The two file:
❯ uname -a
Linux hxzhao-pc 4.19.141-2-MANJARO #1 SMP Sat Aug 22 17:49:27 UTC 2020 x86_64 GNU/Linux
❯ head -n 2 /proc/self/mountinfo
0 0 0:1 / 20 25 0:4 / /proc rw,nosuid,nodev,noexec,relatime shared:5 - proc proc rw
21 25 0:20 / /sys rw,nosuid,nodev,noexec,relatime shared:6 - sysfs sys rw
❯ cat /proc/self/mounts
rootfs proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
dev /dev devtmpfs rw,nosuid,relatime,size=8128740k,nr_inodes=2032185,mode=755 0 0
run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0
efivarfs /sys/firmware/efi/efivars efivarfs rw,nosuid,nodev,noexec,relatime 0 0
/dev/sdb5 / ext4 rw,noatime,discard 0 0
securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,size=4096k,nr_inodes=1024,mode=755 0 0
cgroup2 /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate 0 0
cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0
pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0
bpf /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0
cgroup /sys/fs/cgroup/rdma cgroup rw,nosuid,nodev,noexec,relatime,rdma 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0
cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0
cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0
cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0
cgroup /sys/fs/cgroup/hugetlb cgroup rw,nosuid,nodev,noexec,relatime,hugetlb 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0
cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=19801 0 0
hugetlbfs /dev/hugepages hugetlbfs rw,relatime,pagesize=2M 0 0
mqueue /dev/mqueue mqueue rw,nosuid,nodev,noexec,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,nosuid,nodev,noexec,relatime 0 0
tracefs /sys/kernel/tracing tracefs rw,nosuid,nodev,noexec,relatime 0 0
configfs /sys/kernel/config configfs rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /tmp tmpfs rw,noatime 0 0
/dev/sdb2 /boot/efi vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/sda3 /opt ext4 rw,noatime,discard 0 0
/dev/sda1 /home ext4 rw,noatime 0 0
fusectl /sys/fs/fuse/connections fusectl rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=1627632k,nr_inodes=406908,mode=700,uid=1000,gid=1000 0 0
gvfsd-fuse /run/user/1000/gvfs fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0
❯ cat /proc/self/mountstats
device rootfs mounted on device proc mounted on /proc with fstype proc
device sys mounted on /sys with fstype sysfs
device dev mounted on /dev with fstype devtmpfs
device run mounted on /run with fstype tmpfs
device efivarfs mounted on /sys/firmware/efi/efivars with fstype efivarfs
device /dev/sdb5 mounted on / with fstype ext4
device securityfs mounted on /sys/kernel/security with fstype securityfs
device tmpfs mounted on /dev/shm with fstype tmpfs
device devpts mounted on /dev/pts with fstype devpts
device tmpfs mounted on /sys/fs/cgroup with fstype tmpfs
device cgroup2 mounted on /sys/fs/cgroup/unified with fstype cgroup2
device cgroup mounted on /sys/fs/cgroup/systemd with fstype cgroup
device pstore mounted on /sys/fs/pstore with fstype pstore
device bpf mounted on /sys/fs/bpf with fstype bpf
device cgroup mounted on /sys/fs/cgroup/memory with fstype cgroup
device cgroup mounted on /sys/fs/cgroup/net_cls,net_prio with fstype cgroup
device cgroup mounted on /sys/fs/cgroup/rdma with fstype cgroup
device cgroup mounted on /sys/fs/cgroup/cpu,cpuacct with fstype cgroup
device cgroup mounted on /sys/fs/cgroup/cpuset with fstype cgroup
device cgroup mounted on /sys/fs/cgroup/devices with fstype cgroup
device cgroup mounted on /sys/fs/cgroup/freezer with fstype cgroup
device cgroup mounted on /sys/fs/cgroup/hugetlb with fstype cgroup
device cgroup mounted on /sys/fs/cgroup/pids with fstype cgroup
device cgroup mounted on /sys/fs/cgroup/perf_event with fstype cgroup
device cgroup mounted on /sys/fs/cgroup/blkio with fstype cgroup
device systemd-1 mounted on /proc/sys/fs/binfmt_misc with fstype autofs
device hugetlbfs mounted on /dev/hugepages with fstype hugetlbfs
device mqueue mounted on /dev/mqueue with fstype mqueue
device debugfs mounted on /sys/kernel/debug with fstype debugfs
device tracefs mounted on /sys/kernel/tracing with fstype tracefs
device configfs mounted on /sys/kernel/config with fstype configfs
device tmpfs mounted on /tmp with fstype tmpfs
device /dev/sdb2 mounted on /boot/efi with fstype vfat
device /dev/sda3 mounted on /opt with fstype ext4
device /dev/sda1 mounted on /home with fstype ext4
device fusectl mounted on /sys/fs/fuse/connections with fstype fusectl
device tmpfs mounted on /run/user/1000 with fstype tmpfs
device gvfsd-fuse mounted on /run/user/1000/gvfs with fstype fuse.gvfsd-fuse
I checkout the kernel v4.19.141 source from kernel official, but it seems right.
// fs/proc_namespace.c:show_mountinfo()
static int show_mountinfo(struct seq_file *m, struct vfsmount *mnt)
struct proc_mounts *p = m->private;
struct mount *r = real_mount(mnt);
struct super_block *sb = mnt->mnt_sb;
struct path mnt_path = { .dentry = mnt->mnt_root, .mnt = mnt };
int err;
seq_printf(m, "%i %i %u:%u ", r->mnt_id, r->mnt_parent->mnt_id,
MAJOR(sb->s_dev), MINOR(sb->s_dev));
if (sb->s_op->show_path) {
err = sb->s_op->show_path(m, mnt->mnt_root);
if (err)
goto out;
} else {
seq_dentry(m, mnt->mnt_root, " \t\n\\");
seq_putc(m, ' ');
