I recently installed a new manjaro beside my vista install. I did it very easily from a manjaro 64bits version I have, even if my laptop is a 32 bit one; but this is not the issue .
I’m wondering how to overpass the identification stage as I’m the only user.
I tried by uncommenting the 3 autologin lines of the lightdm.conf without any success.
I tried also by copying .xinitrc into my home directory without success as well.
Any advice will be appreciated.
HI, I’m using majaro-arm XFCE on a Raspberry Pi 400 and have been doing everything in this thread and the archlinix wiki link posted by @maycne.sonahoz. When I try to enter the command
groupadd -r autologin
I get the following in terminal
groupadd: Permission denied.
groupadd: cannot lock /etc/group; try again later.
What do I do to get the command to work and not get the “Permission denied” message?
I did sudo like you said like you said and it worked. Now I have the issue of it stopping at the login screen and I have to hit return or click on login to continue How do I make it go directly to the main desktop?
Goto /etc/lightdm/lightdm.conf then go down till you see
#autologin-user-timeout=0
Remove the # and change 0 to 1 That will make it work. It won’t hide the login screen but it will auto execute an enter for you. If you leave it at 0 then it is off. Setting it to 1 will let it wait 1 second before loading the default user like it says in the comment in the file.
# autologin-user-timeout = Number of seconds to wait before loading default user
If 1 doesn’t work try setting it to 2
Also goto Applications (Manjaro button) → Settings → Manjaro Settings Manager → User Accounts → Your MAIN ACCOUNT (The account you normally login with) → Administrator (a small window will pop up labeled Account Type) → Check the box next to Show Groups → Check the box next to autologin → Click on the Apply button → Password window will popup, enter your password and press enter
