Several weeks ago I installed and configured Manjaro and used it for awhile. After an update, I began to have problems logging in after I would lock the screen. I could use the eye icon to view my password and confirmed that it was correct, yet I could still not log in. A reboot would usually fix teh problem for a while, but eventually I decided I should reinstall the operating system.
I considered moving to a different distribution since I need a stable system that I know I’ll be able to get into after investing so much time getting everything setup the way I need it. I decided to give it another shot, so I’ve reinstalled Manjaro and spent several days getting everything set back up again. Yesterday, to my disappointment, the system locked me out again. This time it happened after a full logout, not just a lock screen, and the mouse won’t activate anything on the screen. I can no longer get into the system. I’ve rebooted multiple times to no affect. I need to understand what the problem is and find a solution that is permanent. Any ideas would be appreciated.
