Localize Manjaro
Locale and Keyboard Layouts
The locale is all the settings related to localization, like GUI/applications language, time, currency etc. In Manjaro you can set the preferred locale settings using Manjaro Settings Manager GUI application. Sometimes, because of complicated setups and often after some user mistakes, you might not be able to have the correct settings for each user. Below you will see how you can check and set properly your configuration manually.
Keyboard layouts are treated separately from the locale configuration and are divided in GUI (Xorg) and Console, although they are controlled by one utility, localectl(in systemd installations).
In Linux systems all locales are available for installation, they just need to be enabled and generated. The settings are configured initially system-wide, but it is possible to override them per user-session.
System locale
Check your current system settings (type in terminal)
 locale
Check which are already available for usage (generated)
 locale -a
Example output :
$ locale -a
C
el_GR.utf8
en_US.utf8
POSIX
If your locale is not listed, you must edit /etc/locale.gen and uncomment yours.
# zh_SG.UTF-8 UTF-8
# zh_TW BIG5
# zh_TW.EUC-TW EUC-TW
zh_TW.UTF-8 UTF-8
# zu_ZA ISO-8859-1
You may want to uncomment all the variations of your country code "zh_TW" to use them as fallbacks for some programs they might use them. Then, generate them with this command
sudo locale-gen
Now you can set the system locale with this
sudo localectl set-locale LANG=zh_TW.UTF-8
The setting is saved in the system file /etc/locale.conf.
 LANG=zh_TW.UTF-8
If all preferred locale various settings consist of the same value, you only need LANG set.
If there are different values, you need to add only the different than LANG value.
Here is a sample
 LANG=zh_TW.UTF-8
 LANGUAGE=zh_TW:en_AU
 LC_ADDRESS=en_AU.UTF-8
 LC_IDENTIFICATION=en_AU.UTF-8
 LC_MEASUREMENT=en_AU.UTF-8
 LC_MONETARY=en_AU.UTF-8
 LC_MESSAGES=zh_TW.UTF-8
 LC_NAME=en_AU.UTF-8
 LC_NUMERIC=en_AU.UTF-8
 LC_PAPER=en_AU.UTF-8
 LC_TELEPHONE=en_AU.UTF-8
 LC_TIME=en_AU.UTF-8
The LANGUAGE parameter maybe read by some applications for translations. It's format is a little different than the rest. It works in a way of a fallback language list, meaning you can add more than one language code, separated by a semi-colon (;).
User locale
The system locale settings can be overridden for a user that wants a different setting variation, by creating (or editing if it already exists) this file
$HOME/.config/locale.conf
Add any user specific locale settings as bellow.
LANG=zh_TW.UTF-8
LC_CTYPE=zh_TW.UTF-8
Important!
If you need to change the basic LANG parameter value, you need to unset LANG first. This can be gracefully done by adding in $HOME/.xprofilethis:
unset LANG
source /etc/profile.d/locale.sh
Special input methods
While I am not proficient on this subject, you may add/set any required (from some relevant tutorial) parameters in $HOME/.xprofile with the export command.
export XMODIFIERS=@im=gcin
export GTK_IM_MODULE=gcin
export QT_IM_MODULE=gcin
export XIM_MODULE=gcin
Console fonts
The file /etc/vconsole.conf holds information on your keyboard layout and the font displayed in the TTY - the physical console.
Find available fonts and keymaps for your language (example for Greek):
ls -1 /usr/share/kbd/consolefonts | grep gr
ls -1 /usr/share/kbd/keymaps/i386/qwerty | grep gr
Tip (Archwiki): For European based languages written in Latin/Greek letters you can use eurlatgr font, it includes a broad range of Latin/Greek letter variations as well as special characters.
Here is a sample setup for danish keyboard and the Terminus font.
KEYMAP=dk
FONT=ter-118n
Non-English Keyboard Layouts
If you are using non-default settings or non-English layout for your Keyboard, use this command without sudo, changing to your preferred layouts (check here)
localectl --no-convert set-x11-keymap us,gr pc105 , grp:alt_shift_toggle
The above example is for English-Greek standard layouts, with Alt+Shift swithing. For selecting your options use the below commands
localectl list-x11-keymap-models, list-x11-keymap-layouts,  \
          list-x11-keymap-variants [LAYOUT], list-x11-keymap-options
[Man-page] List available X11 keymap models, layouts, variants and options, useful for configuration with set-keymap. The command list-x11-keymap-variants optionally takes a layout parameter to limit the output to the variants suitable for the specific
layout.
An alternative command/method is this, which you may add it to a session autostart mechanism.
setxkbmap -model pc104 -layout us,gr -variant , option grp:alt_shift_toggle
Read man setxkbmap for detailed instructions.
Permanent user settings
A problem may happen with Suspend/Sleep (depending your session/DE), because during sleep, X stops and starts on wake up again. To avoid such issues, it may help to make the settings permanent for your user account, by adding that command in your home folder ~/.xinitrc (or ~/.xprofile).
In a real multi-user system with several user locales, this should be applied at /etc/skel/.xinitrc (or .xprofile), so that every new user has individual session settings.
In systems where these settings are the same for all accounts, it is sufficient to run the localectl command once, which writes the settings in /etc/X11/xorg.conf.d/00-keyboard.conf
Other Considerations (i.e. DM, DE...)
Manjaro Settings Manager (MSM)
MSM has a Language (Locale Settings) configuration section, which affects system-wide environment variables. It edits /etc/locale.conf with at least (for the Greek locale)
LANG=el_GR.UTF-8
MSM-Locale
and with any custom settings per type, selected in the Detailed Settings tab
On the above example, this is the result:
LANG=el_GR.UTF-8
LC_TIME=en_US.UTF-8
LC_COLLATE=en_US.UTF-8
Plasma
Plasma uses its own locale files on user session. You can easily override system settings, using the System Settings ==> Regional Settings module.
  • Create your preferred language in the Language tab.
  • Add more languages, if you need them.
  • Set the preferred order
  • Fine-tune specific settings, as well. In the Format tab, you may specify a region that matches your need for the below settings (Numbers, Time etc), and/or enable Detailed Settings, to change specific options
  • Logout and login to see the changes.
Plasma creates/edits two files to adapt your custom/user settings. For the above example, this is the result:
==> ~/.config/plasma-locale-settings.sh
export LC_NUMERIC=el_GR.UTF-8
export LC_TIME=el_CY.UTF-8
export LC_MONETARY=el_GR.UTF-8
export LC_MEASUREMENT=el_GR.UTF-8
export LC_COLLATE=C
export LANGUAGE=el:en_US
==> ~/.config/plasma-localerc
[Formats]
LC_COLLATE=C
LC_TIME=el_CY.UTF-8
useDetailed=true
[Translations]
LANGUAGE=el:en_US
Note to TLP3 members-experienced users: Please add your findings about how DMs and DEs handle locale and keyboard layout configuration here
Troubleshooting
If you have followed the above guide and still have issues, there are possibilities of other files conflicting. Xorg, GDM and Plasma may have overriden your settings. The Archlinux wiki for Locale and Keyboard Layout is alawys the more updated place to look for a solution and of course the Manjaro Forum is always the more welcoming community.
Archlinux wiki is an ultimate source of Linux related information.
Just remember that Arch is not Manjaro so please ask Manjaro questions in the Manjaro forum.
References
Arch Linux Wiki - Locale, Xprofile, Keyboard Configuration in Xorg
Manjaro Forum Topics [1] [2]
This guide was originally written at wiki.manjaro.org and extended in time.
Locale issue with XFCE
Locale issues
Default locale not set properly?
Manjaro KDE Login Screen vs Kubuntu Login Screen
Keyboard layouts not switching after suspend
Awesome & locale default settings
Major locale settings problem!
Keybord Layouts
Locale setup by user question
I have problem with login manjaro
Firefox not showing Georgian unicode fonts correctly
Dvorak Keyboard on Lockscreen & after - Deepin Desktop
KDE: locales messed up
Unable to uninstall language pack
Different languages on system
Strange Swedish localization
Gedit cyrillic
Bumblebee/Nvidia - problem
Remember keyboard layout
Manjaro suddenly changed language
Xfce - Locale not properly set (solved)
changing the Keyboard Layout but Unilaterally
KDE forgets keyboard layout settings after reboot
[SOLVED] Permanently change Keyboard layout
[SOLVED] Configuring locales (language in system information)
Cannot add or remove languages
Multiple locales in manjaro-architect
Laptop after update can't login because keymap doesn't match
Can't login due to keyboard input changed to japanase accidentally
[SOLVED] Something is wrong with my locale.
Locale not supported by C library
Locale - Groundhog day...
Deepin: users with different ui languages
Reinstalling locale does not work
A Question about Locales
Switching system language bug
Can't change language from English to Romanian
Input Thai language and switch the languages?
Konsole LANG (locale) wrong
Default locale
Can't login after changing keyboard model in settings
Cannot change the keyboard in the setting manager (Archetict with i3)
How do I add a second language to type in, and preferably set a keyboard shortcut to switch between them?
Keyboard Configuration for non-English Layouts is added.
I would personally appreciate any contribution on Kbd Layout related issues and experience, since it is future proofing and welcoming international users.
Thanks.
i will add this
Set language for user session
For display managers that use AccountsService the locale for the user session can be set by editing:
/var/lib/AccountsService/users/$USER
[User] Language= your_locale
Do you know in which order the system finds and uses locale settings?
I have been investigating a little. It seems confusing…
depends on
systems & users on boot
locale & localectl
Xorg / FreeDesktop
displays manager ( for login )
.xprofile or .bashrc or .xinitrc if you put EXPORT
see this
https://wiki.archlinux.fr/locale
–> with locale-check.sh
Yes, I know this, is one of them :robot::space_invader::japanese_goblin:
Now I need the rest, xinit, DEs, they need to get in order though…
I study. It’s a long process for my skills… :paw_prints:
I have edited the guide for clarity and added some important info about user-specific locale configuration.
