Linux614 (6.14.4-1) Missing amdkfd.ko Module - Prevents ROCm GPU Compute
Affected Package: linux614
Package Version: 6.14.4-1
Architecture: x86_64
Manjaro Branch: Stable
Description:
The linux614 kernel package (version 6.14.4-1) does not include the amdkfd.ko kernel module. This module is essential for enabling ROCm (Radeon Open Compute platform) and allowing AMD GPUs to be used for compute tasks. Its absence prevents userspace ROCm libraries and applications (such as Ollama with GPU acceleration, PyTorch/TensorFlow on ROCm, etc.) from detecting or utilizing compatible AMD GPUs for compute.
Steps to Reproduce:
  1. Install the linux614 kernel (version 6.14.4-1).
  2. Boot into the linux614 kernel.
  3. Verify the absence of the amdkfd.ko module:
  • lsmod | grep kfd (shows no output)
  • sudo modprobe amdkfd (results in modprobe: FATAL: Module amdkfd not found in directory /lib/modules/6.14.4-1-MANJARO)
  • find /lib/modules/6.14.4-1-MANJARO/ -name “amdkfd.ko*” (shows no output)
  1. Confirm the module is not listed as part of the installed package:
  • pacman -Ql linux614 | grep amdkfd (shows no output)
  • pacman -Ql linux614 | grep amdgpu (shows amdgpu.ko.zst is present, but no amdkfd.ko.zst)
Expected Behavior:
The linux614 kernel package should include the amdkfd.ko.zst module as part of the amdgpu driver, typically located in /usr/lib/modules/$(uname -r)/kernel/drivers/gpu/drm/amd/amdgpu/. This module should load (either automatically or manually via modprobe amdkfd) to enable ROCm GPU compute functionality.
Actual Behavior:
The amdkfd.ko.zst module is missing from the linux614 package and the installed kernel modules directory. Attempts to load it fail, and ROCm-dependent applications cannot use the GPU for compute, falling back to CPU or failing to detect compatible devices. For example, rocminfo fails to properly enumerate compute capabilities, often with HSA_STATUS_ERROR_OUT_OF_RESOURCES or similar errors if amdkfd is not available.
Hardware:
  • CPU: AMD Ryzen 5800XT
  • GPU: AMD Radeon RX 6700 XT (gfx1031)
System Information:
  • uname -r: 6.14.4-1-MANJARO
  • Output of pacman -Qi linux614:
Version : 6.14.4-1
Description : The Linux 6.14 kernel and modules
Architecture : x86_64
URL : https://www.kernel.org/
Licenses : GPL-2.0-only
Groups : None
Provides : linux=6.14.4 KSMBD-MODULE VIRTUALBOX-GUEST-MODULES WIREGUARD-MODULE
Depends On : coreutils initramfs kmod
Optional Deps : wireless-regdb: to set the correct wireless channels of your country [installed]
linux-firmware: firmware images needed for some devices [installed]
Required By : linux614-virtualbox-host-modules
Optional For : base
Conflicts With : None
Replaces : virtualbox-guest-modules wireguard
Installed Size : 146.02 MiB
Packager : Manjaro Build Server build@manjaro.org
Build Date : Sat 26 Apr 2025 01:52:09 AM EDT
Install Date : Wed 14 May 2025 12:35:11 PM EDT
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
Any help is appreciated, happy to follow up with any additional details. Thank you
What is the source of your information?
It may be too old …
That module is not present in any kernel I have looked at
linux510, linux612
Also not in my Mint installation, which runs kernel 6.8
Thanks for the follow-up. I was expecting that amdkfd.ko would be included with the amdgpu driver because it’s needed for the ROCm compute stack. The amdkfd.ko module is essential for ROCm userspace libraries to interface with AMD GPUs. Upstream kernel development includes amdkfd as a configurable part of the amdgpu driver (via CONFIG_DRM_AMDGPU_KFD), and including it is a common practice for distributions aiming to provide out-of-the-box ROCm support.
Regarding other distributions or kernel versions, while some like Ubuntu may also leverage DKMS packages (e.g., rocm-dkms from AMD’s repositories) to provide amdkfd, this is an alternative mechanism to ensure its availability. If Manjaro’s older kernel packages (linux510, linux612) also omit amdkfd.ko, it probably reflects a consistent packaging decision for those series. However, unlike distributions that readily offer official DKMS solutions, Manjaro users are then left without a straightforward path to enable ROCm if the module isn’t in the primary kernel package.
The core issue is that the current linux614 package, by omitting amdkfd.ko, prevents ROCm functionality. Incorporating amdkfd.ko into the linux614 package by enabling the relevant kernel configuration option during the build process seems to be the most direct solution, and I’ve tried pretty hard already to find a better one. Do you know of a package that might be able to help? I haven’t been able to find one, but I’m willing to try to create it if that’s what’s needed.
I am just wondering if one or more of these packages might do the job: rocm-opencl-runtime, rocm-opencl-sdk, opencl-amd (AUR)
pamac info rocm-opencl-runtime rocm-opencl-sdk opencl-amd
Version               : 6.3.3-1
Description           : OpenCL implementation for AMD
URL                   : https://github.com/ROCm/clr
Licenses              : MIT
Repository            : extra
Installed Size        : 2.7 MB
Groups                : --
Depends On            : rocm-core hsa-rocr comgr mesa glibc gcc-libs numactl
                        opencl-icd-loader opencl-headers
Optional Dependencies : --
Provides              : opencl-driver
Replaces              : --
Conflicts With        : --
Packager              : Torsten KeĂźler <tpkessler@archlinux.org>
Build Date            : Sun 23 Mar 2025 01:19:48
Validated By          : MD5 Sum  SHA-256 Sum  Signature
Version               : 6.3.3-1
Description           : Develop OpenCL-based applications for AMD platforms
URL                   : https://rocm.docs.amd.com/en/latest/
Licenses              : LicenseRef-None
Repository            : extra
Groups                : --
Depends On            : rocm-core hsa-rocr rocm-opencl-runtime
Provides              : --
Replaces              : --
Conflicts With        : --
Build Date            : Tue 25 Mar 2025 03:46:10
Version               : 1:6.4.0-1
Description           : ROCm components repackaged from AMD's Ubuntu releases (ROCr
                        runtime, ROCm runtime, HIP runtime) - This package is
                        intended to work along with the free amdgpu stack.
URL                   : http://www.amd.com
Licenses              : custom:AMD
Repository            : AUR
Groups                : --
Depends On            : libdrm ocl-icd gcc-libs numactl
Optional Dependencies : clinfo [Installed]
                        opencl-amd-dev
Make Dependencies     : wget
Check Dependencies    : --
Provides              : opencl-driver libdrm-amdgpu-amdgpu1 rocm-core comgr hip hipcc
                        hip-dev hip-doc hip-samples hsa-rocr hsa-rocr-dev rocminfo
                        hip-runtime-amd rocm-device-libs rocm-language-runtime
                        rocm-hip-runtime rocdecode rocdecode-dev rocjpeg rocjpeg-dev
                        rocm-ocl-icd rocm-opencl-icd-loader rocm-opencl
                        rocm-opencl-dev rocm-opencl-runtime rocm-dbgapi
                        rocm-debug-agent rocm-gdb rocprofiler rocprofiler-dev
                        rocprofiler-plugins rocprofiler-register roctracer
                        roctracer-dev hsa-amd-aqlprofile openmp-extras-runtime
                        rocm-cmake rocm-utils rocm-smi-lib amd-smi-lib
Replaces              : --
Conflicts With        : rocm-opencl-runtime libdrm-amdgpu-amdgpu1 rocm-core comgr hip
                        hipcc hip-dev hip-doc hip-samples hsa-rocr hsa-rocr-dev
                        rocminfo hip-runtime-amd rocm-device-libs
                        rocm-language-runtime rocm-hip-runtime rocdecode
                        rocdecode-dev rocjpeg rocjpeg-dev rocm-ocl-icd
                        rocm-opencl-icd-loader rocm-opencl rocm-opencl-dev
                        rocm-dbgapi rocm-debug-agent rocm-gdb rocprofiler
                        rocprofiler-dev rocprofiler-plugins rocprofiler-register
                        roctracer roctracer-dev hsa-amd-aqlprofile
                        openmp-extras-runtime rocm-cmake rocm-utils rocm-smi-lib
                        amd-smi-lib
Maintainer            : sperg512
First Submitted       : Thu 01 Dec 2016 14:45:18
Last Modified         : Sat 12 Apr 2025 08:54:11
Votes                 : 133
Out of Date           : --
No it doesn’t: https://cateee.net/lkddb/web-lkddb/DRM_AMDGPU_KFD.html
If you look at the kconfig of amdkfd you will find HSA_AMD and HSA_AMD_SVM which are both Y in our kernel config. Those are built-in and not build as modules.
