Hello there, I am using a laptop that has a ryzen processor and nvidia card.
I can’t quite get how to use dGPU for gaming. All the solutions I did find were for nvidia+Intel using optimus-manager
prime-run glxgears
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 25
Current serial number in output stream: 26
The same problem here. prime-run glxinfo leads to the error mentioned above. Seems that nvidia drivers cannot be loaded (because of “invalid argument”). video-hybrid-amd-nvidia-455xx-prime & 5.9 kernel.
How are you launching games? The easiest way is to use lutris for all your games. You have the prime render offload option, gamemode and many more tweaks
