I can’t seam to login into my pc the login screen keeps reseting and not leting me in.
It maybe is Pams foult with the new update, but i can’t tell because journalctl is confusing to me.
Welcome to the forum!
It is quite possible that you’ve been bitten by that.
Try booting up from the USB key or optical disk that you used for installing. Then, open up a terminal and issue the following command…
su -
Enter the password, and then issue the following command…
manjaro-chroot -a
Then you can look for any .pacnew
files under /etc/pam.d/
, and tend to them as needed.
When you’re done, just enter…
exit
systemctl reboot
there isn’t .pacnew file or any hiden .files in /etc/pam.d/
What about the obvious then, i.e. …
when put in a wrong password it tells me its wrong, but when its right the screen goes black for a second then the mouse apears and then its right back at the login screen.
I looked at the journalctl and its giving me errors from sddm, sddm-greeter and sddm-helper
saying
Qoblject: Cannot create childern for a parent that is in difreant thread
and other stuff like virtualkeybord plugin is not isntalt ext.
Could this have samthing to do as to why i cant load in to my system.
That is possible. Are you using apparmor
by any chance?
i have never used it. When i type aa-status it says:
apparmor module is loaded.
apparmor filesystem is not mounted.
I can’t check if ts running beacause chroot ignores the “systemctl status apparmor” command
Alright i tryied “systemctl status apparmor" again in the comand line at boot, heres what i got:
Loaded: loaded (/usr/lib/systemd/system/apparmor.service;enabled; vendor preset: disavled)
Active: Inactive (dead)
and aa-status has all zeros in frotn of profiles and processes
If I just copy paste all journalctl errors and ohter things i think might be relevent in here, would that be helpfull figuring out my problem?
I honestlly don’t know what else to do at this point.
It might at least shed a bit of light on the situation.
Loading file:///usr/share/sddm/themes/breath2/Main.qml...
sddm-greeter[1042]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffff0de1530), parent's thread is QThread(0x557ab9462cf0), current thread is QThread(0x557ab959a080)
sddm-greeter[1042]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
ModemManager[754]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.2/0000:20:01.0/0000:22:00.0': not supported by any plugin
ModemManager[754]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.2/0000:20:04.0/0000:25:00.0': not supported by any plugin
dbus-daemon[687]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.28' (uid=968 pid=1042 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-fCzZsd>
systemd[1]: Starting Disk Manager...
udisksd[1067]: udisks daemon version 2.9.0 starting
dbus-daemon[687]: [system] Successfully activated service 'org.freedesktop.UDisks2'
systemd[1]: Started Disk Manager.
audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
dbus-daemon[687]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.28' (uid=968 pid=1042 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-fCzZsd" >
audit: BPF prog-id=12 op=LOAD
audit: BPF prog-id=13 op=LOAD
systemd[1]: Starting Daemon for power management...
dbus-daemon[687]: [system] Successfully activated service 'org.freedesktop.UPower'
systemd[1]: Started Daemon for power management.
audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 05 16:21:00 sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/Main.qml:408:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>
Sep 05 16:21:00 sddm-greeter[1042]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:209:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instea>
Sep 05 16:21:00 sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/VirtualKeyboard.qml:22:1: Type InputPanel unavailable
Sep 05 16:21:00 sddm-greeter[1042]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Sep 05 16:21:00 sddm-greeter[1042]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Sep 05 16:21:00 sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/Login.qml:84:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>
Sep 05 16:21:00 udisksd[1067]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Sep 05 16:21:00 sddm-greeter[1042]: file:///usr/lib/qt/qml/org/kde/plasma/components/Button.qml:52: ReferenceError: PlasmaCore is not defined
Sep 05 16:21:00 sddm-greeter[1042]: Adding view for "HDMI-A-0" QRect(0,0 1920x1080)
Sep 05 16:21:00 sddm-greeter[1042]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.29'
Sep 05 16:21:00 sddm-greeter[1042]: Message received from daemon: Capabilities
Sep 05 16:21:00 sddm-greeter[1042]: Message received from daemon: HostName
Sep 05 16:21:01 systemd[1]: systemd-rfkill.service: Succeeded.
Sep 05 16:21:01 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 05 16:21:02 kernel: logitech-hidpp-device 0003:046D:4016.0005: HID++ 2.0 device connected.
Sep 05 16:21:03 z-ms7b89 upowerd[1082]: treating change event as add on /sys/devices/pci0000:00/0000:00:07.1/0000:29:00.3/usb3/3-1/3-1:1.2/0003:046D:C52B.0003/0003:046D:4016.0005/power_supply/hidpp_battery_0
Sep 05 16:21:04 sddm-greeter[1042]: <input>:406:376: Could not add child element to parent element because the types are incorrect.
Sep 05 16:21:04 sddm-greeter[1042]: <input>:407:126: Could not add child element to parent element because the types are incorrect.
Sep 05 16:21:04 sddm-greeter[1042]: <input>:408:126: Could not add child element to parent element because the types are incorrect.
Sep 05 16:21:04 sddm-greeter[1042]: <input>:408:385: Could not add child element to parent element because the types are incorrect.
Sep 05 16:21:04 sddm-greeter[1042]: <input>:409:125: Could not add child element to parent element because the types are incorrect.
Sep 05 16:21:04 sddm-greeter[1042]: <input>:410:124: Could not add child element to parent element because the types are incorrect.
Sep 05 16:21:04 sddm-greeter[1042]: <input>:411:125: Could not add child element to parent element because the types are incorrect.
Sep 05 16:21:04 sddm-greeter[1042]: <input>:411:371: Could not add child element to parent element because the types are incorrect.
Sep 05 16:21:04 sddm-greeter[1042]: <input>:411:619: Could not add child element to parent element because the types are incorrect.
Sep 05 16:21:04 sddm-greeter[1042]: Reading from "/usr/share/xsessions/plasma.desktop"
Sep 05 16:21:04 sddm[788]: Message received from greeter: Login
Sep 05 16:21:04 sddm[788]: Reading from "/usr/share/xsessions/plasma.desktop"
Sep 05 16:21:04 sddm[788]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11"
Sep 05 16:21:04 sddm-helper[1134]: [PAM] Starting...
Sep 05 16:21:04 sddm-helper[1134]: [PAM] Authenticating...
Sep 05 16:21:04 sddm-helper[1134]: [PAM] Preparing to converse...
Sep 05 16:21:04 sddm-helper[1134]: [PAM] Conversation with 1 messages
Sep 05 16:21:04 sddm-helper[1134]: pam_kwallet5(sddm:auth): (null): pam_sm_authenticate
Sep 05 16:21:04 audit[1134]: USER_AUTH pid=1134 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit acct="" exe="/usr/lib/sddm/sddm-helper" >
Sep 05 16:21:04 sddm-helper[1134]: [PAM] returning.
Sep 05 16:21:04 kernel: kauditd_printk_skb: 11 callbacks suppressed
Sep 05 16:21:04 kernel: audit: type=1100 audit(1599315664.100:68): pid=1134 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit acct="z" exe=>
Sep 05 16:21:04 audit[1134]: USER_ACCT pid=1134 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="z" exe="/usr/lib/sddm/sddm-hel>
Sep 05 16:21:04 sddm[788]: Authenticated successfully
Sep 05 16:21:04 sddm-greeter[1042]: Message received from daemon: LoginSucceeded
Sep 05 16:21:04 sddm-helper[1134]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Sep 05 16:21:04 audit[1134]: CRED_ACQ pid=1134 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit acct="z" exe="/usr/lib/sddm/sddm-helper" hostname>
Sep 05 16:21:04 kernel: audit: type=1101 audit(1599315664.104:69): pid=1134 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="">
Sep 05 16:21:04 kernel: audit: type=1103 audit(1599315664.104:70): pid=1134 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit acct="z" exe="/usr/l>
Sep 05 16:21:04 kernel: audit: type=1006 audit(1599315664.104:71): pid=1134 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Sep 05 16:21:04 sddm-helper[1134]: pam_unix(sddm:session): session opened for user z by (uid=0)
systemd[1]: Created slice User Slice of UID 1000.
systemd[1]: Starting User Runtime Directory /run/user/1000.
systemd-logind[695]: New session 2 of user
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/Main.qml:377: TypeError: Cannot read property 'smallSpacing' of null
sddm-greeter[1042]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/components/BatteryIcon.qml:42: TypeError: Cannot call method 'roundToIconSize' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/Battery.qml:27: TypeError: Cannot read property 'smallSpacing' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:55: TypeError: Cannot read property 'smallSpacing' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:34: TypeError: Cannot read property 'gridUnit' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:36: TypeError: Cannot read property 'largeSpacing' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:37: TypeError: Cannot read property 'smallSpacing' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:34: sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:36: TypeError: Cannot read property 'largeSpacing' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/ActionButton.qml:37: sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/SessionManagementScreen.qml:82: TypeError: Cannot read property 'gridUnit' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/SessionManagementScreen.qml:111: TypeError: Cannot read property 'smallSpacing' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/SessionManagementScreen.qml:97: TypeError: Cannot read property 'gridUnit' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/SessionManagementScreen.qml:98: TypeError: Cannot read property 'gridUnit' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/SessionManagementScreen.qml:88: TypeError: Cannot read property 'gridUnit' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/UserList.qml:25: TypeError: Cannot read property 'gridUnit' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/UserList.qml:26: TypeError: Cannot read property 'gridUnit' of null
sddm-greeter[1042]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:51: TypeError: Cannot read property 'iconSizes' of null
sddm-greeter[1042]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:114: TypeError: Cannot read property 'iconSizes' of null
audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
sddm-greeter[1042]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:49: TypeError: Cannot read property 'smallSpacing' of null
sddm-greeter[1042]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ButtonStyle.qml:96: TypeError: Cannot read property 'iconSizes' of null
sddm-greeter[1042]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ButtonStyle.qml:41: TypeError: Cannot read property 'smallSpacing' of null
sddm-greeter[1042]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/TextFieldStyle.qml:90: TypeError: Cannot read property 'iconSizes' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/UserDelegate.qml:39: TypeError: Cannot read property 'largeSpacing' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/UserDelegate.qml:70: TypeError: Cannot read property 'gridUnit' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/components/UserDelegate.qml:45: TypeError: Cannot read property 'longDuration' of null
sddm-greeter[1042]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/private/TextFieldFocus.qml:93: TypeError: Cannot read property 'longDuration' of null
sddm-greeter[1042]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/private/ButtonShadow.qml:130: TypeError: Cannot read property 'longDuration' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/Main.qml:226: TypeError: Cannot read property 'longDuration' of null
sddm-greeter[1042]: file:///usr/share/sddm/themes/breath2/Main.qml:382: TypeError: Cannot read property 'longDuration' of null
systemd[1]: Finished User Runtime Directory /run/user/1000.
systemd[1]: Starting User Manager for UID 1000...
I’ve edited your post to make it more readable. When inserting terminal output, then please use the </> button in the editor toolbar to format your post. It really makes a difference.
I went looking for pacnew files and i think they might be somthing importat
/etc/shadow.pacnew
/etc/fonts/fonts.conf.pacnew
/etc/security/limits.d/10-gcr.conf.pacnew
Delete /etc/shadow.pacnew
- if you overwrite your existing /etc/shadow
all your accounts passwords and related information will be lost.
Nop that didn’t fix it, still getting black screen when trying to log in
I probably should have mentioned that i used time shift to se if the bug was still there.
It is.
shadow.service: Failed with result 'exit-code'
That suggests that there’s a problem with logind
, and thus with systemd
I don’t know whether it’ll make a difference, but it could be related to systemd-homed
, which is new, and which I’ve masked on my system.
sudo systemctl disable --now systemd-homed.service
sudo systemctl mask systemd-homed.service
System has not been booted with systemd as init system (PID 1). Can't operate.
Failed to connect to bus: Host is down
Created symlink /etc/systemd/system/systemd-homed.service -> /dev/null.
this is what i got
