Hello,
i’m experiencing this problem with Dolphin: big delay even for closing the app
System: Manjaro KDE fully updated with stable branch, Wayland, Intel GPU with open source drivers, no network shared mounted, 1 USB drive always mounted, no system suspension or hybernation configured.
Behaviour:
- when session starts, after system boot and SDDM login → Dolphin runs normally until the session is locked (manually or if timeout expires)
- after session locking → Dolphin becomes completely unusable, with a 30 secs delay for every operation performed, until logout.
- logout → Dolphin normal behaviour immediatly restored, until next session locking
Only Dolphin has the problem, every other KDE app or Plasma behaves normally even after session locking.
As a workaround, i’ve disabled completely session locking (home PC, security is not a problem (maybe… ), but would like to fix the root cause.
Any idea ? Some info here:
hostnamectl Static hostname: fujitsu
Icon name: computer-server
Chassis: server 🖳
Machine ID: 6d58c8d784a543e48de48cc977584765
Boot ID: 7fe4e9e89f914f87adf208afad7b062f
Kernel: Linux 5.19.0-3-rt10-MANJARO
Architecture: x86-64
Hardware Vendor: FUJITSU
Hardware Model: PRIMERGY TX1310 M3
Firmware Version: V5.0.0.11 R1.29.0 for D3521-A1x
Kernel: 5.19.0-3-rt10-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: root="UUID=91e2b4dc-f17a-4f58-9199-180c75043a93" rw reboot=efi
vt.global_cursor_default=0 loglevel=3 udev.log-priority=3 splash
usbcore.autosuspend=5 audit=0 preempt=full
Console: pty pts/2 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Server System: FUJITSU product: PRIMERGY TX1310 M3 v: N/A
serial: <filter> Chassis: type: 17 v: TX1310M3 serial: <filter>
Mobo: FUJITSU model: D3521-A1 v: S26361-D3521-A13 serial: <filter>
UEFI: FUJITSU // American Megatrends v: 5.0.0.11 R1.29.0 for D3521-A1x
date: 12/22/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
status: discharging
RAM: total: 39.01 GiB used: 2.53 GiB (6.5%)
Array-1: capacity: 64 GiB slots: 4 EC: Single-bit ECC
Device-1: DIMM CHA3 type: DDR4 detail: synchronous size: 8 GiB
speed: 2400 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 72 manufacturer: SK Hynix part-no: HMA81GU7AFR8N-UH
serial: <filter>
Device-2: DIMM CHA1 type: no module installed
Device-3: DIMM CHB4 type: DDR4 detail: synchronous size: 16 GiB
total: 72 manufacturer: 0000 part-no: N/A serial: <filter>
Device-4: DIMM CHB2 type: DDR4 detail: synchronous size: 16 GiB
Info: model: Intel Xeon E3-1225 v6 bits: 64 type: MCP arch: Kaby Lake
level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1569 high: 3300 min/max: 800/3700 base/boost: 3300/3700
scaling: driver: intel_pstate governor: powersave volts: 1.0 V
ext-clock: 100 MHz cores: 1: 1000 2: 978 3: 3300 4: 1000 bogomips: 26399
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
disabled
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling
Device-1: Intel HD Graphics P630 vendor: Fujitsu Solutions driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-2 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:591d class-ID: 0300
Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
alternate: fbdev,vesa dri: iris gpu: i915 tty: 111x32
Monitor-1: HDMI-A-2 model: LG (GoldStar) 2D FHD TV serial: <filter>
built: 2017 res: 1920x1080 dpi: 96 gamma: 1.2 size: 509x286mm (20.04x11.26")
diag: 584mm (23") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Message: GL data unavailable in console for root.
Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 1102:0012 class-ID: 0403
Sound API: ALSA v: k5.19.0-3-rt10-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.58 running: yes
Device-1: Intel Ethernet I219-LM vendor: Fujitsu Solutions driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: host132 state: down mac: <filter>
IF-ID-3: nat122 state: down mac: <filter>
IF-ID-4: phys0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
IF-ID-5: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
Device-1: VG: os type: LVM2 size: 1.32 TiB free: 0 KiB
LV-1: root maj-min: 253:1 type: linear dm: dm-1 size: 1.32 TiB
Components:
c-1: md126p6 maj-min: 259:5 size: 1.32 TiB
LV-2: swap maj-min: 253:0 type: linear dm: dm-0 size: 512 MiB
Components:
Hardware-1: Intel Q170/H170/Z170/CM236 SATA Controller [RAID Mode]
driver: ahci v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:a106 rev: N/A
class-ID: 0104
Supported mdraid levels: raid0
Device-1: md126 maj-min: 9:126 type: mdraid level: raid-0 status: active
state: clean size: 1.82 TiB
Info: report: N/A blocks: 1949216768 chunk-size: 64k
Components: Online:
0: sdd maj-min: 8:48 size: 465.76 GiB state: active sync
1: sdc maj-min: 8:32 size: 465.76 GiB state: active sync
2: sdb maj-min: 8:16 size: 465.76 GiB state: active sync
3: sda maj-min: 8:0 size: 465.76 GiB state: active sync
Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 4329568 chunk-size: N/A
Components: Online: N/A Spare:
0: sdd maj-min: 8:48 size: 465.76 GiB state: S
1: sdc maj-min: 8:32 size: 465.76 GiB state: S
2: sdb maj-min: 8:16 size: 465.76 GiB state: S
3: sda maj-min: 8:0 size: 465.76 GiB state: S
Local Storage: total: raw: 2.73 TiB usable: 927.38 GiB used: 270.3 GiB
(29.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1B6Q temp: 24 C
SMART: yes state: enabled health: PASSED on: 324d 0h cycles: 1091
written: 5.11 TiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 3B6Q temp: 24 C
SMART: yes state: enabled health: PASSED on: 322d 22h cycles: 1091
written: 4.97 TiB Pre-Fail: reallocated sector: 98 threshold: 10
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
rev: 3B6Q temp: 26 C
written: 5.05 TiB
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 860 EVO 500GB
rev: 1B6Q temp: 26 C
written: 5.05 TiB
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Seagate
model: ST1000LM 014-1EJ164 drive model: ST1000LM014-1EJ164
family: Laptop SSHD size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> drive serial: <filter> rev: SM36 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 40d 19h cycles: 1311
Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUD0N rev: PF02
dev-links: cdrom
ID-1: / raw-size: 1.32 TiB size: 1.3 TiB (98.35%) used: 270.23 GiB (20.3%)
fs: ext4 block-size: 4096 B dev: /dev/dm-1 maj-min: 253:1 mapped: os-root
label: N/A uuid: N/A
ID-2: /boot/efi raw-size: 2 GiB size: 1.99 GiB (99.80%) used: 73.9 MiB
(3.6%) fs: vfat block-size: 512 B dev: /dev/md126p1 maj-min: 259:0
label: N/A uuid: C1D0-9D5C
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 512 MiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-0 maj-min: 253:0 mapped: os-swap label: swap
uuid: 2f7555d0-ed5c-42e2-bf52-5a0b99820e6d
ID-1: /dev/md126p2 maj-min: 259:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/md126p3 maj-min: 259:2 size: 501.11 GiB fs: ntfs label: N/A
uuid: 1E1061A41061841D
ID-3: /dev/md126p4 maj-min: 259:3 size: 630 MiB fs: ntfs label: N/A
uuid: 04A03B41A03B390E
ID-4: /dev/md126p5 maj-min: 259:4 size: 559 MiB fs: ntfs label: N/A
uuid: EA8AD6F58AD6BCEF
ID-5: /dev/sde1 maj-min: 8:65 size: 931.51 GiB fs: ext4 label: N/A
uuid: 2b59b0d5-8153-4309-aa80-ced408f816a6
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Device-1: 2-6:3 info: VIA Labs VL817 SATA Adaptor type: Mass Storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 8mA
chip-ID: 2109:0715 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 33.0 C pch: 38.5 C mobo: N/A
Processes: 238 Uptime: 5h 15m wakeups: 28 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 11
clang: 14.0.6 Packages: pm: pacman pkgs: 2185 libs: 485 tools: yay
pm: flatpak pkgs: 0 Shell: Zsh (su) v: 5.9 running-in: pty pts/2
inxi: 3.3.22
