icsh
1
Hey,
I’m by no means new to Arch, but I recently switched to Manjaro. Upon trying to “$ sudo pacman -S linux-zen”, it says “Target not found”.
I’ve refreshed databases and tried the same in Add/Remove Software. Am I missing a repo or does Manjaro just not include it?
Thanks in advance.
linux-zen
does not exist on Manjaro. You can install it from AUR though.
Be aware that if you are using any Manjaro kernel module you might be required to search for alternatives as they won’t work AFAIK.
system
Closed
4
