When i let computer go into lock screen and then i have to enter the password sometimes the keyboard is locked and the only way is through the virtual keyboard.
Is it why there’s a virtual keyboard available? Is it supposed that happens?
no - that should not happen. Which system, which desktop enviroment? Is it a build in keyboard or USB? (or even PS/2 still)?
inxi -Fazy
Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=3e2010a7-c97f-4294-b887-2952e34fc467 rw quiet pci=nomsi,noaer
loglevel=3 rd.systemd.show_status=auto rd.udev.log_priority=3 touch
~/.hushlogin
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 81F5 v: 66.25 serial: <filter> UEFI [Legacy]: Insyde v: F.09
date: 05/19/2016
ID-1: BAT1 charge: 33.9 Wh condition: 33.9/33.9 Wh (100%) volts: 16.9/14.8
model: 111-83-72 HS04041 type: Unknown serial: <filter> status: Full
Topology: Quad Core model: AMD A6-7310 APU with AMD Radeon R4 Graphics
bits: 64 type: MCP arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1
microcode: 7030105 L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 15974
Speed: 1001 MHz min/max: 1000/2000 MHz boost: enabled Core speeds (MHz):
1: 1041 2: 998 3: 1005 4: 998
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu bus ID: 00:01.0
chip ID: 1002:9851
Device-2: Microdia HP Webcam type: USB driver: uvcvideo bus ID: 2-1.1:3
chip ID: 0c45:651b serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: radeon
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.8.3-2-MANJARO LLVM 10.0.1)
v: 4.5 Mesa 20.1.6 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:01.1 chip ID: 1002:9840
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus ID: 00:14.2 chip ID: 1022:780d
Sound Server: ALSA v: k5.8.3-2-MANJARO
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel port: 3000
bus ID: 02:00.0 chip ID: 10ec:b723
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 2000 bus ID: 03:00.0 chip ID: 10ec:8136
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 818.89 GiB used: 138.15 GiB (16.9%)
ID-1: /dev/sda vendor: Samsung model: MZNTY256HDHP-000H1 size: 238.47 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 1H3Q scheme: MBR
ID-2: /dev/sdb type: USB vendor: SanDisk model: Cruzer Blade
size: 114.66 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00 scheme: MBR
ID-3: /dev/sdc type: USB vendor: Toshiba model: MK5059GSXP size: 465.76 GiB
block size: physical: 512 B logical: 512 B rotation: 5400 rpm
serial: <filter> rev: GN00 scheme: MBR
ID-1: / raw size: 170.63 GiB size: 166.95 GiB (97.84%)
used: 138.15 GiB (82.7%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 48.0 C mobo: 20.0 C gpu: radeon temp: 48 C
Processes: 200 Uptime: 1h 29m Memory: 3.31 GiB used: 1.57 GiB (47.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1531 pacman: 1525
lib: 453 flatpak: 6 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
