Does anyone know when/ if this bug is going to be fixed ? https://www.reddit.com/r/kde/comments/f2a3wr/unlock_widgets_kde_plasma_518/
It is very annoying not being able to (un)lock widgets without using a script each time.
Cheers
Neil
Cheers
Neil
When you right click on Desktop and go to Edit Mode aka Alt+A,D then the widgets are unlocked. When you Close the Edit Mode then the widgets are locked. The KDE Plasma developers took that decision quite some time ago, to change the behavior. The command in that redit brings back the legacy behavior.
Thanks for that - would have been nice if there was more info about that change around on the web as never saw anything about it prior to your post Thanks for the info anyway.
