Login loop with kde
Hello i havent Start manjaro For a few Days and kde stopped working when i log in with kde it go back to login screen and its like looping so i have to use gnome can someone help me with that?
Installing both Gnome and Plasma desktops together is not recommended or supported Iā€™m afraid.
However, simply not logging in or starting up Manjaro for a few days has absolutely no effect, so this problem existed when you shut down previously.
Can you restore a snapshot?
You can then pursue this further if you come up with some system info;
inxi -Farz
Sort your mirrors and sync and upgrade dance couldnt hurt;
sudo pacman-mirrors -f && sudo pacman -Syu
After which we may also look at foreign packages
pacman -Qmq
Your next line of action could be to create a new user to use with Plasma, separate from the user which uses Gnome.
Sure Heres My Sys infoCPU:
  Info: model: 13th Gen Intel Core i5-1335U bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 3 microcode: 0x4123
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
    st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
    KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 494 min/max: 400/4600:3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 494 2: 494 3: 494 4: 494 5: 494 6: 494 7: 494
    8: 494 9: 494 10: 494 11: 494 12: 494 bogomips: 59916
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb
    pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
    rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Packages: 2154 pm: pacman pkgs: 2136 libs: 438
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 18
    1: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    2: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    4: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    5: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    6: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    7: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    8: https://linorg.usp.br/manjaro/stable/$repo/$arch
Also The Cores and Thread are Wrong i have 10 Cores and 12 Thread
Mod edit to tidy up and reduce text spam
For your machine information:
inxi --admin --verbosity=8 --filter --no-host --width
:loudspeaker: Format for Legibility Tip
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Alternatively, select all pasted text, and click the </> button on the taskbar - which will indent the whole pasted section with one TAB, causing it to render the same way as described above.
We will await your edit.
Also, you should take time to read the following thread:
@ethan_123
Your System Information seems incomplete;
Please provide the full output of:
Definitely! I suspect Gnome settings changes in /home/$USER have messed up one(s) used by Plasma.
