iwlwifi refuses to work correctly on a machine using an intel ax200 with a b550 motherboard (the network card is stock). The motherboard is an asrock b550 phantom gaming-ITX/ax updated to the latest bios. The module keeps erroring and as it does, it momentarily slows down the system, delaying device inputs and screen output.
inxi -v 2:
Host: basil-z97nwifi Kernel: 5.18.6-1-MANJARO arch: x86_64 bits: 64
Desktop: i3 v: 4.20.1 Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: B550 Phantom Gaming-ITX/ax
serial: <superuser required> UEFI: American Megatrends LLC. v: P2.30
date: 02/25/2022
Info: 6-core AMD Ryzen 5 5600 [MT MCP] speed (MHz): avg: 3148
min/max: 2200/4467
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] driver: amdgpu
v: kernel
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: amdgpu
unloaded: modesetting,radeon gpu: amdgpu resolution: 2560x1440~60Hz
OpenGL: renderer: AMD Radeon RX 6600 (dimgrey_cavefish LLVM 13.0.1 DRM
3.46 5.18.6-1-MANJARO)
v: 4.6 Mesa 22.1.2
Device-1: Intel Ethernet I225-V driver: igc
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi
Local Storage: total: 1.19 TiB used: 30.08 GiB (2.5%)
Processes: 298 Uptime: 1h 4m Memory: 15.55 GiB used: 2.76 GiB (17.8%)
Shell: Bash inxi: 3.3.19
dmesg:
[ 0.000000] Linux version 5.18.6-1-MANJARO (builduser@fv-az39-795) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT_DYNAMIC Wed Jun 22 14:16:20 UTC 2022
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=b4c267b4-2ca4-42d3-ad43-92f9b03c60f7 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 3376
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009bfefff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009bff000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20dfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a20e000-0x000000000affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000b020000-0x00000000bb655fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bb656000-0x00000000bcd98fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bcd99000-0x00000000bcdd6fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000bcdd7000-0x00000000bd4b1fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bd4b2000-0x00000000bdf77fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000bdf78000-0x00000000bdffefff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000bdfff000-0x00000000beffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bf000000-0x00000000bfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd200000-0x00000000fd2fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd600000-0x00000000fd7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000043f37ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000043f380000-0x000000043fffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI=0xbd49b000 ACPI 2.0=0xbd49b014 TPMFinalLog=0xbd465000 SMBIOS=0xbde32000 SMBIOS 3.0=0xbde31000 MEMATTR=0xb65e3018 ESRT=0xb80d8f98
[ 0.000000] SMBIOS 3.3.0 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./B550 Phantom Gaming-ITX/ax, BIOS P2.30 02/25/2022
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3493.562 MHz processor
[ 0.000232] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000234] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000239] last_pfn = 0x43f380 max_arch_pfn = 0x400000000
[ 0.000871] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001095] total RAM covered: 3071M
[ 0.001196] Found optimal setting for mtrr clean up
[ 0.001197] gran_size: 64K chunk_size: 64M num_reg: 3 lose cover RAM: 0G
[ 0.001280] e820: update [mem 0xbcf40000-0xbcf4ffff] usable ==> reserved
[ 0.001284] e820: update [mem 0xc0000000-0xffffffff] usable ==> reserved
[ 0.001288] last_pfn = 0xbf000 max_arch_pfn = 0x400000000
[ 0.003937] esrt: Reserving ESRT space from 0x00000000b80d8f98 to 0x00000000b80d8fd0.
[ 0.003944] e820: update [mem 0xb80d8000-0xb80d8fff] usable ==> reserved
[ 0.003976] Using GB pages for direct mapping
[ 0.004425] Secure boot disabled
[ 0.004425] RAMDISK: [mem 0x33531000-0x35a8ffff]
[ 0.004429] ACPI: Early table checksum verification disabled
[ 0.004432] ACPI: RSDP 0x00000000BD49B014 000024 (v02 ALASKA)
[ 0.004434] ACPI: XSDT 0x00000000BD49A728 0000E4 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.004438] ACPI: FACP 0x00000000BCDC8000 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.004441] ACPI: DSDT 0x00000000BCDC1000 0061DF (v02 ALASKA A M I 01072009 INTL 20120913)
[ 0.004443] ACPI: FACS 0x00000000BD495000 000040
[ 0.004445] ACPI: SSDT 0x00000000BCDCE000 008CE9 (v02 AMD AmdTable 00000002 MSFT 04000000)
[ 0.004446] ACPI: SSDT 0x00000000BCDCA000 003ACF (v01 AMD AMD AOD 00000001 INTL 20120913)
[ 0.004448] ACPI: SSDT 0x00000000BCDC9000 0001AD (v02 ALASKA CPUSSDT 01072009 AMI 01072009)
[ 0.004449] ACPI: FIDT 0x00000000BCDC0000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.004451] ACPI: MCFG 0x00000000BCDBF000 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.004452] ACPI: AAFT 0x00000000BCDBE000 000115 (v01 ALASKA OEMAAFT 01072009 MSFT 00000097)
[ 0.004454] ACPI: HPET 0x00000000BCDBD000 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.004455] ACPI: BGRT 0x00000000BCDBC000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.004457] ACPI: TPM2 0x00000000BCDBB000 00004C (v04 ALASKA A M I 00000001 AMI 00000000)
[ 0.004458] ACPI: PCCT 0x00000000BCDBA000 00006E (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.004460] ACPI: SSDT 0x00000000BCDB6000 0030FB (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.004461] ACPI: CRAT 0x00000000BCDB5000 000B18 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.004462] ACPI: CDIT 0x00000000BCDB4000 000029 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.004464] ACPI: SSDT 0x00000000BCDB3000 0002C2 (v01 AMD ArticDGP 00000001 INTL 20120913)
[ 0.004465] ACPI: SSDT 0x00000000BCDB1000 0010B4 (v01 AMD ArticTPX 00000001 INTL 20120913)
[ 0.004467] ACPI: SSDT 0x00000000BCDB0000 00052C (v01 AMD ArticNOI 00000001 INTL 20120913)
[ 0.004468] ACPI: SSDT 0x00000000BCDAC000 003798 (v01 AMD ArticN 00000001 INTL 20120913)
[ 0.004470] ACPI: WSMT 0x00000000BCDAB000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.004471] ACPI: APIC 0x00000000BCDAA000 00015E (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.004472] ACPI: SSDT 0x00000000BCDA9000 00007D (v01 AMD ArticDIS 00000001 INTL 20120913)
[ 0.004474] ACPI: SSDT 0x00000000BCDA7000 0010AF (v01 AMD ArticC 00000001 INTL 20120913)
[ 0.004475] ACPI: SSDT 0x00000000BCDA6000 0000BF (v01 AMD AmdTable 00001000 INTL 20120913)
[ 0.004477] ACPI: FPDT 0x00000000BCDA5000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.004478] ACPI: Reserving FACP table memory at [mem 0xbcdc8000-0xbcdc8113]
[ 0.004479] ACPI: Reserving DSDT table memory at [mem 0xbcdc1000-0xbcdc71de]
[ 0.004479] ACPI: Reserving FACS table memory at [mem 0xbd495000-0xbd49503f]
[ 0.004480] ACPI: Reserving SSDT table memory at [mem 0xbcdce000-0xbcdd6ce8]
[ 0.004480] ACPI: Reserving SSDT table memory at [mem 0xbcdca000-0xbcdcdace]
[ 0.004481] ACPI: Reserving SSDT table memory at [mem 0xbcdc9000-0xbcdc91ac]
[ 0.004481] ACPI: Reserving FIDT table memory at [mem 0xbcdc0000-0xbcdc009b]
[ 0.004482] ACPI: Reserving MCFG table memory at [mem 0xbcdbf000-0xbcdbf03b]
[ 0.004482] ACPI: Reserving AAFT table memory at [mem 0xbcdbe000-0xbcdbe114]
[ 0.004483] ACPI: Reserving HPET table memory at [mem 0xbcdbd000-0xbcdbd037]
[ 0.004483] ACPI: Reserving BGRT table memory at [mem 0xbcdbc000-0xbcdbc037]
[ 0.004484] ACPI: Reserving TPM2 table memory at [mem 0xbcdbb000-0xbcdbb04b]
[ 0.004484] ACPI: Reserving PCCT table memory at [mem 0xbcdba000-0xbcdba06d]
[ 0.004485] ACPI: Reserving SSDT table memory at [mem 0xbcdb6000-0xbcdb90fa]
[ 0.004485] ACPI: Reserving CRAT table memory at [mem 0xbcdb5000-0xbcdb5b17]
[ 0.004486] ACPI: Reserving CDIT table memory at [mem 0xbcdb4000-0xbcdb4028]
[ 0.004486] ACPI: Reserving SSDT table memory at [mem 0xbcdb3000-0xbcdb32c1]
[ 0.004487] ACPI: Reserving SSDT table memory at [mem 0xbcdb1000-0xbcdb20b3]
[ 0.004487] ACPI: Reserving SSDT table memory at [mem 0xbcdb0000-0xbcdb052b]
[ 0.004488] ACPI: Reserving SSDT table memory at [mem 0xbcdac000-0xbcdaf797]
[ 0.004488] ACPI: Reserving WSMT table memory at [mem 0xbcdab000-0xbcdab027]
[ 0.004489] ACPI: Reserving APIC table memory at [mem 0xbcdaa000-0xbcdaa15d]
[ 0.004489] ACPI: Reserving SSDT table memory at [mem 0xbcda9000-0xbcda907c]
[ 0.004489] ACPI: Reserving SSDT table memory at [mem 0xbcda7000-0xbcda80ae]
[ 0.004490] ACPI: Reserving SSDT table memory at [mem 0xbcda6000-0xbcda60be]
[ 0.004490] ACPI: Reserving FPDT table memory at [mem 0xbcda5000-0xbcda5043]
[ 0.004534] No NUMA configuration found
[ 0.004534] Faking a node at [mem 0x0000000000000000-0x000000043f37ffff]
[ 0.004536] NODE_DATA(0) allocated [mem 0x43f37c000-0x43f37ffff]
[ 0.004555] Zone ranges:
[ 0.004556] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.004557] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.004558] Normal [mem 0x0000000100000000-0x000000043f37ffff]
[ 0.004558] Device empty
[ 0.004559] Movable zone start for each node
[ 0.004559] Early memory node ranges
[ 0.004560] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.004561] node 0: [mem 0x0000000000100000-0x0000000009bfefff]
[ 0.004561] node 0: [mem 0x000000000a000000-0x000000000a1fffff]
[ 0.004562] node 0: [mem 0x000000000a20e000-0x000000000affffff]
[ 0.004562] node 0: [mem 0x000000000b020000-0x00000000bb655fff]
[ 0.004563] node 0: [mem 0x00000000bdfff000-0x00000000beffffff]
[ 0.004563] node 0: [mem 0x0000000100000000-0x000000043f37ffff]
[ 0.004564] Initmem setup node 0 [mem 0x0000000000001000-0x000000043f37ffff]
[ 0.004567] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.004577] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.004665] On node 0, zone DMA32: 1025 pages in unavailable ranges
[ 0.004674] On node 0, zone DMA32: 14 pages in unavailable ranges
[ 0.006914] On node 0, zone DMA32: 32 pages in unavailable ranges
[ 0.006984] On node 0, zone DMA32: 10665 pages in unavailable ranges
[ 0.022650] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.022671] On node 0, zone Normal: 3200 pages in unavailable ranges
[ 0.022916] ACPI: PM-Timer IO Port: 0x808
[ 0.022922] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.022934] IOAPIC[0]: apic_id 13, version 33, address 0xfec00000, GSI 0-23
[ 0.022939] IOAPIC[1]: apic_id 14, version 33, address 0xfec01000, GSI 24-55
[ 0.022941] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.022942] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.022944] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.022945] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.022954] e820: update [mem 0xb6fac000-0xb6fecfff] usable ==> reserved
[ 0.022962] smpboot: Allowing 32 CPUs, 20 hotplug CPUs
[ 0.022981] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.022983] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.022984] PM: hibernation: Registered nosave memory: [mem 0x09bff000-0x09ffffff]
[ 0.022985] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20dfff]
[ 0.022986] PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b01ffff]
[ 0.022987] PM: hibernation: Registered nosave memory: [mem 0xb6fac000-0xb6fecfff]
[ 0.022988] PM: hibernation: Registered nosave memory: [mem 0xb80d8000-0xb80d8fff]
[ 0.022989] PM: hibernation: Registered nosave memory: [mem 0xbb656000-0xbcd98fff]
[ 0.022989] PM: hibernation: Registered nosave memory: [mem 0xbcd99000-0xbcdd6fff]
[ 0.022990] PM: hibernation: Registered nosave memory: [mem 0xbcdd7000-0xbd4b1fff]
[ 0.022990] PM: hibernation: Registered nosave memory: [mem 0xbd4b2000-0xbdf77fff]
[ 0.022990] PM: hibernation: Registered nosave memory: [mem 0xbdf78000-0xbdffefff]
[ 0.022991] PM: hibernation: Registered nosave memory: [mem 0xbf000000-0xbfffffff]
[ 0.022992] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xefffffff]
[ 0.022992] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[ 0.022992] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfd1fffff]
[ 0.022993] PM: hibernation: Registered nosave memory: [mem 0xfd200000-0xfd2fffff]
[ 0.022993] PM: hibernation: Registered nosave memory: [mem 0xfd300000-0xfd5fffff]
[ 0.022993] PM: hibernation: Registered nosave memory: [mem 0xfd600000-0xfd7fffff]
[ 0.022994] PM: hibernation: Registered nosave memory: [mem 0xfd800000-0xfe9fffff]
[ 0.022994] PM: hibernation: Registered nosave memory: [mem 0xfea00000-0xfea0ffff]
[ 0.022994] PM: hibernation: Registered nosave memory: [mem 0xfea10000-0xfeb7ffff]
[ 0.022995] PM: hibernation: Registered nosave memory: [mem 0xfeb80000-0xfec01fff]
[ 0.022995] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[ 0.022996] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.022996] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfec2ffff]
[ 0.022996] PM: hibernation: Registered nosave memory: [mem 0xfec30000-0xfec30fff]
[ 0.022997] PM: hibernation: Registered nosave memory: [mem 0xfec31000-0xfecfffff]
[ 0.022997] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.022997] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[ 0.022998] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[ 0.022998] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[ 0.022998] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.022999] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfedc1fff]
[ 0.022999] PM: hibernation: Registered nosave memory: [mem 0xfedc2000-0xfedcffff]
[ 0.022999] PM: hibernation: Registered nosave memory: [mem 0xfedd0000-0xfedd3fff]
[ 0.023000] PM: hibernation: Registered nosave memory: [mem 0xfedd4000-0xfedd5fff]
[ 0.023000] PM: hibernation: Registered nosave memory: [mem 0xfedd6000-0xfeffffff]
[ 0.023000] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.023001] [mem 0xc0000000-0xefffffff] available for PCI devices
[ 0.023002] Booting paravirtualized kernel on bare hardware
[ 0.023004] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.025632] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:32 nr_node_ids:1
[ 0.026600] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[ 0.026605] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[ 0.026606] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.026611] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[ 0.026632] Fallback order for Node 0: 0
[ 0.026635] Built 1 zonelists, mobility grouping on. Total pages: 4109777
[ 0.026636] Policy zone: Normal
[ 0.026637] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=b4c267b4-2ca4-42d3-ad43-92f9b03c60f7 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.026688] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64", will be passed to user space.
[ 0.026689] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.026689] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[ 0.026690] printk: log_buf_len min size: 131072 bytes
[ 0.026821] printk: log_buf_len: 262144 bytes
[ 0.026821] printk: early log buf free: 115432(88%)
[ 0.027699] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.028140] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.028319] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.056510] Memory: 16157420K/16700700K available (14343K kernel code, 2124K rwdata, 11068K rodata, 1856K init, 3308K bss, 543020K reserved, 0K cma-reserved)
[ 0.057051] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.057071] ftrace: allocating 45072 entries in 177 pages
[ 0.063977] ftrace: allocated 177 pages with 4 groups
[ 0.064049] Dynamic Preempt: full
[ 0.064121] rcu: Preemptible hierarchical RCU implementation.
[ 0.064121] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=32.
[ 0.064122] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.064123] Trampoline variant of Tasks RCU enabled.
[ 0.064123] Rude variant of Tasks RCU enabled.
[ 0.064124] Tracing variant of Tasks RCU enabled.
[ 0.064124] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.064125] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.066578] NR_IRQS: 20736, nr_irqs: 1224, preallocated irqs: 16
[ 0.066811] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.066827] random: crng init done
[ 0.066850] Console: colour dummy device 80x25
[ 0.066857] printk: console [tty0] enabled
[ 0.066872] ACPI: Core revision 20211217
[ 0.066963] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.066979] APIC: Switch to symmetric I/O mode setup
[ 0.067114] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.067176] Switched APIC routing to physical flat.
[ 0.067781] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.083646] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x325b8f4029a, max_idle_ns: 440795321053 ns
[ 0.083649] Calibrating delay loop (skipped), value calculated using timer frequency.. 6989.25 BogoMIPS (lpj=11645206)
[ 0.083650] pid_max: default: 32768 minimum: 301
[ 0.085329] LSM: Security Framework initializing
[ 0.085336] landlock: Up and running.
[ 0.085336] Yama: becoming mindful.
[ 0.085340] LSM support for eBPF active
[ 0.085351] AppArmor: AppArmor initialized
[ 0.085380] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.085399] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.085546] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.085581] LVT offset 1 assigned for vector 0xf9
[ 0.085703] LVT offset 2 assigned for vector 0xf4
[ 0.085744] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[ 0.085745] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.085747] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.085748] Spectre V2 : Mitigation: Retpolines
[ 0.085749] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.085749] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.085750] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.085750] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.085751] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.089250] Freeing SMP alternatives memory: 36K
[ 0.198162] smpboot: CPU0: AMD Ryzen 5 5600 6-Core Processor (family: 0x19, model: 0x21, stepping: 0x2)
[ 0.198244] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.198245] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.198253] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.198262] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.198269] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.198272] ... version: 0
[ 0.198272] ... bit width: 48
[ 0.198273] ... generic registers: 6
[ 0.198273] ... value mask: 0000ffffffffffff
[ 0.198273] ... max period: 00007fffffffffff
[ 0.198274] ... fixed-purpose events: 0
[ 0.198274] ... event mask: 000000000000003f
[ 0.198311] rcu: Hierarchical SRCU implementation.
[ 0.198558] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.198706] smp: Bringing up secondary CPUs ...
[ 0.198758] x86: Booting SMP configuration:
[ 0.198759] .... node #0, CPUs: #1 #2 #3 #4 #5 #6
[ 0.210364] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.210391] #7 #8 #9 #10 #11
[ 0.222466] smp: Brought up 1 node, 12 CPUs
[ 0.222466] smpboot: Max logical packages: 3
[ 0.222466] smpboot: Total of 12 processors activated (83879.04 BogoMIPS)
[ 0.223847] devtmpfs: initialized
[ 0.223847] x86/mm: Memory block size: 128MB
[ 0.224185] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20dfff] (57344 bytes)
[ 0.224185] ACPI: PM: Registering ACPI NVS region [mem 0xbcdd7000-0xbd4b1fff] (7188480 bytes)
[ 0.224185] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.224185] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.224185] pinctrl core: initialized pinctrl subsystem
[ 0.224185] PM: RTC time: 21:53:04, date: 2022-06-30
[ 0.224185] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.224185] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.224260] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.224336] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.224342] audit: initializing netlink subsys (disabled)
[ 0.224346] audit: type=2000 audit(1656625984.156:1): state=initialized audit_enabled=0 res=1
[ 0.224346] thermal_sys: Registered thermal governor 'fair_share'
[ 0.224346] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.224346] thermal_sys: Registered thermal governor 'step_wise'
[ 0.224346] thermal_sys: Registered thermal governor 'user_space'
[ 0.224346] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.224346] cpuidle: using governor ladder
[ 0.224346] cpuidle: using governor menu
[ 0.224346] Detected 1 PCC Subspaces
[ 0.224346] Registering PCC driver as Mailbox controller
[ 0.224346] HugeTLB: can free 4095 vmemmap pages for hugepages-1048576kB
[ 0.224346] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.224346] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.224346] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.224346] PCI: Using configuration type 1 for base access
[ 0.224443] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.224448] HugeTLB: can free 7 vmemmap pages for hugepages-2048kB
[ 0.224448] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.224448] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.224448] ACPI: Added _OSI(Module Device)
[ 0.224448] ACPI: Added _OSI(Processor Device)
[ 0.224448] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.224448] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.224448] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.224448] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.224448] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.235043] ACPI: 12 ACPI AML tables successfully acquired and loaded
[ 0.235864] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.238602] ACPI: Interpreter enabled
[ 0.238612] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.238613] ACPI: Using IOAPIC for interrupt routing
[ 0.238802] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.239073] ACPI: Enabled 7 GPEs in block 00 to 1F
[ 0.244292] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.244296] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.244351] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[ 0.244449] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.244456] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[ 0.244679] PCI host bridge to bus 0000:00
[ 0.244680] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.244681] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.244682] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.244683] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.244683] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 0.244684] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfec2ffff window]
[ 0.244685] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[ 0.244686] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.244695] pci 0000:00:00.0: [1022:1480] type 00 class 0x060000
[ 0.244765] pci 0000:00:01.0: [1022:1482] type 00 class 0x060000
[ 0.244822] pci 0000:00:01.2: [1022:1483] type 01 class 0x060400
[ 0.244883] pci 0000:00:01.2: enabling Extended Tags
[ 0.244994] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.245143] pci 0000:00:02.0: [1022:1482] type 00 class 0x060000
[ 0.245192] pci 0000:00:03.0: [1022:1482] type 00 class 0x060000
[ 0.245234] pci 0000:00:03.1: [1022:1483] type 01 class 0x060400
[ 0.245302] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[ 0.245377] pci 0000:00:04.0: [1022:1482] type 00 class 0x060000
[ 0.245423] pci 0000:00:05.0: [1022:1482] type 00 class 0x060000
[ 0.245470] pci 0000:00:07.0: [1022:1482] type 00 class 0x060000
[ 0.245512] pci 0000:00:07.1: [1022:1484] type 01 class 0x060400
[ 0.245536] pci 0000:00:07.1: enabling Extended Tags
[ 0.245575] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[ 0.245640] pci 0000:00:08.0: [1022:1482] type 00 class 0x060000
[ 0.245682] pci 0000:00:08.1: [1022:1484] type 01 class 0x060400
[ 0.245708] pci 0000:00:08.1: enabling Extended Tags
[ 0.245750] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.245834] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.245926] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.246025] pci 0000:00:18.0: [1022:1440] type 00 class 0x060000
[ 0.246045] pci 0000:00:18.1: [1022:1441] type 00 class 0x060000
[ 0.246064] pci 0000:00:18.2: [1022:1442] type 00 class 0x060000
[ 0.246083] pci 0000:00:18.3: [1022:1443] type 00 class 0x060000
[ 0.246103] pci 0000:00:18.4: [1022:1444] type 00 class 0x060000
[ 0.246122] pci 0000:00:18.5: [1022:1445] type 00 class 0x060000
[ 0.246143] pci 0000:00:18.6: [1022:1446] type 00 class 0x060000
[ 0.246163] pci 0000:00:18.7: [1022:1447] type 00 class 0x060000
[ 0.246439] pci 0000:01:00.0: [1022:43ee] type 00 class 0x0c0330
[ 0.246459] pci 0000:01:00.0: reg 0x10: [mem 0xfc9a0000-0xfc9a7fff 64bit]
[ 0.246505] pci 0000:01:00.0: enabling Extended Tags
[ 0.246565] pci 0000:01:00.0: PME# supported from D3hot D3cold
[ 0.246844] pci 0000:01:00.1: [1022:43eb] type 00 class 0x010601
[ 0.246896] pci 0000:01:00.1: reg 0x24: [mem 0xfc980000-0xfc99ffff]
[ 0.246905] pci 0000:01:00.1: reg 0x30: [mem 0xfc900000-0xfc97ffff pref]
[ 0.246912] pci 0000:01:00.1: enabling Extended Tags
[ 0.246956] pci 0000:01:00.1: PME# supported from D3hot D3cold
[ 0.247216] pci 0000:01:00.2: [1022:43e9] type 01 class 0x060400
[ 0.247266] pci 0000:01:00.2: enabling Extended Tags
[ 0.247316] pci 0000:01:00.2: PME# supported from D3hot D3cold
[ 0.247385] pci 0000:00:01.2: PCI bridge to [bus 01-04]
[ 0.247389] pci 0000:00:01.2: bridge window [mem 0xfc500000-0xfc9fffff]
[ 0.247650] pci 0000:02:08.0: [1022:43ea] type 01 class 0x060400
[ 0.247702] pci 0000:02:08.0: enabling Extended Tags
[ 0.247759] pci 0000:02:08.0: PME# supported from D3hot D3cold
[ 0.247824] pci 0000:02:09.0: [1022:43ea] type 01 class 0x060400
[ 0.247876] pci 0000:02:09.0: enabling Extended Tags
[ 0.247933] pci 0000:02:09.0: PME# supported from D3hot D3cold
[ 0.248006] pci 0000:01:00.2: PCI bridge to [bus 02-04]
[ 0.248013] pci 0000:01:00.2: bridge window [mem 0xfc500000-0xfc8fffff]
[ 0.248082] pci 0000:03:00.0: [8086:15f3] type 00 class 0x020000
[ 0.248107] pci 0000:03:00.0: reg 0x10: [mem 0xfc600000-0xfc6fffff]
[ 0.248146] pci 0000:03:00.0: reg 0x1c: [mem 0xfc700000-0xfc703fff]
[ 0.248186] pci 0000:03:00.0: reg 0x30: [mem 0xfc500000-0xfc5fffff pref]
[ 0.248305] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.248447] pci 0000:02:08.0: PCI bridge to [bus 03]
[ 0.248455] pci 0000:02:08.0: bridge window [mem 0xfc500000-0xfc7fffff]
[ 0.248546] pci 0000:04:00.0: [8086:2723] type 00 class 0x028000
[ 0.248578] pci 0000:04:00.0: reg 0x10: [mem 0xfc800000-0xfc803fff 64bit]
[ 0.248743] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[ 0.248877] pci 0000:02:09.0: PCI bridge to [bus 04]
[ 0.248884] pci 0000:02:09.0: bridge window [mem 0xfc800000-0xfc8fffff]
[ 0.248953] pci 0000:05:00.0: [1002:1478] type 01 class 0x060400
[ 0.248966] pci 0000:05:00.0: reg 0x10: [mem 0xfcf00000-0xfcf03fff]
[ 0.249067] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[ 0.249173] pci 0000:00:03.1: PCI bridge to [bus 05-07]
[ 0.249176] pci 0000:00:03.1: bridge window [io 0xf000-0xffff]
[ 0.249178] pci 0000:00:03.1: bridge window [mem 0xfcd00000-0xfcffffff]
[ 0.249181] pci 0000:00:03.1: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.249229] pci 0000:06:00.0: [1002:1479] type 01 class 0x060400
[ 0.249341] pci 0000:06:00.0: PME# supported from D0 D3hot D3cold
[ 0.249715] pci 0000:05:00.0: PCI bridge to [bus 06-07]
[ 0.249720] pci 0000:05:00.0: bridge window [io 0xf000-0xffff]
[ 0.249723] pci 0000:05:00.0: bridge window [mem 0xfcd00000-0xfcefffff]
[ 0.249727] pci 0000:05:00.0: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.249780] pci 0000:07:00.0: [1002:73ff] type 00 class 0x030000
[ 0.249797] pci 0000:07:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.249808] pci 0000:07:00.0: reg 0x18: [mem 0xe0000000-0xe01fffff 64bit pref]
[ 0.249816] pci 0000:07:00.0: reg 0x20: [io 0xf000-0xf0ff]
[ 0.249823] pci 0000:07:00.0: reg 0x24: [mem 0xfcd00000-0xfcdfffff]
[ 0.249831] pci 0000:07:00.0: reg 0x30: [mem 0xfce00000-0xfce1ffff pref]
[ 0.249854] pci 0000:07:00.0: BAR 0: assigned to efifb
[ 0.249861] pci 0000:07:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.249927] pci 0000:07:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.250004] pci 0000:07:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:00:03.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.250044] pci 0000:07:00.1: [1002:ab28] type 00 class 0x040300
[ 0.250058] pci 0000:07:00.1: reg 0x10: [mem 0xfce20000-0xfce23fff]
[ 0.250158] pci 0000:07:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.250247] pci 0000:06:00.0: PCI bridge to [bus 07]
[ 0.250252] pci 0000:06:00.0: bridge window [io 0xf000-0xffff]
[ 0.250255] pci 0000:06:00.0: bridge window [mem 0xfcd00000-0xfcefffff]
[ 0.250259] pci 0000:06:00.0: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.250302] pci 0000:08:00.0: [1022:148a] type 00 class 0x130000
[ 0.250337] pci 0000:08:00.0: enabling Extended Tags
[ 0.250438] pci 0000:00:07.1: PCI bridge to [bus 08]
[ 0.250485] pci 0000:09:00.0: [1022:1485] type 00 class 0x130000
[ 0.250519] pci 0000:09:00.0: enabling Extended Tags
[ 0.250625] pci 0000:09:00.1: [1022:1486] type 00 class 0x108000
[ 0.250641] pci 0000:09:00.1: reg 0x18: [mem 0xfcb00000-0xfcbfffff]
[ 0.250653] pci 0000:09:00.1: reg 0x24: [mem 0xfcc08000-0xfcc09fff]
[ 0.250661] pci 0000:09:00.1: enabling Extended Tags
[ 0.250756] pci 0000:09:00.3: [1022:149c] type 00 class 0x0c0330
[ 0.250769] pci 0000:09:00.3: reg 0x10: [mem 0xfca00000-0xfcafffff 64bit]
[ 0.250799] pci 0000:09:00.3: enabling Extended Tags
[ 0.250844] pci 0000:09:00.3: PME# supported from D0 D3hot D3cold
[ 0.250904] pci 0000:09:00.4: [1022:1487] type 00 class 0x040300
[ 0.250913] pci 0000:09:00.4: reg 0x10: [mem 0xfcc00000-0xfcc07fff]
[ 0.250940] pci 0000:09:00.4: enabling Extended Tags
[ 0.250982] pci 0000:09:00.4: PME# supported from D0 D3hot D3cold
[ 0.251052] pci 0000:00:08.1: PCI bridge to [bus 09]
[ 0.251056] pci 0000:00:08.1: bridge window [mem 0xfca00000-0xfccfffff]
[ 0.251236] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.251273] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.251303] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.251341] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.251375] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.251403] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.251431] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.251459] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.251942] iommu: Default domain type: Translated
[ 0.251943] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.252016] SCSI subsystem initialized
[ 0.252024] libata version 3.00 loaded.
[ 0.252024] ACPI: bus type USB registered
[ 0.252024] usbcore: registered new interface driver usbfs
[ 0.252024] usbcore: registered new interface driver hub
[ 0.252024] usbcore: registered new device driver usb
[ 0.252024] pps_core: LinuxPPS API ver. 1 registered
[ 0.252024] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.252024] PTP clock support registered
[ 0.252024] EDAC MC: Ver: 3.0.0
[ 0.252024] Registered efivars operations
[ 0.252024] NetLabel: Initializing
[ 0.252024] NetLabel: domain hash size = 128
[ 0.252024] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.252024] NetLabel: unlabeled traffic allowed by default
[ 0.252024] mctp: management component transport protocol core
[ 0.252024] NET: Registered PF_MCTP protocol family
[ 0.252024] PCI: Using ACPI for IRQ routing
[ 0.256472] PCI: pci_cache_line_size set to 64 bytes
[ 0.256810] e820: reserve RAM buffer [mem 0x09bff000-0x0bffffff]
[ 0.256811] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.256811] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[ 0.256812] e820: reserve RAM buffer [mem 0xb6fac000-0xb7ffffff]
[ 0.256812] e820: reserve RAM buffer [mem 0xb80d8000-0xbbffffff]
[ 0.256813] e820: reserve RAM buffer [mem 0xbb656000-0xbbffffff]
[ 0.256813] e820: reserve RAM buffer [mem 0xbf000000-0xbfffffff]
[ 0.256814] e820: reserve RAM buffer [mem 0x43f380000-0x43fffffff]
[ 0.256820] pci 0000:07:00.0: vgaarb: setting as boot VGA device
[ 0.256820] pci 0000:07:00.0: vgaarb: bridge control possible
[ 0.256820] pci 0000:07:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.256820] vgaarb: loaded
[ 0.256820] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.256820] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.258020] clocksource: Switched to clocksource tsc-early
[ 0.261711] VFS: Disk quotas dquot_6.6.0
[ 0.261720] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.261777] AppArmor: AppArmor Filesystem Enabled
[ 0.261794] pnp: PnP ACPI init
[ 0.261845] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 0.261861] system 00:01: [mem 0xfeb80000-0xfebfffff] has been reserved
[ 0.261894] system 00:02: [mem 0xfd200000-0xfd2fffff] has been reserved
[ 0.262034] system 00:04: [io 0x0280-0x028f] has been reserved
[ 0.262036] system 00:04: [io 0x0290-0x029f] has been reserved
[ 0.262036] system 00:04: [io 0x02a0-0x02af] has been reserved
[ 0.262037] system 00:04: [io 0x02b0-0x02bf] has been reserved
[ 0.262181] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.262181] system 00:05: [io 0x040b] has been reserved
[ 0.262182] system 00:05: [io 0x04d6] has been reserved
[ 0.262183] system 00:05: [io 0x0c00-0x0c01] has been reserved
[ 0.262183] system 00:05: [io 0x0c14] has been reserved
[ 0.262184] system 00:05: [io 0x0c50-0x0c51] has been reserved
[ 0.262185] system 00:05: [io 0x0c52] has been reserved
[ 0.262186] system 00:05: [io 0x0c6c] has been reserved
[ 0.262186] system 00:05: [io 0x0c6f] has been reserved
[ 0.262187] system 00:05: [io 0x0cd8-0x0cdf] has been reserved
[ 0.262188] system 00:05: [io 0x0800-0x089f] has been reserved
[ 0.262188] system 00:05: [io 0x0b00-0x0b0f] has been reserved
[ 0.262189] system 00:05: [io 0x0b20-0x0b3f] has been reserved
[ 0.262190] system 00:05: [io 0x0900-0x090f] has been reserved
[ 0.262190] system 00:05: [io 0x0910-0x091f] has been reserved
[ 0.262191] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.262192] system 00:05: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.262193] system 00:05: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.262194] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.262195] system 00:05: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.262196] system 00:05: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.262197] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.262553] pnp: PnP ACPI: found 6 devices
[ 0.267688] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.267724] NET: Registered PF_INET protocol family
[ 0.267833] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.268717] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.268740] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.268801] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.268928] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.268975] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.269042] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.269070] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.269099] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.269143] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.269146] NET: Registered PF_XDP protocol family
[ 0.269152] pci 0000:02:08.0: PCI bridge to [bus 03]
[ 0.269345] pci 0000:02:08.0: bridge window [mem 0xfc500000-0xfc7fffff]
[ 0.269353] pci 0000:02:09.0: PCI bridge to [bus 04]
[ 0.269357] pci 0000:02:09.0: bridge window [mem 0xfc800000-0xfc8fffff]
[ 0.269365] pci 0000:01:00.2: PCI bridge to [bus 02-04]
[ 0.269368] pci 0000:01:00.2: bridge window [mem 0xfc500000-0xfc8fffff]
[ 0.269376] pci 0000:00:01.2: PCI bridge to [bus 01-04]
[ 0.269378] pci 0000:00:01.2: bridge window [mem 0xfc500000-0xfc9fffff]
[ 0.269383] pci 0000:06:00.0: PCI bridge to [bus 07]
[ 0.269389] pci 0000:06:00.0: bridge window [io 0xf000-0xffff]
[ 0.269393] pci 0000:06:00.0: bridge window [mem 0xfcd00000-0xfcefffff]
[ 0.269395] pci 0000:06:00.0: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.269400] pci 0000:05:00.0: PCI bridge to [bus 06-07]
[ 0.269402] pci 0000:05:00.0: bridge window [io 0xf000-0xffff]
[ 0.269405] pci 0000:05:00.0: bridge window [mem 0xfcd00000-0xfcefffff]
[ 0.269408] pci 0000:05:00.0: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.269412] pci 0000:00:03.1: PCI bridge to [bus 05-07]
[ 0.269413] pci 0000:00:03.1: bridge window [io 0xf000-0xffff]
[ 0.269415] pci 0000:00:03.1: bridge window [mem 0xfcd00000-0xfcffffff]
[ 0.269417] pci 0000:00:03.1: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.269420] pci 0000:00:07.1: PCI bridge to [bus 08]
[ 0.269426] pci 0000:00:08.1: PCI bridge to [bus 09]
[ 0.269428] pci 0000:00:08.1: bridge window [mem 0xfca00000-0xfccfffff]
[ 0.269433] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.269434] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.269434] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.269435] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.269435] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 0.269436] pci_bus 0000:00: resource 9 [mem 0xc0000000-0xfec2ffff window]
[ 0.269437] pci_bus 0000:00: resource 10 [mem 0xfee00000-0xffffffff window]
[ 0.269437] pci_bus 0000:01: resource 1 [mem 0xfc500000-0xfc9fffff]
[ 0.269438] pci_bus 0000:02: resource 1 [mem 0xfc500000-0xfc8fffff]
[ 0.269439] pci_bus 0000:03: resource 1 [mem 0xfc500000-0xfc7fffff]
[ 0.269439] pci_bus 0000:04: resource 1 [mem 0xfc800000-0xfc8fffff]
[ 0.269440] pci_bus 0000:05: resource 0 [io 0xf000-0xffff]
[ 0.269441] pci_bus 0000:05: resource 1 [mem 0xfcd00000-0xfcffffff]
[ 0.269441] pci_bus 0000:05: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.269442] pci_bus 0000:06: resource 0 [io 0xf000-0xffff]
[ 0.269442] pci_bus 0000:06: resource 1 [mem 0xfcd00000-0xfcefffff]
[ 0.269443] pci_bus 0000:06: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.269444] pci_bus 0000:07: resource 0 [io 0xf000-0xffff]
[ 0.269444] pci_bus 0000:07: resource 1 [mem 0xfcd00000-0xfcefffff]
[ 0.269445] pci_bus 0000:07: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[ 0.269446] pci_bus 0000:09: resource 1 [mem 0xfca00000-0xfccfffff]
[ 0.269814] pci 0000:07:00.1: D0 power state depends on 0000:07:00.0
[ 0.269931] PCI: CLS 64 bytes, default 64
[ 0.269935] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.269935] software IO TLB: mapped [mem 0x00000000b17fd000-0x00000000b57fd000] (64MB)
[ 0.269954] LVT offset 0 assigned for vector 0x400
[ 0.269962] Trying to unpack rootfs image as initramfs...
[ 0.279180] perf: AMD IBS detected (0x000003ff)
[ 0.279924] Initialise system trusted keyrings
[ 0.279930] Key type blacklist registered
[ 0.279949] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.280435] zbud: loaded
[ 0.282918] Key type asymmetric registered
[ 0.282919] Asymmetric key parser 'x509' registered
[ 0.484897] Freeing initrd memory: 38268K
[ 0.486105] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.486121] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.486151] io scheduler mq-deadline registered
[ 0.486152] io scheduler kyber registered
[ 0.486175] io scheduler bfq registered
[ 0.486494] pcieport 0000:00:01.2: PME: Signaling with IRQ 25
[ 0.486748] pcieport 0000:00:01.2: AER: enabled with IRQ 25
[ 0.486876] pcieport 0000:00:03.1: PME: Signaling with IRQ 26
[ 0.486926] pcieport 0000:00:03.1: AER: enabled with IRQ 26
[ 0.487116] pcieport 0000:00:07.1: PME: Signaling with IRQ 28
[ 0.487164] pcieport 0000:00:07.1: AER: enabled with IRQ 28
[ 0.487276] pcieport 0000:00:08.1: PME: Signaling with IRQ 29
[ 0.487320] pcieport 0000:00:08.1: AER: enabled with IRQ 29
[ 0.488262] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.488332] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.488345] ACPI: button: Power Button [PWRB]
[ 0.488361] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.488381] ACPI: button: Power Button [PWRF]
[ 0.491724] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1165
[ 0.491733] Monitor-Mwait will be used to enter C-1 state
[ 0.491736] ACPI: \_SB_.PLTF.C000: Found 2 idle states
[ 0.491799] ACPI: \_SB_.PLTF.C002: Found 2 idle states
[ 0.491869] ACPI: \_SB_.PLTF.C004: Found 2 idle states
[ 0.491941] ACPI: \_SB_.PLTF.C006: Found 2 idle states
[ 0.492013] ACPI: \_SB_.PLTF.C008: Found 2 idle states
[ 0.492078] ACPI: \_SB_.PLTF.C00A: Found 2 idle states
[ 0.492141] ACPI: \_SB_.PLTF.C001: Found 2 idle states
[ 0.492191] ACPI: \_SB_.PLTF.C003: Found 2 idle states
[ 0.492257] ACPI: \_SB_.PLTF.C005: Found 2 idle states
[ 0.492335] ACPI: \_SB_.PLTF.C007: Found 2 idle states
[ 0.492388] ACPI: \_SB_.PLTF.C009: Found 2 idle states
[ 0.492442] ACPI: \_SB_.PLTF.C00B: Found 2 idle states
[ 0.492554] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.493180] Non-volatile memory driver v1.3
[ 0.493181] Linux agpgart interface v0.103
[ 0.493181] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.493209] ACPI: bus type drm_connector registered
[ 0.493828] ahci 0000:01:00.1: version 3.0
[ 0.494091] ahci 0000:01:00.1: SSS flag set, parallel bus scan disabled
[ 0.494161] ahci 0000:01:00.1: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 0.494163] ahci 0000:01:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[ 0.494640] scsi host0: ahci
[ 0.494706] scsi host1: ahci
[ 0.494755] scsi host2: ahci
[ 0.494803] scsi host3: ahci
[ 0.494837] scsi host4: ahci
[ 0.494872] scsi host5: ahci
[ 0.495071] ata1: SATA max UDMA/133 abar m131072@0xfc980000 port 0xfc980100 irq 39
[ 0.495074] ata2: SATA max UDMA/133 abar m131072@0xfc980000 port 0xfc980180 irq 39
[ 0.495076] ata3: SATA max UDMA/133 abar m131072@0xfc980000 port 0xfc980200 irq 39
[ 0.495077] ata4: SATA max UDMA/133 abar m131072@0xfc980000 port 0xfc980280 irq 39
[ 0.495079] ata5: SATA max UDMA/133 abar m131072@0xfc980000 port 0xfc980300 irq 39
[ 0.495081] ata6: SATA max UDMA/133 abar m131072@0xfc980000 port 0xfc980380 irq 39
[ 0.495108] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.495110] ehci-pci: EHCI PCI platform driver
[ 0.495117] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.495118] ohci-pci: OHCI PCI platform driver
[ 0.495124] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.495145] usbcore: registered new interface driver usbserial_generic
[ 0.495147] usbserial: USB Serial support registered for generic
[ 0.495186] rtc_cmos 00:03: RTC can wake from S4
[ 0.495398] rtc_cmos 00:03: registered as rtc0
[ 0.495434] rtc_cmos 00:03: setting system clock to 2022-06-30T21:53:05 UTC (1656625985)
[ 0.495441] rtc_cmos 00:03: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.495515] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.495565] efifb: probing for efifb
[ 0.495571] efifb: showing boot graphics
[ 0.497359] efifb: framebuffer at 0xd0000000, using 14400k, total 14400k
[ 0.497360] efifb: mode is 2560x1440x32, linelength=10240, pages=1
[ 0.497361] efifb: scrolling: redraw
[ 0.497361] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.497379] fbcon: Deferring console take-over
[ 0.497380] fb0: EFI VGA frame buffer device
[ 0.497392] hid: raw HID events driver (C) Jiri Kosina
[ 0.497433] drop_monitor: Initializing network drop monitor service
[ 0.504639] Initializing XFRM netlink socket
[ 0.504680] NET: Registered PF_INET6 protocol family
[ 0.506001] Segment Routing with IPv6
[ 0.506002] RPL Segment Routing with IPv6
[ 0.506006] In-situ OAM (IOAM) with IPv6
[ 0.506016] NET: Registered PF_PACKET protocol family
[ 0.506421] microcode: CPU0: patch_level=0x0a201205
[ 0.506426] microcode: CPU1: patch_level=0x0a201205
[ 0.506431] microcode: CPU2: patch_level=0x0a201205
[ 0.506436] microcode: CPU3: patch_level=0x0a201205
[ 0.506441] microcode: CPU4: patch_level=0x0a201205
[ 0.506446] microcode: CPU5: patch_level=0x0a201205
[ 0.506449] microcode: CPU6: patch_level=0x0a201205
[ 0.506451] microcode: CPU7: patch_level=0x0a201205
[ 0.506455] microcode: CPU8: patch_level=0x0a201205
[ 0.506459] microcode: CPU9: patch_level=0x0a201205
[ 0.506463] microcode: CPU10: patch_level=0x0a201205
[ 0.506467] microcode: CPU11: patch_level=0x0a201205
[ 0.506470] microcode: Microcode Update Driver: v2.2.
[ 0.506532] resctrl: L3 allocation detected
[ 0.506533] resctrl: MB allocation detected
[ 0.506533] resctrl: L3 monitoring detected
[ 0.506535] IPI shorthand broadcast: enabled
[ 0.506543] sched_clock: Marking stable (506312998, 215588)->(692975989, -186447403)
[ 0.506722] registered taskstats version 1
[ 0.506834] Loading compiled-in X.509 certificates
[ 0.508543] Loaded X.509 cert 'Build time autogenerated kernel key: c8773c1d3b09f152ce0bb40682fe739753842995'
[ 0.510476] zswap: loaded using pool zstd/z3fold
[ 0.510575] Key type ._fscrypt registered
[ 0.510576] Key type .fscrypt registered
[ 0.510576] Key type fscrypt-provisioning registered
[ 0.510595] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.511179] PM: Magic number: 10:822:905
[ 0.511283] RAS: Correctable Errors collector initialized.
[ 0.812579] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.284201] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.284543] ata2.00: supports DRM functions and may not be fully accessible
[ 1.284545] ata2.00: ATA-11: Samsung SSD 860 QVO 1TB, RVQ01B6Q, max UDMA/133
[ 1.285127] ata2.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.287523] ata2.00: Features: Trust Dev-Sleep NCQ-sndrcv
[ 1.287788] ata2.00: supports DRM functions and may not be fully accessible
[ 1.290282] ata2.00: configured for UDMA/133
[ 1.290342] tsc: Refined TSC clocksource calibration: 3493.437 MHz
[ 1.290348] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x325b1901053, max_idle_ns: 440795306184 ns
[ 1.290541] clocksource: Switched to clocksource tsc
[ 1.290607] scsi 1:0:0:0: Direct-Access ATA Samsung SSD 860 1B6Q PQ: 0 ANSI: 5
[ 1.290766] ata2.00: Enabling discard_zeroes_data
[ 1.290821] sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.290830] sd 1:0:0:0: [sda] Write Protect is off
[ 1.290833] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.290846] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.291050] ata2.00: Enabling discard_zeroes_data
[ 1.308405] sda: sda1 sda2 sda3
[ 1.308479] ata2.00: Enabling discard_zeroes_data
[ 1.324582] sd 1:0:0:0: [sda] supports TCG Opal
[ 1.324584] sd 1:0:0:0: [sda] Attached SCSI disk
[ 1.604262] ata3: SATA link down (SStatus 0 SControl 300)
[ 2.073966] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.075732] ata4.00: supports DRM functions and may not be fully accessible
[ 2.075736] ata4.00: ATA-9: Samsung SSD 850 EVO 250GB, EMT01B6Q, max UDMA/133
[ 2.076304] ata4.00: NCQ Send/Recv Log not supported
[ 2.076308] ata4.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 2.077857] ata4.00: Features: Trust Dev-Sleep
[ 2.078181] ata4.00: supports DRM functions and may not be fully accessible
[ 2.078533] ata4.00: NCQ Send/Recv Log not supported
[ 2.079811] ata4.00: configured for UDMA/133
[ 2.079939] scsi 3:0:0:0: Direct-Access ATA Samsung SSD 850 1B6Q PQ: 0 ANSI: 5
[ 2.080192] sd 3:0:0:0: [sdb] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[ 2.080199] sd 3:0:0:0: [sdb] Write Protect is off
[ 2.080201] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.080213] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.098252] sdb: sdb1 sdb2 sdb3 sdb4
[ 2.113937] sd 3:0:0:0: [sdb] supports TCG Opal
[ 2.113939] sd 3:0:0:0: [sdb] Attached SCSI disk
[ 3.113941] ata5: failed to resume link (SControl 0)
[ 3.113961] ata5: SATA link down (SStatus 0 SControl 0)
[ 3.427371] ata6: SATA link down (SStatus 0 SControl 330)
[ 3.428566] Freeing unused decrypted memory: 2036K
[ 3.428735] Freeing unused kernel image (initmem) memory: 1856K
[ 3.428738] Write protecting the kernel read-only data: 28672k
[ 3.429023] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 3.429166] Freeing unused kernel image (rodata/data gap) memory: 1220K
[ 3.451184] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 3.451187] rodata_test: all tests were successful
[ 3.451190] Run /init as init process
[ 3.451191] with arguments:
[ 3.451192] /init
[ 3.451192] with environment:
[ 3.451192] HOME=/
[ 3.451193] TERM=linux
[ 3.451193] BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
[ 3.559554] [drm] amdgpu kernel modesetting enabled.
[ 3.564061] amdgpu: Ignoring ACPI CRAT on non-APU system
[ 3.564063] amdgpu: Virtual CRAT table created for CPU
[ 3.564068] amdgpu: Topology: Add CPU node
[ 3.564105] checking generic (d0000000 e10000) vs hw (d0000000 10000000)
[ 3.564107] checking generic (d0000000 e10000) vs hw (d0000000 10000000)
[ 3.564107] fb0: switching to amdgpu from EFI VGA
[ 3.564154] amdgpu 0000:07:00.0: vgaarb: deactivate vga console
[ 3.564210] [drm] initializing kernel modesetting (DIMGREY_CAVEFISH 0x1002:0x73FF 0x1EAE:0x6505 0xC7).
[ 3.564212] amdgpu 0000:07:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 3.564216] [drm] register mmio base: 0xFCD00000
[ 3.564217] [drm] register mmio size: 1048576
[ 3.566647] [drm] add ip block number 0 <nv_common>
[ 3.566648] [drm] add ip block number 1 <gmc_v10_0>
[ 3.566648] [drm] add ip block number 2 <navi10_ih>
[ 3.566649] [drm] add ip block number 3 <psp>
[ 3.566649] [drm] add ip block number 4 <smu>
[ 3.566649] [drm] add ip block number 5 <dm>
[ 3.566650] [drm] add ip block number 6 <gfx_v10_0>
[ 3.566650] [drm] add ip block number 7 <sdma_v5_2>
[ 3.566651] [drm] add ip block number 8 <vcn_v3_0>
[ 3.566651] [drm] add ip block number 9 <jpeg_v3_0>
[ 3.566659] amdgpu 0000:07:00.0: No more image in the PCI ROM
[ 3.566671] amdgpu 0000:07:00.0: amdgpu: Fetched VBIOS from ROM BAR
[ 3.566672] amdgpu: ATOM BIOS: 113-23L86HMD2-D02
[ 3.566676] [drm] VCN(0) decode is enabled in VM mode
[ 3.566677] [drm] VCN(0) encode is enabled in VM mode
[ 3.566678] [drm] JPEG decode is enabled in VM mode
[ 3.566702] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 3.566706] amdgpu 0000:07:00.0: amdgpu: VRAM: 8176M 0x0000008000000000 - 0x00000081FEFFFFFF (8176M used)
[ 3.566707] amdgpu 0000:07:00.0: amdgpu: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
[ 3.566708] amdgpu 0000:07:00.0: amdgpu: AGP: 267894784M 0x0000008400000000 - 0x0000FFFFFFFFFFFF
[ 3.566716] [drm] Detected VRAM RAM=8176M, BAR=256M
[ 3.566716] [drm] RAM width 128bits GDDR6
[ 3.566736] [drm] amdgpu: 8176M of VRAM memory ready
[ 3.566737] [drm] amdgpu: 8176M of GTT memory ready.
[ 3.566741] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 3.566957] [drm] PCIE GART of 512M enabled (table at 0x0000008000E10000).
[ 3.567090] amdgpu 0000:07:00.0: amdgpu: PSP runtime database doesn't exist
[ 6.409462] amdgpu 0000:07:00.0: amdgpu: STB initialized to 2048 entries
[ 6.409536] [drm] Loading DMUB firmware via PSP: version=0x0202000F
[ 6.410022] [drm] use_doorbell being set to: [true]
[ 6.410030] [drm] use_doorbell being set to: [true]
[ 6.410082] [drm] Found VCN firmware Version ENC: 1.20 DEC: 2 VEP: 0 Revision: 5
[ 6.410085] amdgpu 0000:07:00.0: amdgpu: Will use PSP to load VCN firmware
[ 6.480266] [drm] reserve 0xa00000 from 0x81fe000000 for PSP TMR
[ 6.577006] amdgpu 0000:07:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 6.594962] amdgpu 0000:07:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 6.594983] amdgpu 0000:07:00.0: amdgpu: smu driver if version = 0x0000000f, smu fw if version = 0x00000013, smu fw program = 0, version = 0x003b2900 (59.41.0)
[ 6.594985] amdgpu 0000:07:00.0: amdgpu: SMU driver if version not matched
[ 6.594989] amdgpu 0000:07:00.0: amdgpu: use vbios provided pptable
[ 6.646721] amdgpu 0000:07:00.0: amdgpu: SMU is initialized successfully!
[ 6.646881] [drm] Display Core initialized with v3.2.177!
[ 6.648142] [drm] DMUB hardware initialized: version=0x0202000F
[ 6.915081] [drm] REG_WAIT timeout 1us * 100000 tries - mpc2_assert_idle_mpcc line:478
[ 7.178116] [drm] kiq ring mec 2 pipe 1 q 0
[ 7.182777] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 7.183134] [drm] JPEG decode initialized successfully.
[ 7.184573] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 7.219303] memmap_init_zone_device initialised 2097152 pages in 10ms
[ 7.219310] amdgpu: HMM registered 8176MB device memory
[ 7.219538] amdgpu: SRAT table not found
[ 7.219539] amdgpu: Virtual CRAT table created for GPU
[ 7.219711] amdgpu: Topology: Add dGPU node [0x73ff:0x1002]
[ 7.219713] kfd kfd: amdgpu: added device 1002:73ff
[ 7.219733] amdgpu 0000:07:00.0: amdgpu: SE 2, SH per SE 2, CU per SH 8, active_cu_number 28
[ 7.219791] amdgpu 0000:07:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 7.219792] amdgpu 0000:07:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 7.219793] amdgpu 0000:07:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 7.219794] amdgpu 0000:07:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 7.219794] amdgpu 0000:07:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 7.219795] amdgpu 0000:07:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 7.219795] amdgpu 0000:07:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 7.219796] amdgpu 0000:07:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 7.219797] amdgpu 0000:07:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 7.219798] amdgpu 0000:07:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 7.219798] amdgpu 0000:07:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 7.219799] amdgpu 0000:07:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
[ 7.219799] amdgpu 0000:07:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 1
[ 7.219800] amdgpu 0000:07:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 1
[ 7.219801] amdgpu 0000:07:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 1
[ 7.219801] amdgpu 0000:07:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 1
[ 7.221054] [drm] Initialized amdgpu 3.46.0 20150101 for 0000:07:00.0 on minor 0
[ 7.226846] fbcon: amdgpudrmfb (fb0) is primary device
[ 7.226847] fbcon: Deferring console take-over
[ 7.226848] amdgpu 0000:07:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 7.289953] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 7.289960] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 7.345243] xhci_hcd 0000:01:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000410
[ 7.345445] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 7.345447] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 7.345449] xhci_hcd 0000:01:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.345490] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
[ 7.345491] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.345492] usb usb1: Product: xHCI Host Controller
[ 7.345493] usb usb1: Manufacturer: Linux 5.18.6-1-MANJARO xhci-hcd
[ 7.345494] usb usb1: SerialNumber: 0000:01:00.0
[ 7.345540] hub 1-0:1.0: USB hub found
[ 7.345554] hub 1-0:1.0: 10 ports detected
[ 7.345680] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 7.345689] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
[ 7.345690] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.345691] usb usb2: Product: xHCI Host Controller
[ 7.345692] usb usb2: Manufacturer: Linux 5.18.6-1-MANJARO xhci-hcd
[ 7.345692] usb usb2: SerialNumber: 0000:01:00.0
[ 7.345724] hub 2-0:1.0: USB hub found
[ 7.345731] hub 2-0:1.0: 4 ports detected
[ 7.345844] xhci_hcd 0000:09:00.3: xHCI Host Controller
[ 7.345846] xhci_hcd 0000:09:00.3: new USB bus registered, assigned bus number 3
[ 7.345947] xhci_hcd 0000:09:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 7.346111] xhci_hcd 0000:09:00.3: xHCI Host Controller
[ 7.346112] xhci_hcd 0000:09:00.3: new USB bus registered, assigned bus number 4
[ 7.346113] xhci_hcd 0000:09:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.346129] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
[ 7.346130] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.346131] usb usb3: Product: xHCI Host Controller
[ 7.346131] usb usb3: Manufacturer: Linux 5.18.6-1-MANJARO xhci-hcd
[ 7.346132] usb usb3: SerialNumber: 0000:09:00.3
[ 7.346201] hub 3-0:1.0: USB hub found
[ 7.346206] hub 3-0:1.0: 4 ports detected
[ 7.346331] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 7.346340] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
[ 7.346341] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.346341] usb usb4: Product: xHCI Host Controller
[ 7.346342] usb usb4: Manufacturer: Linux 5.18.6-1-MANJARO xhci-hcd
[ 7.346343] usb usb4: SerialNumber: 0000:09:00.3
[ 7.346419] hub 4-0:1.0: USB hub found
[ 7.346424] hub 4-0:1.0: 4 ports detected
[ 7.514235] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
[ 7.593659] usb 3-3: new high-speed USB device number 2 using xhci_hcd
[ 7.593665] usb 1-9: new full-speed USB device number 2 using xhci_hcd
[ 7.676062] systemd[1]: systemd 251.2-3-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 7.676065] systemd[1]: Detected architecture x86-64.
[ 7.678108] systemd[1]: Hostname set to <basil-z97nwifi>.
[ 7.741880] usb 3-3: New USB device found, idVendor=174c, idProduct=2074, bcdDevice= 2.00
[ 7.741883] usb 3-3: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 7.741885] usb 3-3: Product: ASM107x
[ 7.741886] usb 3-3: Manufacturer: Asmedia
[ 7.794407] hub 3-3:1.0: USB hub found
[ 7.795016] hub 3-3:1.0: 4 ports detected
[ 7.812196] systemd[1]: Queued start job for default target Graphical Interface.
[ 7.812935] systemd[1]: Created slice Slice /system/getty.
[ 7.813087] systemd[1]: Created slice Slice /system/maia-console.
[ 7.813211] systemd[1]: Created slice Slice /system/modprobe.
[ 7.813330] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 7.813452] systemd[1]: Created slice User and Session Slice.
[ 7.813481] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 7.813500] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.813566] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.813581] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.813588] systemd[1]: Reached target Login Prompts.
[ 7.813595] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 7.813606] systemd[1]: Reached target Path Units.
[ 7.813613] systemd[1]: Reached target Remote File Systems.
[ 7.813618] systemd[1]: Reached target Slice Units.
[ 7.813626] systemd[1]: Reached target Swaps.
[ 7.813633] systemd[1]: Reached target Local Verity Protected Volumes.
[ 7.813666] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.813708] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.814361] systemd[1]: Listening on Process Core Dump Socket.
[ 7.814673] systemd[1]: Listening on Journal Audit Socket.
[ 7.814722] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.814767] systemd[1]: Listening on Journal Socket.
[ 7.815896] systemd[1]: Listening on udev Control Socket.
[ 7.815936] systemd[1]: Listening on udev Kernel Socket.
[ 7.816312] systemd[1]: Mounting Huge Pages File System...
[ 7.816700] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.817404] systemd[1]: Mounting Kernel Debug File System...
[ 7.817723] systemd[1]: Mounting Kernel Trace File System...
[ 7.818066] systemd[1]: Starting Load AppArmor profiles...
[ 7.818443] systemd[1]: Starting Create List of Static Device Nodes...
[ 7.818806] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 7.819158] systemd[1]: Starting Load Kernel Module configfs...
[ 7.819493] systemd[1]: Starting Load Kernel Module drm...
[ 7.819835] systemd[1]: Starting Load Kernel Module fuse...
[ 7.819869] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 7.820589] systemd[1]: Starting Journal Service...
[ 7.822066] systemd[1]: Starting Load Kernel Modules...
[ 7.822393] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.822423] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 7.822780] systemd[1]: Starting Coldplug All udev Devices...
[ 7.823326] systemd[1]: Mounted Huge Pages File System.
[ 7.823363] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.823397] systemd[1]: Mounted Kernel Debug File System.
[ 7.823428] systemd[1]: Mounted Kernel Trace File System.
[ 7.823502] systemd[1]: Finished Create List of Static Device Nodes.
[ 7.823636] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 7.823690] systemd[1]: Finished Load Kernel Module configfs.
[ 7.823789] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 7.823834] systemd[1]: Finished Load Kernel Module drm.
[ 7.824195] systemd[1]: Mounting Kernel Configuration File System...
[ 7.825570] systemd[1]: Mounted Kernel Configuration File System.
[ 7.827785] EXT4-fs (sda3): re-mounted. Quota mode: none.
[ 7.828086] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 7.828144] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 7.832141] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 7.832580] systemd[1]: Starting Load/Save Random Seed...
[ 7.832618] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 7.833046] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 7.833787] fuse: init (API version 7.36)
[ 7.834100] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 7.834186] systemd[1]: Finished Load Kernel Module fuse.
[ 7.834223] audit: type=1130 audit(1656625992.835:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.834230] audit: type=1131 audit(1656625992.835:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.834819] systemd[1]: Mounting FUSE Control File System...
[ 7.835921] systemd[1]: Finished Load Kernel Modules.
[ 7.835945] audit: type=1130 audit(1656625992.835:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.836437] systemd[1]: Starting Apply Kernel Variables...
[ 7.838897] systemd[1]: Mounted FUSE Control File System.
[ 7.850952] systemd[1]: Started Journal Service.
[ 7.850992] audit: type=1130 audit(1656625992.851:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.852437] audit: type=1130 audit(1656625992.851:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.856664] audit: type=1130 audit(1656625992.855:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.860148] systemd-journald[345]: Received client request to flush runtime journal.
[ 7.863739] usb 4-3: new SuperSpeed USB device number 2 using xhci_hcd
[ 7.878264] audit: type=1130 audit(1656625992.878:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.885189] usb 4-3: New USB device found, idVendor=174c, idProduct=3074, bcdDevice= 2.00
[ 7.885192] usb 4-3: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 7.885193] usb 4-3: Product: ASM107x
[ 7.885194] usb 4-3: Manufacturer: Asmedia
[ 7.892711] audit: type=1325 audit(1656625992.888:9): table=filter family=2 entries=0 op=xt_register pid=364 subj==unconfined comm="iptables"
[ 7.892783] audit: type=1300 audit(1656625992.888:9): arch=c000003e syscall=55 success=yes exit=0 a0=4 a1=0 a2=40 a3=7ffc88e8f1e0 items=0 ppid=363 pid=364 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj==unconfined key=(null)
[ 7.892785] audit: type=1327 audit(1656625992.888:9): proctitle=69707461626C6573002D4C007566772D757365722D696E707574002D6E
[ 7.906342] hub 4-3:1.0: USB hub found
[ 7.906460] hub 4-3:1.0: 4 ports detected
[ 7.991747] usb 1-9: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ 7.991752] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.083385] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 8.083390] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 8.085231] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 8.100064] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 8.100137] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 8.100188] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 8.103830] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 8.107078] ccp 0000:09:00.1: enabling device (0000 -> 0002)
[ 8.107172] ccp 0000:09:00.1: ccp: unable to access the device: you might be running a broken BIOS.
[ 8.117328] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 8.117331] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 8.120852] Intel(R) 2.5G Ethernet Linux Driver
[ 8.120854] Copyright(c) 2018 Intel Corporation.
[ 8.120955] igc 0000:03:00.0: PCIe PTM not supported by PCIe bus/controller
[ 8.121424] cryptd: max_cpu_qlen set to 1000
[ 8.170325] usb 3-3.2: new high-speed USB device number 3 using xhci_hcd
[ 8.174014] pps pps0: new PPS source ptp0
[ 8.174039] igc 0000:03:00.0 (unnamed net_device) (uninitialized): PHC added
[ 8.193668] usb 1-10: new full-speed USB device number 3 using xhci_hcd
[ 8.200940] AVX2 version of gcm_enc/dec engaged.
[ 8.200977] AES CTR mode by8 optimization enabled
[ 8.201732] igc 0000:03:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[ 8.201735] igc 0000:03:00.0 eth0: MAC: 70:85:c2:97:5f:1a
[ 8.213195] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.215743] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.282759] usb 3-3.2: New USB device found, idVendor=0781, idProduct=5567, bcdDevice= 1.27
[ 8.282763] usb 3-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.282765] usb 3-3.2: Product: Cruzer Blade
[ 8.282766] usb 3-3.2: Manufacturer: SanDisk
[ 8.282768] usb 3-3.2: SerialNumber: 4C530001120509110421
[ 8.289251] igc 0000:03:00.0 enp3s0: renamed from eth0
[ 8.298546] Intel(R) Wireless WiFi driver for Linux
[ 8.298614] iwlwifi 0000:04:00.0: enabling device (0000 -> 0002)
[ 8.302338] iwlwifi 0000:04:00.0: Direct firmware load for iwlwifi-cc-a0-72.ucode failed with error -2
[ 8.306499] iwlwifi 0000:04:00.0: api flags index 2 larger than supported by driver
[ 8.306510] iwlwifi 0000:04:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 8.306689] iwlwifi 0000:04:00.0: loaded firmware version 71.058653f6.0 cc-a0-71.ucode op_mode iwlmvm
[ 8.347483] snd_hda_intel 0000:07:00.1: Handle vga_switcheroo audio client
[ 8.347487] snd_hda_intel 0000:07:00.1: Force to non-snoop mode
[ 8.347722] snd_hda_intel 0000:09:00.4: enabling device (0000 -> 0002)
[ 8.371427] snd_hda_intel 0000:07:00.1: bound 0000:07:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 8.376856] usb 3-3.3: new full-speed USB device number 4 using xhci_hcd
[ 8.376959] SVM: TSC scaling supported
[ 8.376971] kvm: Nested Virtualization enabled
[ 8.376972] SVM: kvm: Nested Paging enabled
[ 8.377032] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:05:00.0/0000:06:00.0/0000:07:00.1/sound/card0/input3
[ 8.377077] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:05:00.0/0000:06:00.0/0000:07:00.1/sound/card0/input4
[ 8.377109] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:05:00.0/0000:06:00.0/0000:07:00.1/sound/card0/input5
[ 8.377119] SVM: Virtual VMLOAD VMSAVE supported
[ 8.377120] SVM: Virtual GIF supported
[ 8.377121] SVM: LBR virtualization supported
[ 8.377138] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:05:00.0/0000:06:00.0/0000:07:00.1/sound/card0/input6
[ 8.377173] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:05:00.0/0000:06:00.0/0000:07:00.1/sound/card0/input7
[ 8.385187] MCE: In-kernel MCE decoding enabled.
[ 8.390887] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 8.390891] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 8.390893] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 8.390894] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 8.390895] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 8.390896] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 8.390898] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 8.390899] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 8.437709] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input8
[ 8.437751] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input9
[ 8.437782] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input10
[ 8.437817] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input11
[ 8.437861] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:09:00.4/sound/card1/input12
[ 8.493737] i2c i2c-0: adapter quirk: no zero length (addr 0x0018, size 0, write)
[ 8.493741] i2c i2c-0: adapter quirk: no zero length (addr 0x0019, size 0, write)
[ 8.493743] i2c i2c-0: adapter quirk: no zero length (addr 0x001a, size 0, write)
[ 8.493745] i2c i2c-0: adapter quirk: no zero length (addr 0x0029, size 0, write)
[ 8.493747] i2c i2c-0: adapter quirk: no zero length (addr 0x002a, size 0, write)
[ 8.493748] i2c i2c-0: adapter quirk: no zero length (addr 0x002b, size 0, write)
[ 8.493749] i2c i2c-0: adapter quirk: no zero length (addr 0x004c, size 0, write)
[ 8.493750] i2c i2c-0: adapter quirk: no zero length (addr 0x004d, size 0, write)
[ 8.493751] i2c i2c-0: adapter quirk: no zero length (addr 0x004e, size 0, write)
[ 8.493753] i2c i2c-1: adapter quirk: no zero length (addr 0x0018, size 0, write)
[ 8.493928] iwlwifi 0000:04:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 8.493968] thermal thermal_zone0: failed to read out thermal zone (-61)
[ 8.520931] intel_rapl_common: Found RAPL domain package
[ 8.520933] intel_rapl_common: Found RAPL domain core
[ 8.522496] usb 1-10: New USB device found, idVendor=26ce, idProduct=01a2, bcdDevice= 0.00
[ 8.522498] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.522499] usb 1-10: Product: LED Controller
[ 8.522500] usb 1-10: Manufacturer: ASRock
[ 8.522501] usb 1-10: SerialNumber: A02019100900
[ 8.525270] nct6775: Found NCT6792D or compatible chip at 0x2e:0x290
[ 8.615474] iwlwifi 0000:04:00.0: Detected RF HR B3, rfid=0x10a100
[ 8.655460] [drm] DSC precompute is not needed.
[ 8.680888] iwlwifi 0000:04:00.0: base HW address: 78:2b:46:b3:af:1f
[ 8.693746] iwlwifi 0000:04:00.0: iwlmvm doesn't allow to disable BT Coex, check bt_coex_active module parameter
[ 8.695059] iwlwifi 0000:04:00.0 wlp4s0: renamed from wlan0
[ 8.731742] NET: Registered PF_QIPCRTR protocol family
[ 8.844183] loop: module loaded
[ 8.844753] loop0: detected capacity change from 0 to 8
[ 8.851026] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 8.924764] [drm] REG_WAIT timeout 1us * 100000 tries - mpc2_assert_idle_mpcc line:478
[ 8.960778] ahci 0000:01:00.1: port does not support device sleep
[ 8.960849] ahci 0000:01:00.1: port does not support device sleep
[ 9.062073] ACPI: \: failed to evaluate _DSM (0x1001)
[ 9.062076] ACPI: \: failed to evaluate _DSM (0x1001)
[ 9.062077] ACPI: \: failed to evaluate _DSM (0x1001)
[ 9.062078] ACPI: \: failed to evaluate _DSM (0x1001)
[ 9.062079] ACPI: \: failed to evaluate _DSM (0x1001)
[ 9.267070] ACPI: \: failed to evaluate _DSM (0x1001)
[ 9.267073] ACPI: \: failed to evaluate _DSM (0x1001)
[ 9.267075] ACPI: \: failed to evaluate _DSM (0x1001)
[ 9.267076] ACPI: \: failed to evaluate _DSM (0x1001)
[ 9.267077] ACPI: \: failed to evaluate _DSM (0x1001)
[ 9.613608] input: ASRock LED Controller as /devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-10/1-10:1.0/0003:26CE:01A2.0001/input/input13
[ 9.629521] Bluetooth: Core ver 2.22
[ 9.629533] NET: Registered PF_BLUETOOTH protocol family
[ 9.629533] Bluetooth: HCI device and connection manager initialized
[ 9.629536] Bluetooth: HCI socket layer initialized
[ 9.629537] Bluetooth: L2CAP socket layer initialized
[ 9.629539] Bluetooth: SCO socket layer initialized
[ 9.670388] hid-generic 0003:26CE:01A2.0001: input,hidraw0: USB HID v1.10 Device [ASRock LED Controller] on usb-0000:01:00.0-10/input0
[ 9.670411] usbcore: registered new interface driver usbhid
[ 9.670412] usbhid: USB HID core driver
[ 9.687340] usbcore: registered new interface driver btusb
[ 9.707693] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[ 9.707710] Bluetooth: hci0: Boot Address: 0x24800
[ 9.707712] Bluetooth: hci0: Firmware Version: 255-255.255
[ 9.711600] usb 1-9: USB disconnect, device number 2
[ 9.712255] Bluetooth: hci0: FW download error recovery failed (-19)
[ 9.712267] Bluetooth: hci0: sending frame failed (-19)
[ 9.712272] Bluetooth: hci0: Failed to read MSFT supported features (-19)
[ 9.724106] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.724108] Bluetooth: BNEP filters: protocol multicast
[ 9.724110] Bluetooth: BNEP socket layer initialized
[ 10.140333] usb 1-9: new full-speed USB device number 4 using xhci_hcd
[ 10.535704] usb 1-9: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ 10.535709] usb 1-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 10.554545] Bluetooth: hci0: Bootloader revision 0.3 build 0 week 24 2017
[ 10.559548] Bluetooth: hci0: Device revision is 1
[ 10.559550] Bluetooth: hci0: Secure boot is enabled
[ 10.559551] Bluetooth: hci0: OTP lock is enabled
[ 10.559551] Bluetooth: hci0: API lock is enabled
[ 10.559552] Bluetooth: hci0: Debug lock is disabled
[ 10.559553] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 10.559732] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[ 10.559740] Bluetooth: hci0: Boot Address: 0x24800
[ 10.559741] Bluetooth: hci0: Firmware Version: 255-255.255
[ 11.660987] igc 0000:03:00.0 enp3s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 11.661185] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 12.636991] usb 3-3.3: New USB device found, idVendor=1b1c, idProduct=1b13, bcdDevice= 3.08
[ 12.636996] usb 3-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 12.636998] usb 3-3.3: Product: Corsair K70 RGB Gaming Keyboard
[ 12.637000] usb 3-3.3: Manufacturer: Corsair
[ 12.637001] usb 3-3.3: SerialNumber: 1400701CAE3D8C8153AA2CEFF5001941
[ 13.153685] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 13.228654] kauditd_printk_skb: 156 callbacks suppressed
[ 13.228655] audit: type=1325 audit(1656625998.228:102): table=nat family=2 entries=0 op=xt_register pid=1164 subj==unconfined comm="iptables"
[ 13.228659] audit: type=1300 audit(1656625998.228:102): arch=c000003e syscall=55 success=yes exit=0 a0=4 a1=0 a2=40 a3=7ffc6a0bbcd0 items=0 ppid=659 pid=1164 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj==unconfined key=(null)
[ 13.228662] audit: type=1327 audit(1656625998.228:102): proctitle=2F7573722F62696E2F69707461626C6573002D2D7461626C65006E6174002D2D696E7365727400504F5354524F5554494E47002D2D736F757263650031302E34322E302E302F32340000002D2D64657374696E6174696F6E0031302E34322E302E302F3234002D2D6A756D70004D415351554552414445002D6D00636F6D6D65
[ 13.228687] audit: type=1325 audit(1656625998.228:103): table=nat family=2 entries=5 op=xt_replace pid=1164 subj==unconfined comm="iptables"
[ 13.228693] audit: type=1300 audit(1656625998.228:103): arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=55b6d59927e0 items=0 ppid=659 pid=1164 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj==unconfined key=(null)
[ 13.228694] audit: type=1327 audit(1656625998.228:103): proctitle=2F7573722F62696E2F69707461626C6573002D2D7461626C65006E6174002D2D696E7365727400504F5354524F5554494E47002D2D736F757263650031302E34322E302E302F32340000002D2D64657374696E6174696F6E0031302E34322E302E302F3234002D2D6A756D70004D415351554552414445002D6D00636F6D6D65
[ 13.229526] audit: type=1325 audit(1656625998.228:104): table=filter family=2 entries=139 op=xt_replace pid=1167 subj==unconfined comm="iptables"
[ 13.229549] audit: type=1300 audit(1656625998.228:104): arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=5615a0620810 items=0 ppid=659 pid=1167 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj==unconfined key=(null)
[ 13.229551] audit: type=1327 audit(1656625998.228:104): proctitle=2F7573722F62696E2F69707461626C6573002D2D7461626C650066696C746572002D2D6E65772D636861696E006E6D2D73682D696E2D776C70347330
[ 13.230414] audit: type=1325 audit(1656625998.231:105): table=filter family=2 entries=141 op=xt_replace pid=1168 subj==unconfined comm="iptables"
[ 13.583963] input: Corsair Corsair K70 RGB Gaming Keyboard Keyboard as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-3/3-3.3/3-3.3:1.0/0003:1B1C:1B13.0002/input/input14
[ 13.640408] input: Corsair Corsair K70 RGB Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-3/3-3.3/3-3.3:1.0/0003:1B1C:1B13.0002/input/input15
[ 13.640441] input: Corsair Corsair K70 RGB Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-3/3-3.3/3-3.3:1.0/0003:1B1C:1B13.0002/input/input16
[ 13.640531] hid-generic 0003:1B1C:1B13.0002: input,hiddev96,hidraw1: USB HID v1.11 Keyboard [Corsair Corsair K70 RGB Gaming Keyboard ] on usb-0000:09:00.3-3.3/input0
[ 14.260486] hid-generic 0003:1B1C:1B13.0003: hiddev97,hidraw2: USB HID v1.11 Device [Corsair Corsair K70 RGB Gaming Keyboard ] on usb-0000:09:00.3-3.3/input1
[ 14.353654] usb 3-3.4: new full-speed USB device number 5 using xhci_hcd
[ 14.483144] usb 3-3.4: New USB device found, idVendor=1b1c, idProduct=1b05, bcdDevice= 2.26
[ 14.483148] usb 3-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 14.483150] usb 3-3.4: Product: Corsair M65 Gaming Mouse
[ 14.483151] usb 3-3.4: Manufacturer: Corsair
[ 14.616235] input: Corsair Corsair M65 Gaming Mouse as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-3/3-3.4/3-3.4:1.0/0003:1B1C:1B05.0004/input/input17
[ 14.616296] hid-generic 0003:1B1C:1B05.0004: input,hidraw3: USB HID v1.11 Mouse [Corsair Corsair M65 Gaming Mouse] on usb-0000:09:00.3-3.4/input0
[ 14.621269] input: Corsair Corsair M65 Gaming Mouse as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-3/3-3.4/3-3.4:1.1/0003:1B1C:1B05.0005/input/input18
[ 14.677044] hid-generic 0003:1B1C:1B05.0005: input,hidraw4: USB HID v1.11 Keyboard [Corsair Corsair M65 Gaming Mouse] on usb-0000:09:00.3-3.4/input1
[ 14.680334] input: Corsair Corsair M65 Gaming Mouse as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-3/3-3.4/3-3.4:1.2/0003:1B1C:1B05.0006/input/input19
[ 14.737042] hid-generic 0003:1B1C:1B05.0006: input,hidraw5: USB HID v1.11 Device [Corsair Corsair M65 Gaming Mouse] on usb-0000:09:00.3-3.4/input2
[ 15.377885] Bluetooth: hci0: Waiting for firmware download to complete
[ 15.378577] Bluetooth: hci0: Firmware loaded in 4705902 usecs
[ 15.378606] Bluetooth: hci0: Waiting for device to boot
[ 15.396827] Bluetooth: hci0: Device booted in 17805 usecs
[ 15.396831] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[ 15.398399] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-20-1-3.ddc
[ 15.407656] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 15.412628] Bluetooth: hci0: Firmware revision 0.3 build 118 week 17 2022
[ 15.653033] NET: Registered PF_ALG protocol family
[ 15.792059] mousedev: PS/2 mouse device common for all mice
[ 15.864432] usb-storage 3-3.2:1.0: USB Mass Storage device detected
[ 15.864626] scsi host6: usb-storage 3-3.2:1.0
[ 15.864703] usbcore: registered new interface driver usb-storage
[ 15.869538] usbcore: registered new interface driver uas
[ 16.891393] scsi 6:0:0:0: Direct-Access SanDisk Cruzer Blade 1.27 PQ: 0 ANSI: 6
[ 16.894205] sd 6:0:0:0: [sdc] 122107136 512-byte logical blocks: (62.5 GB/58.2 GiB)
[ 16.894572] sd 6:0:0:0: [sdc] Write Protect is off
[ 16.894576] sd 6:0:0:0: [sdc] Mode Sense: 43 00 00 00
[ 16.894950] sd 6:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 16.899748] sdc: sdc1
[ 16.902434] sd 6:0:0:0: [sdc] Attached SCSI removable disk
[ 17.234492] iwlwifi 0000:04:00.0: Microcode SW error detected. Restarting 0x0.
[ 17.234624] iwlwifi 0000:04:00.0: Start IWL Error Log Dump:
[ 17.234625] iwlwifi 0000:04:00.0: Transport status: 0x0000004A, valid: 6
[ 17.234627] iwlwifi 0000:04:00.0: Loaded firmware version: 71.058653f6.0 cc-a0-71.ucode
[ 17.234629] iwlwifi 0000:04:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 17.234630] iwlwifi 0000:04:00.0: 0x00A022F0 | trm_hw_status0
[ 17.234631] iwlwifi 0000:04:00.0: 0x00000000 | trm_hw_status1
[ 17.234632] iwlwifi 0000:04:00.0: 0x004FB4C6 | branchlink2
[ 17.234633] iwlwifi 0000:04:00.0: 0x00019C4C | interruptlink1
[ 17.234634] iwlwifi 0000:04:00.0: 0x00019C4C | interruptlink2
[ 17.234635] iwlwifi 0000:04:00.0: 0x00014DC6 | data1
[ 17.234635] iwlwifi 0000:04:00.0: 0x00001000 | data2
[ 17.234636] iwlwifi 0000:04:00.0: 0x00000000 | data3
[ 17.234637] iwlwifi 0000:04:00.0: 0x00000000 | beacon time
[ 17.234638] iwlwifi 0000:04:00.0: 0x007BF041 | tsf low
[ 17.234639] iwlwifi 0000:04:00.0: 0x00000000 | tsf hi
[ 17.234639] iwlwifi 0000:04:00.0: 0x00000000 | time gp1
[ 17.234640] iwlwifi 0000:04:00.0: 0x007C4968 | time gp2
[ 17.234641] iwlwifi 0000:04:00.0: 0x00000001 | uCode revision type
[ 17.234642] iwlwifi 0000:04:00.0: 0x00000047 | uCode version major
[ 17.234642] iwlwifi 0000:04:00.0: 0x058653F6 | uCode version minor
[ 17.234643] iwlwifi 0000:04:00.0: 0x00000340 | hw version
[ 17.234644] iwlwifi 0000:04:00.0: 0x18C89000 | board version
[ 17.234645] iwlwifi 0000:04:00.0: 0x0300001C | hcmd
[ 17.234646] iwlwifi 0000:04:00.0: 0x00021000 | isr0
[ 17.234646] iwlwifi 0000:04:00.0: 0x00040000 | isr1
[ 17.234647] iwlwifi 0000:04:00.0: 0x08F80002 | isr2
[ 17.234648] iwlwifi 0000:04:00.0: 0x00C3400D | isr3
[ 17.234649] iwlwifi 0000:04:00.0: 0x00000000 | isr4
[ 17.234649] iwlwifi 0000:04:00.0: 0x00520103 | last cmd Id
[ 17.234650] iwlwifi 0000:04:00.0: 0x00014DC6 | wait_event
[ 17.234651] iwlwifi 0000:04:00.0: 0x000000B4 | l2p_control
[ 17.234652] iwlwifi 0000:04:00.0: 0x00000000 | l2p_duration
[ 17.234652] iwlwifi 0000:04:00.0: 0x0000000F | l2p_mhvalid
[ 17.234653] iwlwifi 0000:04:00.0: 0x00000000 | l2p_addr_match
[ 17.234654] iwlwifi 0000:04:00.0: 0x00000009 | lmpm_pmg_sel
[ 17.234655] iwlwifi 0000:04:00.0: 0x00000000 | timestamp
[ 17.234655] iwlwifi 0000:04:00.0: 0x00005898 | flow_handler
[ 17.234728] iwlwifi 0000:04:00.0: Start IWL Error Log Dump:
[ 17.234729] iwlwifi 0000:04:00.0: Transport status: 0x0000004A, valid: 7
[ 17.234730] iwlwifi 0000:04:00.0: 0x20003207 | ADVANCED_SYSASSERT
[ 17.234731] iwlwifi 0000:04:00.0: 0x00000000 | umac branchlink1
[ 17.234732] iwlwifi 0000:04:00.0: 0x80455B2C | umac branchlink2
[ 17.234733] iwlwifi 0000:04:00.0: 0xC0081200 | umac interruptlink1
[ 17.234734] iwlwifi 0000:04:00.0: 0x00000000 | umac interruptlink2
[ 17.234735] iwlwifi 0000:04:00.0: 0x003DC92F | umac data1
[ 17.234735] iwlwifi 0000:04:00.0: 0xDEADBEEF | umac data2
[ 17.234736] iwlwifi 0000:04:00.0: 0xDEADBEEF | umac data3
[ 17.234737] iwlwifi 0000:04:00.0: 0x00000047 | umac major
[ 17.234738] iwlwifi 0000:04:00.0: 0x058653F6 | umac minor
[ 17.234738] iwlwifi 0000:04:00.0: 0x007C4962 | frame pointer
[ 17.234739] iwlwifi 0000:04:00.0: 0xC0885E64 | stack pointer
[ 17.234740] iwlwifi 0000:04:00.0: 0x00520103 | last host cmd
[ 17.234741] iwlwifi 0000:04:00.0: 0x00000000 | isr status reg
[ 17.234756] iwlwifi 0000:04:00.0: IML/ROM dump:
[ 17.234757] iwlwifi 0000:04:00.0: 0x00000003 | IML/ROM error/state
[ 17.234772] iwlwifi 0000:04:00.0: 0x00005802 | IML/ROM data1
[ 17.234787] iwlwifi 0000:04:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 17.234796] iwlwifi 0000:04:00.0: Fseq Registers:
[ 17.234799] iwlwifi 0000:04:00.0: 0x60000041 | FSEQ_ERROR_CODE
[ 17.234804] iwlwifi 0000:04:00.0: 0x00290021 | FSEQ_TOP_INIT_VERSION
[ 17.234808] iwlwifi 0000:04:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 17.234812] iwlwifi 0000:04:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 17.234816] iwlwifi 0000:04:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 17.234820] iwlwifi 0000:04:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 17.234824] iwlwifi 0000:04:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 17.234828] iwlwifi 0000:04:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 17.234832] iwlwifi 0000:04:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 17.234838] iwlwifi 0000:04:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 17.234844] iwlwifi 0000:04:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 17.234850] iwlwifi 0000:04:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 17.235078] iwlwifi 0000:04:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 17.235081] ieee80211 phy0: Hardware restart was requested
[ 18.263956] ACPI: \: failed to evaluate _DSM (0x1001)
[ 18.263959] ACPI: \: failed to evaluate _DSM (0x1001)
[ 18.263960] ACPI: \: failed to evaluate _DSM (0x1001)
[ 18.263961] ACPI: \: failed to evaluate _DSM (0x1001)
[ 18.263962] ACPI: \: failed to evaluate _DSM (0x1001)
[ 18.263963] ACPI: \: failed to evaluate _DSM (0x1001)
[ 18.802290] kauditd_printk_skb: 36 callbacks suppressed
[ 18.802293] audit: type=1131 audit(1656626003.805:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 18.941853] audit: type=1100 audit(1656626003.941:119): pid=1122 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 18.941998] audit: type=1101 audit(1656626003.941:120): pid=1122 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 19.022129] audit: type=1106 audit(1656626004.021:121): pid=1032 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 19.022152] audit: type=1104 audit(1656626004.021:122): pid=1032 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 19.024081] audit: type=1103 audit(1656626004.025:123): pid=1122 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="basilmari" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 19.024133] audit: type=1006 audit(1656626004.025:124): pid=1122 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 19.024140] audit: type=1300 audit(1656626004.025:124): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffcb8047fd0 a2=4 a3=7ffcb8047ce4 items=0 ppid=675 pid=1122 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="lightdm" exe="/usr/bin/lightdm" subj==unconfined key=(null)
[ 19.024143] audit: type=1327 audit(1656626004.025:124): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003132003139
[ 19.031583] audit: type=1130 audit(1656626004.031:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.016685] Bluetooth: RFCOMM TTY layer initialized
[ 20.016690] Bluetooth: RFCOMM socket layer initialized
[ 20.016692] Bluetooth: RFCOMM ver 1.11
[ 22.377601] iwlwifi 0000:04:00.0: Microcode SW error detected. Restarting 0x0.
[ 22.377717] iwlwifi 0000:04:00.0: Start IWL Error Log Dump:
[ 22.377719] iwlwifi 0000:04:00.0: Transport status: 0x0000004A, valid: 6
[ 22.377720] iwlwifi 0000:04:00.0: Loaded firmware version: 71.058653f6.0 cc-a0-71.ucode
[ 22.377722] iwlwifi 0000:04:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 22.377724] iwlwifi 0000:04:00.0: 0x000022F0 | trm_hw_status0
[ 22.377725] iwlwifi 0000:04:00.0: 0x00000000 | trm_hw_status1
[ 22.377726] iwlwifi 0000:04:00.0: 0x004FB4C6 | branchlink2
[ 22.377726] iwlwifi 0000:04:00.0: 0x004FCA66 | interruptlink1
[ 22.377727] iwlwifi 0000:04:00.0: 0x004FCA66 | interruptlink2
[ 22.377728] iwlwifi 0000:04:00.0: 0x004F4766 | data1
[ 22.377729] iwlwifi 0000:04:00.0: 0x00001000 | data2
[ 22.377730] iwlwifi 0000:04:00.0: 0x00000000 | data3
[ 22.377730] iwlwifi 0000:04:00.0: 0x00000000 | beacon time
[ 22.377731] iwlwifi 0000:04:00.0: 0x00415F39 | tsf low
[ 22.377732] iwlwifi 0000:04:00.0: 0x00000000 | tsf hi
[ 22.377733] iwlwifi 0000:04:00.0: 0x00000000 | time gp1
[ 22.377733] iwlwifi 0000:04:00.0: 0x0041BAAD | time gp2
[ 22.377734] iwlwifi 0000:04:00.0: 0x00000001 | uCode revision type
[ 22.377735] iwlwifi 0000:04:00.0: 0x00000047 | uCode version major
[ 22.377736] iwlwifi 0000:04:00.0: 0x058653F6 | uCode version minor
[ 22.377737] iwlwifi 0000:04:00.0: 0x00000340 | hw version
[ 22.377737] iwlwifi 0000:04:00.0: 0x18C89000 | board version
[ 22.377738] iwlwifi 0000:04:00.0: 0x8014FC04 | hcmd
[ 22.377739] iwlwifi 0000:04:00.0: 0x00020000 | isr0
[ 22.377740] iwlwifi 0000:04:00.0: 0x00000000 | isr1
[ 22.377741] iwlwifi 0000:04:00.0: 0x08B00002 | isr2
[ 22.377741] iwlwifi 0000:04:00.0: 0x00C3000C | isr3
[ 22.377742] iwlwifi 0000:04:00.0: 0x00000000 | isr4
[ 22.377743] iwlwifi 0000:04:00.0: 0x001C0103 | last cmd Id
[ 22.377743] iwlwifi 0000:04:00.0: 0x004F4766 | wait_event
[ 22.377744] iwlwifi 0000:04:00.0: 0x00000000 | l2p_control
[ 22.377745] iwlwifi 0000:04:00.0: 0x00000020 | l2p_duration
[ 22.377746] iwlwifi 0000:04:00.0: 0x00000000 | l2p_mhvalid
[ 22.377746] iwlwifi 0000:04:00.0: 0x00000000 | l2p_addr_match
[ 22.377747] iwlwifi 0000:04:00.0: 0x00000009 | lmpm_pmg_sel
[ 22.377748] iwlwifi 0000:04:00.0: 0x00000000 | timestamp
[ 22.377749] iwlwifi 0000:04:00.0: 0x00003070 | flow_handler
[ 22.377858] iwlwifi 0000:04:00.0: Start IWL Error Log Dump:
[ 22.377859] iwlwifi 0000:04:00.0: Transport status: 0x0000004A, valid: 7
[ 22.377859] iwlwifi 0000:04:00.0: 0x20003207 | ADVANCED_SYSASSERT
[ 22.377860] iwlwifi 0000:04:00.0: 0x00000000 | umac branchlink1
[ 22.377861] iwlwifi 0000:04:00.0: 0x80455B2C | umac branchlink2
[ 22.377862] iwlwifi 0000:04:00.0: 0xC0081200 | umac interruptlink1
[ 22.377862] iwlwifi 0000:04:00.0: 0x00000000 | umac interruptlink2
[ 22.377863] iwlwifi 0000:04:00.0: 0x00033A76 | umac data1
[ 22.377863] iwlwifi 0000:04:00.0: 0xDEADBEEF | umac data2
[ 22.377864] iwlwifi 0000:04:00.0: 0xDEADBEEF | umac data3
[ 22.377865] iwlwifi 0000:04:00.0: 0x00000047 | umac major
[ 22.377865] iwlwifi 0000:04:00.0: 0x058653F6 | umac minor
[ 22.377866] iwlwifi 0000:04:00.0: 0x0041BAA7 | frame pointer
[ 22.377866] iwlwifi 0000:04:00.0: 0xC0885E64 | stack pointer
[ 22.377867] iwlwifi 0000:04:00.0: 0x002D0207 | last host cmd
[ 22.377868] iwlwifi 0000:04:00.0: 0x00000000 | isr status reg
[ 22.377881] iwlwifi 0000:04:00.0: IML/ROM dump:
[ 22.377881] iwlwifi 0000:04:00.0: 0x00000003 | IML/ROM error/state
[ 22.377894] iwlwifi 0000:04:00.0: 0x000059F0 | IML/ROM data1
[ 22.377907] iwlwifi 0000:04:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 22.377915] iwlwifi 0000:04:00.0: Fseq Registers:
[ 22.377918] iwlwifi 0000:04:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 22.377922] iwlwifi 0000:04:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 22.377926] iwlwifi 0000:04:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 22.377929] iwlwifi 0000:04:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 22.377933] iwlwifi 0000:04:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 22.377936] iwlwifi 0000:04:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 22.377940] iwlwifi 0000:04:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 22.377943] iwlwifi 0000:04:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 22.377947] iwlwifi 0000:04:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 22.377953] iwlwifi 0000:04:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 22.377958] iwlwifi 0000:04:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 22.377964] iwlwifi 0000:04:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 22.378172] iwlwifi 0000:04:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 22.378176] ieee80211 phy0: Hardware restart was requested
[ 23.330127] ACPI: \: failed to evaluate _DSM (0x1001)
[ 23.330130] ACPI: \: failed to evaluate _DSM (0x1001)
[ 23.330131] ACPI: \: failed to evaluate _DSM (0x1001)
[ 23.330132] ACPI: \: failed to evaluate _DSM (0x1001)
[ 23.330133] ACPI: \: failed to evaluate _DSM (0x1001)
[ 23.330134] ACPI: \: failed to evaluate _DSM (0x1001)
[ 23.330135] ACPI: \: failed to evaluate _DSM (0x1001)
[ 23.883855] kauditd_printk_skb: 10 callbacks suppressed
[ 23.883858] audit: type=1131 audit(1656626008.885:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.444002] iwlwifi 0000:04:00.0: Microcode SW error detected. Restarting 0x0.
[ 27.444118] iwlwifi 0000:04:00.0: Start IWL Error Log Dump:
[ 27.444119] iwlwifi 0000:04:00.0: Transport status: 0x0000004A, valid: 6
[ 27.444121] iwlwifi 0000:04:00.0: Loaded firmware version: 71.058653f6.0 cc-a0-71.ucode
[ 27.444123] iwlwifi 0000:04:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 27.444124] iwlwifi 0000:04:00.0: 0x000022F0 | trm_hw_status0
[ 27.444125] iwlwifi 0000:04:00.0: 0x00000000 | trm_hw_status1
[ 27.444126] iwlwifi 0000:04:00.0: 0x004FB4C6 | branchlink2
[ 27.444127] iwlwifi 0000:04:00.0: 0x0001CAC6 | interruptlink1
[ 27.444128] iwlwifi 0000:04:00.0: 0x0001CAC6 | interruptlink2
[ 27.444129] iwlwifi 0000:04:00.0: 0x004F4766 | data1
[ 27.444130] iwlwifi 0000:04:00.0: 0x00001000 | data2
[ 27.444130] iwlwifi 0000:04:00.0: 0x00000000 | data3
[ 27.444131] iwlwifi 0000:04:00.0: 0x00000000 | beacon time
[ 27.444132] iwlwifi 0000:04:00.0: 0x00414E24 | tsf low
[ 27.444133] iwlwifi 0000:04:00.0: 0x00000000 | tsf hi
[ 27.444133] iwlwifi 0000:04:00.0: 0x00000000 | time gp1
[ 27.444134] iwlwifi 0000:04:00.0: 0x0041A9A0 | time gp2
[ 27.444135] iwlwifi 0000:04:00.0: 0x00000001 | uCode revision type
[ 27.444136] iwlwifi 0000:04:00.0: 0x00000047 | uCode version major
[ 27.444137] iwlwifi 0000:04:00.0: 0x058653F6 | uCode version minor
[ 27.444137] iwlwifi 0000:04:00.0: 0x00000340 | hw version
[ 27.444138] iwlwifi 0000:04:00.0: 0x18C89000 | board version
[ 27.444139] iwlwifi 0000:04:00.0: 0x800CFC04 | hcmd
[ 27.444140] iwlwifi 0000:04:00.0: 0x00020000 | isr0
[ 27.444141] iwlwifi 0000:04:00.0: 0x00000000 | isr1
[ 27.444141] iwlwifi 0000:04:00.0: 0x08B00002 | isr2
[ 27.444142] iwlwifi 0000:04:00.0: 0x00C3000C | isr3
[ 27.444143] iwlwifi 0000:04:00.0: 0x00000000 | isr4
[ 27.444143] iwlwifi 0000:04:00.0: 0x001C0103 | last cmd Id
[ 27.444144] iwlwifi 0000:04:00.0: 0x004F4766 | wait_event
[ 27.444145] iwlwifi 0000:04:00.0: 0x00000000 | l2p_control
[ 27.444146] iwlwifi 0000:04:00.0: 0x00000020 | l2p_duration
[ 27.444146] iwlwifi 0000:04:00.0: 0x00000000 | l2p_mhvalid
[ 27.444147] iwlwifi 0000:04:00.0: 0x00000000 | l2p_addr_match
[ 27.444148] iwlwifi 0000:04:00.0: 0x00000009 | lmpm_pmg_sel
[ 27.444149] iwlwifi 0000:04:00.0: 0x00000000 | timestamp
[ 27.444149] iwlwifi 0000:04:00.0: 0x0000286C | flow_handler
[ 27.444259] iwlwifi 0000:04:00.0: Start IWL Error Log Dump:
[ 27.444260] iwlwifi 0000:04:00.0: Transport status: 0x0000004A, valid: 7
[ 27.444261] iwlwifi 0000:04:00.0: 0x20003207 | ADVANCED_SYSASSERT
[ 27.444262] iwlwifi 0000:04:00.0: 0x00000000 | umac branchlink1
[ 27.444263] iwlwifi 0000:04:00.0: 0x80455B2C | umac branchlink2
[ 27.444263] iwlwifi 0000:04:00.0: 0xC0081200 | umac interruptlink1
[ 27.444264] iwlwifi 0000:04:00.0: 0x00000000 | umac interruptlink2
[ 27.444265] iwlwifi 0000:04:00.0: 0x00032968 | umac data1
[ 27.444266] iwlwifi 0000:04:00.0: 0xDEADBEEF | umac data2
[ 27.444266] iwlwifi 0000:04:00.0: 0xDEADBEEF | umac data3
[ 27.444267] iwlwifi 0000:04:00.0: 0x00000047 | umac major
[ 27.444268] iwlwifi 0000:04:00.0: 0x058653F6 | umac minor
[ 27.444269] iwlwifi 0000:04:00.0: 0x0041A99A | frame pointer
[ 27.444269] iwlwifi 0000:04:00.0: 0xC0885E64 | stack pointer
[ 27.444270] iwlwifi 0000:04:00.0: 0x002D0207 | last host cmd
[ 27.444271] iwlwifi 0000:04:00.0: 0x00000000 | isr status reg
[ 27.444307] iwlwifi 0000:04:00.0: IML/ROM dump:
[ 27.444308] iwlwifi 0000:04:00.0: 0x00000003 | IML/ROM error/state
[ 27.444321] iwlwifi 0000:04:00.0: 0x000059EE | IML/ROM data1
[ 27.444333] iwlwifi 0000:04:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 27.444341] iwlwifi 0000:04:00.0: Fseq Registers:
[ 27.444344] iwlwifi 0000:04:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 27.444348] iwlwifi 0000:04:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 27.444351] iwlwifi 0000:04:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 27.444355] iwlwifi 0000:04:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 27.444358] iwlwifi 0000:04:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 27.444361] iwlwifi 0000:04:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 27.444365] iwlwifi 0000:04:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 27.444368] iwlwifi 0000:04:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 27.444372] iwlwifi 0000:04:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 27.444377] iwlwifi 0000:04:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 27.444383] iwlwifi 0000:04:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 27.444388] iwlwifi 0000:04:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 27.444561] iwlwifi 0000:04:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 27.444565] ieee80211 phy0: Hardware restart was requested
[ 28.402955] ACPI: \: failed to evaluate _DSM (0x1001)
[ 28.402958] ACPI: \: failed to evaluate _DSM (0x1001)
[ 28.402960] ACPI: \: failed to evaluate _DSM (0x1001)
[ 28.402961] ACPI: \: failed to evaluate _DSM (0x1001)
[ 28.402962] ACPI: \: failed to evaluate _DSM (0x1001)
[ 28.402963] ACPI: \: failed to evaluate _DSM (0x1001)
[ 29.304323] audit: type=1131 audit(1656626014.305:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 29.307996] audit: type=1131 audit(1656626014.308:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.516680] iwlwifi 0000:04:00.0: Microcode SW error detected. Restarting 0x0.
[ 32.516798] iwlwifi 0000:04:00.0: Start IWL Error Log Dump:
[ 32.516800] iwlwifi 0000:04:00.0: Transport status: 0x0000004A, valid: 6
[ 32.516803] iwlwifi 0000:04:00.0: Loaded firmware version: 71.058653f6.0 cc-a0-71.ucode
[ 32.516805] iwlwifi 0000:04:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 32.516807] iwlwifi 0000:04:00.0: 0x000022F0 | trm_hw_status0
[ 32.516808] iwlwifi 0000:04:00.0: 0x00000000 | trm_hw_status1
[ 32.516809] iwlwifi 0000:04:00.0: 0x004FB4C6 | branchlink2
[ 32.516810] iwlwifi 0000:04:00.0: 0x0001B052 | interruptlink1
[ 32.516811] iwlwifi 0000:04:00.0: 0x0001B052 | interruptlink2
[ 32.516812] iwlwifi 0000:04:00.0: 0x004F4766 | data1
[ 32.516813] iwlwifi 0000:04:00.0: 0x00001000 | data2
[ 32.516814] iwlwifi 0000:04:00.0: 0x00000000 | data3
[ 32.516815] iwlwifi 0000:04:00.0: 0x00000000 | beacon time
[ 32.516816] iwlwifi 0000:04:00.0: 0x0041625E | tsf low
[ 32.516817] iwlwifi 0000:04:00.0: 0x00000000 | tsf hi
[ 32.516818] iwlwifi 0000:04:00.0: 0x00000000 | time gp1
[ 32.516819] iwlwifi 0000:04:00.0: 0x0041BDD3 | time gp2
[ 32.516820] iwlwifi 0000:04:00.0: 0x00000001 | uCode revision type
[ 32.516821] iwlwifi 0000:04:00.0: 0x00000047 | uCode version major
[ 32.516822] iwlwifi 0000:04:00.0: 0x058653F6 | uCode version minor
[ 32.516824] iwlwifi 0000:04:00.0: 0x00000340 | hw version
[ 32.516825] iwlwifi 0000:04:00.0: 0x18C89000 | board version
[ 32.516826] iwlwifi 0000:04:00.0: 0x800CFC04 | hcmd
[ 32.516827] iwlwifi 0000:04:00.0: 0x00020000 | isr0
[ 32.516828] iwlwifi 0000:04:00.0: 0x00000000 | isr1
[ 32.516829] iwlwifi 0000:04:00.0: 0x08B00002 | isr2
[ 32.516830] iwlwifi 0000:04:00.0: 0x00C3000C | isr3
[ 32.516831] iwlwifi 0000:04:00.0: 0x00000000 | isr4
[ 32.516832] iwlwifi 0000:04:00.0: 0x001C0103 | last cmd Id
[ 32.516833] iwlwifi 0000:04:00.0: 0x004F4766 | wait_event
[ 32.516834] iwlwifi 0000:04:00.0: 0x00000000 | l2p_control
[ 32.516834] iwlwifi 0000:04:00.0: 0x00000020 | l2p_duration
[ 32.516835] iwlwifi 0000:04:00.0: 0x00000000 | l2p_mhvalid
[ 32.516836] iwlwifi 0000:04:00.0: 0x00000000 | l2p_addr_match
[ 32.516837] iwlwifi 0000:04:00.0: 0x00000009 | lmpm_pmg_sel
[ 32.516838] iwlwifi 0000:04:00.0: 0x00000000 | timestamp
[ 32.516839] iwlwifi 0000:04:00.0: 0x0000286C | flow_handler
[ 32.516940] iwlwifi 0000:04:00.0: Start IWL Error Log Dump:
[ 32.516941] iwlwifi 0000:04:00.0: Transport status: 0x0000004A, valid: 7
[ 32.516942] iwlwifi 0000:04:00.0: 0x20003207 | ADVANCED_SYSASSERT
[ 32.516944] iwlwifi 0000:04:00.0: 0x00000000 | umac branchlink1
[ 32.516945] iwlwifi 0000:04:00.0: 0x80455B2C | umac branchlink2
[ 32.516946] iwlwifi 0000:04:00.0: 0xC0081200 | umac interruptlink1
[ 32.516947] iwlwifi 0000:04:00.0: 0x00000000 | umac interruptlink2
[ 32.516948] iwlwifi 0000:04:00.0: 0x00033D9B | umac data1
[ 32.516949] iwlwifi 0000:04:00.0: 0xDEADBEEF | umac data2
[ 32.516950] iwlwifi 0000:04:00.0: 0xDEADBEEF | umac data3
[ 32.516951] iwlwifi 0000:04:00.0: 0x00000047 | umac major
[ 32.516952] iwlwifi 0000:04:00.0: 0x058653F6 | umac minor
[ 32.516953] iwlwifi 0000:04:00.0: 0x0041BDCD | frame pointer
[ 32.516954] iwlwifi 0000:04:00.0: 0xC0885E64 | stack pointer
[ 32.516955] iwlwifi 0000:04:00.0: 0x002D0207 | last host cmd
[ 32.516956] iwlwifi 0000:04:00.0: 0x00000000 | isr status reg
[ 32.517007] iwlwifi 0000:04:00.0: IML/ROM dump:
[ 32.517007] iwlwifi 0000:04:00.0: 0x00000003 | IML/ROM error/state
[ 32.517020] iwlwifi 0000:04:00.0: 0x000059EE | IML/ROM data1
[ 32.517033] iwlwifi 0000:04:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 32.517041] iwlwifi 0000:04:00.0: Fseq Registers:
[ 32.517044] iwlwifi 0000:04:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 32.517048] iwlwifi 0000:04:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 32.517052] iwlwifi 0000:04:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 32.517055] iwlwifi 0000:04:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 32.517059] iwlwifi 0000:04:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 32.517062] iwlwifi 0000:04:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 32.517066] iwlwifi 0000:04:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 32.517069] iwlwifi 0000:04:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 32.517073] iwlwifi 0000:04:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 32.517079] iwlwifi 0000:04:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 32.517084] iwlwifi 0000:04:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 32.517090] iwlwifi 0000:04:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 32.517263] iwlwifi 0000:04:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 32.517267] ieee80211 phy0: Hardware restart was requested
[ 33.468938] ACPI: \: failed to evaluate _DSM (0x1001)
[ 33.468941] ACPI: \: failed to evaluate _DSM (0x1001)
[ 33.468942] ACPI: \: failed to evaluate _DSM (0x1001)
[ 33.468943] ACPI: \: failed to evaluate _DSM (0x1001)
[ 33.468944] ACPI: \: failed to evaluate _DSM (0x1001)
[ 33.468945] ACPI: \: failed to evaluate _DSM (0x1001)
[ 36.395849] audit: type=1100 audit(1656626021.395:137): pid=1595 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="basilmari" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 36.395923] audit: type=1101 audit(1656626021.395:138): pid=1595 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="basilmari" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 36.396524] audit: type=1110 audit(1656626021.395:139): pid=1595 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 36.397907] audit: type=1105 audit(1656626021.398:140): pid=1595 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
The section after “Microcode SW error detected. Restarting 0x0” keeps repeating ad infinitum.
I’ve tried the kernels 5.4, 5.10, 5.15, and 5.18. Kernel 5.10 and 5.4 are not compatible with my graphics card it seems. 5.15 and 5.18 produce the same results. I also tried setting parameters for iwlwifi in /etc/modprobe.d/iwlwifi.conf like this:
options iwlwifi swcrypto=0 bt_coex_active=0 power_save=0
finally, linux-firmware is up to date.
Can anyone gleam something from the logs that could tell me what the problem is?
Extra relevent info: The system is dual booted and windows fast startup is turned off.
