is it possible to change the value of the time, waiting to type in the password again, after one single failed attempt at log-in? I do not mean the amount of time waiting after too man bad login attempts.
And maybe it should be decreased for everyone.
Anyhow, how can I change it for me, at least?
Thank you for your quick responese, but no, that is not what I meant.
That value defines the amount of time, which the user must wait for, if he had too many bad attempts to log-in.
I just want to decrease the amount of time, after I typed in the password wrong once, but am unable to directly type in the password again. I need to wait almost two seconds. That feels too long.
Both do not work for me properly.
If I suspend my session or simply lock it, it takes longer than my desired seconds of 0.5.
Do you know even another solution?
