As title: I linked dragged an appimage to desktop and clicked the button to link here. It didn’t show up, so I figured I might have missclicked, and tried again. I then got the pop up saying that it was already linked there. If look at my desktop through dolphin though, it shows up. any thoughts?
I tried running a command that I found online in a different thread:
Alright, a few of the links I made today have reappeared randomly, I’m not sure what triggered it, but I’m almost certain that this is not working as intended.
This started happening after I made a second activity for the purpose of writing, and, after realizing that it didn’t give me a clean desktop with nothing on it in the new activity, I deleted the new activity. When I did so, it deleted all the links on the desktop, but they all showed in dolphin. I restarted pc and they showed up again, but this issue is still here now.
That is how you link things to the desktop, yes. My problem is that it doesn’t actually show what I drag onto the desktop on the desktop until I restart my pc. I’ve no idea why it does that.
do you get that menu when you try to drag and drop that appimage or file on the desktop? just simply click link here and you should be good to go!
are you on the latest update? are you using any custom global themes ?
have you tried this?
check your basic DE settings like has the preview or folder view enabled on the desktop in the dropdown menu which you get when you right click on the desktop?
This doesn’t work, and I am on the latest update of kde, I’m using 5.15 kernel, and no I’m not using and custom global themes, I’m using breeze dark without the desktop layout from the theme.
yes. you can try and set a new user in the users settings, try linking that appimage on the desktop then report back, in this way we can find if the issue is user profile specfic or not
