Localsearch-3 seems to have gone berserk after 2026-05-02 Stable update
The update went well, thanks developers!
The only problem I have is that the localsearch-3 seems to be gone berserk. It has been churning for 5 hours at 100% on all CPUs, even though the localsearch status shows the indexer is idle.
Summary
My system is pretty standard GNOME:
CPU: 8-core AMD Ryzen 9 5900HX with Radeon Graphics (-MT MCP-)
speed/min/max: 3494/423/4683 MHz Kernel: 6.18.26-1-MANJARO x86_64 Up: 3h 4m
Mem: 9.72/30.77 GiB (31.6%) Storage: 3.64 TiB (50.4% used) Procs: 489
Shell: Zsh inxi: 3.3.40
inxi -v3
inxi -v3
  Host: ramoth Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 15.2.1
  Desktop: GNOME v: 50.1 Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: N/A model: HX90 serial: <superuser required>
    Firmware: UEFI vendor: American Megatrends LLC. v: 5.19 date: 10/11/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
    charge: 55% (should be ignored) status: discharging
  Info: 8-core model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
  Speed (MHz): avg: 3551 min/max: 423/4683 boost: enabled cores: 1: 3551
    2: 3551 3: 3551 4: 3551 5: 3551 6: 3551 7: 3551 8: 3551 9: 3551 10: 3551
    11: 3551 12: 3551 13: 3551 14: 3551 15: 3551 16: 3551 bogomips: 105405
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
    ssse3 svm
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 bus-ID: 04:00.0
    temp: 71.0 C
  Device-2: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
    type: USB bus-ID: 1-2.1:4
    compositor: gnome-shell driver: X: loaded: amdgpu
    unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu resolution:
    1: 2560x1440~60Hz 2: 1920x1080~60Hz
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
    renoir ACO DRM 3.64 6.18.26-1-MANJARO)
  Info: Tools: api: clinfo, eglinfo, glxinfo x11: xprop,xrandr
  Device-1: Intel Ethernet I225-V driver: igc v: kernel port: N/A
    bus-ID: 02:00.0
  IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 1c:83:41:29:f5:5a
  Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel
    bus-ID: 03:00.0
  IF: wlp3s0 state: down mac: 72:63:bc:a7:92:8e
  IF-ID-1: gpd0 state: down mac: N/A
  Local Storage: total: 3.64 TiB used: 1.83 TiB (50.4%)
  Memory: total: 32 GiB note: est. available: 30.77 GiB used: 9.76 GiB (31.7%)
  Processes: 485 Uptime: 3h 2m Init: systemd
  Packages: 2449 Compilers: clang: 22.1.3 gcc: 15.2.1 Shell: Zsh v: 5.9
    inxi: 3.3.40
Ok. It seems that after a reboot, it churned again at high CPU around ten minutes, and then it stopped and started behaving.
Surprising.
If the database is broken, try to reset it:
localsearch  reset -s
