unable to get display device for DPI computation.
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) LoadModule: "glxserver_nvidia"
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (==) modeset(0): Backing store enabled
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (==) modeset(0): Silken mouse disabled
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (==) modeset(0): DPMS enabled
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): [DRI2] Setup complete
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): [DRI2] DRI driver: iris
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): [DRI2] VDPAU driver: va_gl
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (WW) NVIDIA: Failed to bind sideband socket to
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (WW) NVIDIA: '/var/run/nvidia-xdriver-03c032ac' Permission denied
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) NVIDIA: access.
Jun 08 22:54:27 zArch acpid[664]: client connected from 2650[120:120]
Jun 08 22:54:27 zArch acpid[664]: 1 client rule loaded
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) Module glamoregl: vendor="X.Org Foundation"
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: compiled for 1.20.11, module version = 1.0.1
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: ABI class: X.Org ANSI C Emulation, version 0.4
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 630 (CFL GT2)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): glamor initialized
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Output eDP-1 has no monitor section
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Output DP-1 has no monitor section
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Output DP-2 has no monitor section
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Output DP-3 has no monitor section
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): EDID for output eDP-1
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Manufacturer: SHP Model: 14ba Serial#: 0
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Year: 2019 Week: 22
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): EDID Version: 1.4
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Digital Display Input
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): 8 bits per channel
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Digital interface is DisplayPort
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Gamma: 2.20
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): No DPMS capabilities specified
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Default color space is primary color space
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): First detailed timing is preferred mode
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Preferred mode is native pixel format and refresh rate
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): redX: 0.640 redY: 0.329 greenX: 0.300 greenY: 0.600
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): blueX: 0.149 blueY: 0.060 whiteX: 0.312 whiteY: 0.328
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Manufacturer's mask: 0
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Supported detailed timing:
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): clock: 142.5 MHz Image Size: 344 x 194 mm
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1142 v_border: 0
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: [31B blob data]
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Unknown vendor-specific block 0
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): EDID (in hex):
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): 00ffffffffffff004d10ba1400000000
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): 161d0104a52213780ede50a3544c9926
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): 0f505400000001010101010101010101
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): 010101010101ac3780a070383e403020
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): 350058c2100000180000000000000000
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): 00000000000000000000000000fe004d
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): 57503154804c513135364d3100000000
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): 0002410332001200000a010a202000d3
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Printing probed modes for output eDP-1
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1920x1080"x60.0 142.52 1920 1968 2000 2080 1080 1083 1088 1142 -hsync -vsync (68.5 kHz eP)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
Jun 08 22:54:27 zArch /usr/lib/gdm-x-session[2650]: (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz
xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP- primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 60.00*+ 59.97 59.96 59.93
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
