I’ve set the Display resolution to 1080p, however, every time Manjaro boots, the log-in screen loads with the 4K resolution.
Welcome to Manjaro!
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
Thanks Fabby!
I thought this was a known issue with High-DPI screens.
System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel
wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: N552VW v: 1.0 serial: <filter>
Mobo: ASUSTeK model: N552VW v: 1.0 serial: <filter> UEFI: American Megatrends v: N552VW.304 date: 05/08/2019
Battery: ID-1: BAT0 charge: 2.6 Wh condition: 30.9/47.5 Wh (65%) volts: 14.4/14.4 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: Charging cycles: 1328
Memory: RAM: total: 11.60 GiB used: 4.15 GiB (35.8%)
CPU: Topology: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S rev: 3 L2 cache: 6144 KiB
bogomips: 41621
Speed: 900 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 868 2: 874 3: 899 4: 894 5: 846 6: 884 7: 868 8: 891
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: ASUSTeK driver: nouveau v: kernel bus ID: 01:00.0
chip ID: 10de:139b
Device-3: Chicony HD WebCam (Asus N-series) type: USB driver: uvcvideo bus ID: 1-4:2 chip ID: 04f2:b3fd
serial: <filter>
Display: x11 server: X.Org 1.20.8 driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a170
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0 chip ID: 8086:095a
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
bus ID: 03:00.1 chip ID: 10ec:8168
IF: enp3s0f1 state: down mac: <filter>
IP v6: <filter> virtual: stable-privacy scope: link
Drives: Local Storage: total: 1.94 TiB used: 1.79 TiB (92.5%)
ID-1: /dev/sda vendor: Samsung model: MZNLF128HCHP-00004 size: 119.24 GiB speed: 6.0 Gb/s serial: <filter>
rev: 301Q scheme: GPT
ID-2: /dev/sdb vendor: Seagate model: ST2000LM003 HN-M201RAD size: 1.82 TiB speed: 6.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: 0001 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: AS00 dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 104.02 GiB used: 35.15 GiB (33.8%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 73036dd4-76d9-492e-ab0f-055ca28fa40e
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: A8D8-F352
ID-3: /run/media/xashyar/Audio size: 800.78 GiB used: 774.58 GiB (96.7%) fs: ntfs dev: /dev/sdb2 label: Audio
uuid: 149AF8339AF812CA
ID-4: /run/media/xashyar/Video size: 1.00 TiB used: 1021.96 GiB (99.8%) fs: ntfs dev: /dev/sdb3 label: Video
uuid: ECF0069FF0066FDE
Swap: ID-1: swap-1 type: partition size: 12.76 GiB used: 1.10 GiB (8.6%) priority: -2 dev: /dev/sda3 label: N/A
uuid: 866158db-e867-41da-b8af-91b73b6302cd
Unmounted: ID-1: /dev/sdb1 size: 128.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-2: /dev/sdb4 size: 37.69 GiB fs: ntfs label: Misc uuid: FAEA29D1EA298B49
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-4:2 info: Chicony HD WebCam (Asus N-series) type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 04f2:b3fd serial: <filter>
Device-2: 1-9:3 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:0a2a
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 47.0 C mobo: N/A gpu: nouveau temp: 43 C
Fan Speeds (RPM): cpu: 2100
Info: Processes: 356 Uptime: 4h 02m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1270 pacman: 1264 snap: 6
Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
You may be able to set it up in /etc/init/lightdm.conf
, but I have no experience with it, never even looked at this file.
Try installing slick-greeter and the settings package
sudo pacman -Syu lightdm-slick-greeter lightdm-settings
There is a couple of greeter themes as well but it is very easy to modify /etc/lightdm/slick-greeter.conf to use another wallpaper.
