After the last update, my session freeze after login.
The desktop launches, I can see my desktop icons, the taskbar and some system popup message but after that everything is frozen. I still can move the mouse and I’m able to change user by using ctrl+alt+del.
I have other users configured that are using the default kde desktop config and I’m able to connect with them and use normally the session. It is only my session that freezes.
I tried with a console session (ctrl+alt+F2) the command “startx”, had the same behavior and after login out session, I had the message on console:
Did the X11 server die?The X11 connection broke (error 1).
Is there a way to reinitialize my kde config to the default one like the other users, or something I can do?
However I found out that yakuake console answers although the interface is frozen.
Using the Yakuake console, I’m even able to launch firefox and it runs normally.
I tired the following:
killall plasmashell
kstart5 plasmashell
and I had the following messages:
kf.plasma.quick: Applet preload policy set to 1
qt.svg: :303:258: Could not add child element to parent element because the types are incorrect.
qt.svg: :303:463: Could not add child element to parent element because the types are incorrect.
qt.svg: :303:659: Could not add child element to parent element because the types are incorrect.
qt.svg: :303:913: Could not add child element to parent element because the types are incorrect.
qt.svg: :303:1049: Could not add child element to parent element because the types are incorrect.
qt.svg: :303:1251: Could not add child element to parent element because the types are incorrect.
qt.svg: :303:1453: Could not add child element to parent element because the types are incorrect.
qt.svg: :303:1631: Could not add child element to parent element because the types are incorrect.
qt.svg: :303:1739: Could not add child element to parent element because the types are incorrect.
qt.svg: :303:1980: Could not add child element to parent element because the types are incorrect.
qt.svg: :303:2223: Could not add child element to parent element because the types are incorrect.
trying to show an empty dialog
file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:134:19: QML Loader: Binding loop detected for property “height”
Error: cannot change the containment to AppletsLayout
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:520:9: QML Label: Binding loop detected for property “height”
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:475:13: QML Label: Binding loop detected for property “height”
file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property “minimumWidth”
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:542:5: QML Label: Binding loop detected for property “height”
Cyclic dependency detected between “file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml” and “file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/Notificati
onHeader.qml”
libkcups: CUPS-Get-Printers last error: 0 successful-ok
libkcups: Create-Printer-Subscriptions last error: 0 successful-ok
libkcups: Get-Jobs last error: 0 successful-ok
Plasma Shell startup completed
file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:17:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property “minimumWidth”
Both point size and pixel size set. Using pixel size.
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:54:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property “minimumWidth”
libkcups: 3 “Canon_MG6800_series”
libkcups: 3 “MG6800-series”
libkcups: 0
libkcups: 0
QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
org.kde.plasma.pulseaudio: No object for name “alsa_output.pci-0000_0a_00.3.analog-stereo.monitor”
pamac update --force-refresh
Préparation…
Clonage des fichiers de construction de libretro-genesis-plus-gx-git…
Création des informations de libretro-genesis-plus-gx-git…
Vérification des dépendances de libretro-genesis-plus-gx-git…
Vérification des dépendances de libmagick6…
Clonage des fichiers de construction de teamviewer…
Création des informations de teamviewer…
Vérification des dépendances de teamviewer…
Synchronisation des bases de données des paquets…
Actualisation de core.db…
Actualisation de extra.db…
Actualisation de community.db…
Actualisation de multilib.db…
Actualisation de core.files…
Actualisation de extra.files…
Actualisation de community.files…
Actualisation de multilib.files…
Avertissement : manjaro-hello : la version locale (0.6.7-2) est plus récente que extra (0.6.6-9)
Résolution des dépendances…
Recherche des conflits entre paquets…
À construire (3):
libmagick6 6.9.12.29-1 (6.9.12.23-1) AUR
libretro-genesis-plus-gx-git 1868.c1c605e-1 (1859.22b60cd-1) AUR
teamviewer 15.23.9-1 (15.22.3-1) AUR
Éditer les fichiers de construction : [e]
Appliquer la transaction ? [e/o/N]
the 3 AUR packet gives me an error:
DPKGBUILD does not exist
but I don’t think it’s related to my issue.
After a while, the desktop started to respond normally, don’t have any idea why.
Some windows popped up, as if it had restored a previous session and then everything was normal and the interface was answering normally.
I have not rebooted yet to see if it behaves the same.
Hi, I have the same issue. The output of journalctl -p 3 -b is
Nov 28 07:43:22 kafka kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Nov 28 07:43:22 kafka kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Nov 28 07:43:22 kafka kernel: pci 0000:00:07.2: DPC: RP PIO log size 0 is invalid
Nov 28 07:43:22 kafka dhcpcd[337]: no valid interfaces found
Nov 28 07:43:23 kafka systemd-udevd[272]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
I didn’t find any fix, a long time after login it came back to life (maybe 1 or 2 hours).
As the other users didn’t have any issues, I switched the KDE theme to default in the settings.
