Little question to yakuake
Hello together,
now I am a proud owner of a brandnew Tuxedo Pulse 15 - gen 1 laptop.
I Installed manjaro KDE. All works without problems.
But one little problem I see:
With every login starts yakuake with an open console so I have to close them every time.
Where can I tell yakuake to start in closed mode? I can’t find this option.
System:    Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.4 Distro: Manjaro Linux
Machine:   Type: Laptop System: TUXEDO product: TUXEDO Pulse 15 Gen1 v: Standard serial: <filter>
           Mobo: TUXEDO model: PULSE1501 v: Standard serial: <filter> UEFI: American Megatrends v: N.1.07.A02 date: 12/08/2020
Battery:   ID-1: BAT0 charge: 90.7 Wh condition: 91.6/91.6 Wh (100%)
CPU:       Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP L2 cache: 4 MiB
           Speed: 1397 MHz min/max: 1400/2900 MHz Core speeds (MHz): 1: 1397 2: 1397 3: 1398 4: 1396 5: 1397 6: 1397 7: 1397
           8: 1393 9: 1397 10: 1397 11: 1397 12: 1397 13: 1397 14: 1397 15: 1397 16: 1392
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
           Device-2: Chicony HD Webcam type: USB driver: uvcvideo
           Display: x11 server: X.Org 1.20.10 driver: amdgpu,ati unloaded: modesetting resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.2-2-MANJARO LLVM 11.0.0) v: 4.6 Mesa 20.3.1
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel
           Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
           Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
           Sound Server: ALSA v: k5.10.2-2-MANJARO
Network:   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
Drives:    Local Storage: total: 232.89 GiB used: 19.42 GiB (8.3%)
           ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M8250G size: 232.89 GiB
Partition: ID-1: / size: 219.86 GiB used: 19.42 GiB (8.8%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: /boot/efi size: 511 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap:      ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
Sensors:   System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 32.0 C
Info:      Processes: 310 Uptime: 12m Memory: 7.26 GiB used: 1.48 GiB (20.3%) Shell: Bash inxi: 3.2.01
regards
caho
I think this could happen if yakuake is started twice. Like if it is in autostart AND a previous session is restored.
Check your preferences for "desktop session" or “session manager” and be sure to choose "Start with an empty session" instead of “Restore previous session”. Or exclude yakuake from apps to be restored in that very same place. Or remove yakuake as an autostart application. Plenty of choice.
Thank you, @Signalrunner,
yakuake was in autostart and now I have changed my settings to “start with empty session”.
regards
caho
