Has anyone else found that lollypop crashes when they select to shuffle all artists. I get the following output if I launch Lollypop from the terminal:
File "/usr/lib/python3.9/site-packages/lollypop/view_artists_rounded.py", line 214, in __on_banner_play_all
album_ids = App().albums.get_ids([], [], self.storage_type,
File "/usr/lib/python3.9/site-packages/lollypop/database_albums.py", line 1081, in get_ids
result = sql.execute(request, (storage_type,))
sqlite3.ProgrammingError: Incorrect number of bindings supplied. The current statement uses 2, and there are 1 supplied.
To replicate the bug, launch Lollypop, click on “Artists” on the left hand navigation bar, then click on the shuffle icon in the top right hand corner.
My output for inxi -Fazy
is:
Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=f5245ffc-4c91-4b47-b905-1d35123f8237 rw quiet
rd.udev.log_priority=3 mitigations=off
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop System: Intel Client Systems product: NUC8i7HVK v: J71485-504
serial: <filter> Chassis: Intel Corporation type: 3 v: 2.0 serial: <filter>
Mobo: Intel model: NUC8i7HVB v: J68196-504 serial: <filter> UEFI: Intel
v: HNKBLi70.86A.0064.2020.1028.1438 date: 10/28/2020
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Device-2: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: Discharging
Info: Quad Core model: Intel Core i7-8809G bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
L2 cache: 8 MiB
bogomips: 49618
Speed: 900 MHz min/max: 800/8300 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Type: srbds status: Vulnerable
Device-1: Intel HD Graphics 630 driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:591b
Device-2: AMD Polaris 22 XT [Radeon RX Vega M GH] vendor: Intel
driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:694c
Display: wayland server: X.Org 1.20.99.1 compositor: gnome-shell driver:
loaded: amdgpu,ati,intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 50 dpi: 92
size: 530x300mm (20.9x11.8") diag: 609mm (24")
Monitor-2: XWAYLAND1 res: 1920x1080 hz: 60 dpi: 92
OpenGL: renderer: AMD VEGAM (DRM 3.40.0 5.10.7-3-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.3 direct render: Yes
Device-1: Intel CM238 HD Audio driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a171
Device-2: AMD Polaris 22 HDMI Audio vendor: Intel driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 1002:ab08
Device-3: Logitech Logitech StreamCam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus ID: 6-1:2
chip ID: 046d:0893 serial: <filter>
Sound Server: ALSA v: k5.10.7-3-MANJARO
Device-1: Intel Ethernet I219-LM driver: e1000e v: kernel port: f040
bus ID: 00:1f.6 chip ID: 8086:15b7
Device-2: Intel I210 Gigabit Network driver: igb v: kernel port: b000
bus ID: 05:00.0 chip ID: 8086:157b
IF: enp5s0 state: down mac: <filter>
Device-3: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: b000
bus ID: 06:00.0 chip ID: 8086:24fd
IF: wlp6s0 state: down mac: <filter>
IF-ID-1: eth0 state: up speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 1.86 TiB used: 594.96 GiB (31.2%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 970 PRO 1TB
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 1B2QEXP7 temp: 45.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 serial: <filter> rev: SS0411B temp: 38.9 C
ID-1: / raw size: 953.57 GiB size: 937.61 GiB (98.33%)
used: 316.51 GiB (33.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 61.5 C mobo: 29.8 C gpu: amdgpu temp: 49.0 C
Processes: 321 Uptime: 6h 51m wakeups: 13 Memory: 31.28 GiB
used: 8.4 GiB (26.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1870 lib: 454 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.2.02
