Line Out Not Working
Since the 2026-05-19 update, my Line Out has not been working properly. I assume this has to do with with the pipewire update from 1.6.4 to 1.6.5. I reverted my system back to before the update and the audio works fine.
I’ve tried restarting the wireplumber and pipewire services, deleting the wireplumber configuration for my user, and checking the alsamixer setup. I’ve also tried rolling pipewire, wireplumber, etc back to 1.6.4, but that did not work, so maybe something else is going on.
My headphone jack does still work and I have my speakers plugged into there for now, but I’d like to get the rear jack working again.
Edited for full output from inxi -zv8:
  Kernel: 6.18.33-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=fe7cb117-10fc-4903-9a1a-f5cf72b13490 rw rootflags=subvol=@
    quiet splash resume=UUID=348b79f5-1b76-4b4e-ab10-1d73b13dedfe
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.26.0
  Type: Desktop Mobo: ASRock model: H470M-STX serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends
    v: P2.20 date: 08/06/2021
  System RAM: total: 16 GiB available: 15.24 GiB used: 3.12 GiB (20.5%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: G.Skill part-no: F4-3000C16-8GRS
    serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    serial: <filter>
  Info: model: 11th Gen Intel Core i5-11500 bits: 64 type: MT MCP
    arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
    process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
    microcode: 0x65
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB
    desc: 6x512 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 65088
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm
    fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep sha_ni smap smep smx ss ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
    tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
    x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: ASRock
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2
    bus-ID: 00:02.0 chip-ID: 8086:4c8a class-ID: 0300
    alternate: fbdev,vesa dri: iris gpu: i915 d-rect: 3520x1980 display-ID: 0
  Monitor-1: HDMI-A-1 pos: primary,top-left model: MSI MP251 E2
    serial: <filter> built: 2025 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 90 gamma: 1.2 chroma: red: x: 0.655 y: 0.341 green: x: 0.318 y: 0.627
    blue: x: 0.149 y: 0.059 white: x: 0.318 y: 0.337
    size: 540x310mm (21.26x12.2") diag: 623mm (24.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480
  Monitor-2: HDMI-A-2 pos: bottom-r model: HP W2072a serial: <filter>
    built: 2012 res: mode: 1600x900 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
    chroma: red: x: 0.635 y: 0.329 green: x: 0.302 y: 0.631 blue: x: 0.153
    y: 0.071 white: x: 0.314 y: 0.329 size: 443x249mm (17.44x9.8")
    diag: 508mm (20") ratio: 16:9 modes: 1600x900, 1280x1024, 1440x900,
    1280x720, 1024x768, 800x600, 640x480, 720x400
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.1-arch1.2 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Graphics (RKL GT1)
    device-ID: 8086:4c8a memory: 14.88 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.350 layers: 2 device: 0 type: integrated-gpu name: Intel
    Graphics (RKL GT1) driver: mesa intel v: 26.1.1-arch1.2
    device-ID: 8086:4c8a surfaces: N/A
  Device-1: Intel vendor: ASRock driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:f1c8 class-ID: 0403
  API: ALSA v: k6.18.33-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4d class-ID: 0200
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 8086:24fb class-ID: 0280
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0aa7
    class-ID: e001
  Local Storage: total: 1.03 TiB used: 108.55 GiB (10.3%)
    model: WDBA3V5000ANC-WRSN size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 211210WD temp: 22.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: TeamGroup
    model: T-FORCE TM8FFE512G size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 1.c.Q.37 temp: 33.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 120GB SSD
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0613 scheme: GPT
  ID-1: / raw-size: 94.73 GiB size: 94.73 GiB (100.00%) used: 64.6 GiB (68.2%)
    fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: fe7cb117-10fc-4903-9a1a-f5cf72b13490
    used: 664 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 2F1E-A295
  ID-3: /home raw-size: 476.94 GiB size: 468.38 GiB (98.21%)
    used: 43.95 GiB (9.4%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:7
    label: Home uuid: 3683cd15-0c99-4854-a7b6-e062d58a296d
  ID-4: /var/cache raw-size: 94.73 GiB size: 94.73 GiB (100.00%)
    used: 64.6 GiB (68.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
  ID-5: /var/log raw-size: 94.73 GiB size: 94.73 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.77 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 348b79f5-1b76-4b4e-ab10-1d73b13dedfe
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 200 MiB fs: vfat label: N/A
    uuid: 402B-42A3
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 366.69 GiB fs: ntfs label: N/A
    uuid: F0182C43182C0AE4
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 735 MiB fs: ntfs label: N/A
    uuid: C0A8CC20A8CC1736
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 98.14 GiB fs: ntfs
    label: Storage uuid: B0C406C6C4068F32
  Hub-2: 1-6:2 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-6.1:4 info: BY Tech Gaming Keyboard type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:0049 class-ID: 0300
  Device-2: 1-6.2:6 info: Logitech M-U0007 [Corded Mouse M500] type: mouse
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 046d:c069 class-ID: 0301
  Device-3: 1-9:3 info: ASRock LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a6 class-ID: 0300
    serial: <filter>
  Device-4: 1-14:5 info: Intel Wireless-AC 3168 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0aa7 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-4: 2-6:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  System Temperatures: cpu: 30.0 C pch: 46.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1390 pm: pacman pkgs: 1360 libs: 353 tools: pamac pm: flatpak
    pkgs: 30
    1: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    2: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    4: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    5: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    6: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    7: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    8: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 318
  1: cpu: 33.4% command: firefox pid: 1493 mem: 569.4 MiB (3.6%)
  2: cpu: 17.9% command: firefox pid: 1955 mem: 291.4 MiB (1.8%)
  3: cpu: 9.6% command: kwin_wayland pid: 762 mem: 190.5 MiB (1.2%)
  4: cpu: 7.0% command: plasmashell pid: 951 mem: 368.0 MiB (2.3%)
  5: cpu: 5.1% command: firefox pid: 1612 mem: 339.9 MiB (2.1%)
  Memory top: 5 of 318
  1: mem: 569.4 MiB (3.6%) command: firefox pid: 1493 cpu: 33.4%
  2: mem: 368.0 MiB (2.3%) command: plasmashell pid: 951 cpu: 7.0%
  3: mem: 339.9 MiB (2.1%) command: firefox pid: 1612 cpu: 5.1%
  4: mem: 291.4 MiB (1.8%) command: firefox pid: 1955 cpu: 17.9%
  5: mem: 190.5 MiB (1.2%) command: kwin_wayland pid: 762 cpu: 9.6%
  Processes: 318 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.05 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.5 gcc: 16.1.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
Please provide the full output of inxi -zv8. The truncated output you have provided lacks information which may be helpful to forum members who are troubleshooting the issue.
Please post more information about ALSA audio devices
sudo alsa-info.sh --upload
and audio cards detected and available in PipeWire
pactl list cards
Output from sudo alsa-info.sh --upload is here:
https://alsa-project.org/db/?f=fb0fbebd1d2062e1c1e759e7b49442a5b4abe986
Output of pactl list cards:
Card #42
        Driver: alsa
        Owner Module: n/a
        Properties:
                device.enum.api = "udev"
                device.api = "alsa"
                media.class = "Audio/Device"
                api.alsa.path = "hw:0"
                api.alsa.card = "0"
                api.alsa.card.name = "HDA Intel PCH"
                api.alsa.card.longname = "HDA Intel PCH at 0xb1430000 irq 162"
                device.plugged.usec = "10540141"
                sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
                device.bus = "pci"
                device.subsystem = "sound"
                device.vendor.id = "0x8086"
                device.product.id = "0xf1c8"
                device.name = "alsa_card.pci-0000_00_1f.3"
                device.description = "Built-in Audio"
                device.nick = "HDA Intel PCH"
                device.icon_name = "audio-card-analog-pci"
                api.alsa.use-acp = "true"
                api.acp.auto-port = "false"
                api.dbus.ReserveDevice1.Priority = "-20"
                api.alsa.split-enable = "true"
                spa.object.id = "2"
                factory.id = "15"
                client.id = "41"
                object.id = "42"
                object.serial = "42"
                object.path = "alsa:acp:PCH"
                alsa.card = "0"
                alsa.long_card_name = "HDA Intel PCH at 0xb1430000 irq 162"
                alsa.mixer_name = "Realtek ALC233"
                alsa.components = "HDA:10ec0235,18492233,00100002"
                alsa.id = "PCH"
                device.string = "0"
        Profiles:
                off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
                output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
                output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
                input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
                pro-audio: Pro Audio (sinks: 1, sources: 2, priority: 1, available: yes)
        Active Profile: output:analog-stereo+input:analog-stereo
        Ports:
                analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 1, not available)
                        Properties:
                                port.type = "mic"
                                port.availability-group = "Legacy 1"
                                card.profile.port = "0"
                        Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo
                analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 2, available)
                        Properties:
                                port.type = "line"
                                port.availability-group = "Legacy 2"
                                card.profile.port = "1"
                        Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
                analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 3, available)
                        Properties:
                                port.type = "headphones"
                                port.availability-group = "Legacy 3"
                                card.profile.port = "2"
Original post has been edited with full inxi -zv8 output.
ALSA data shows all playback mixer controls are muted [off] and volume set to 0
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0xb1430000 irq 162'
  Mixer name	: 'Realtek ALC233'
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB] [off]
  Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 0 [0%] [-51.00dB]
  Front Right: Playback 0 [0%] [-51.00dB]
Simple mixer control 'Line Out',0
  Mono:
I suggest use alsamixer to unmute mixer controls and increase volume
alsamixer --card=PCH --view=playback
alsamixer(1) - General Controls
The Left and right arrow keys are used to select the channel (or device, depending on your preferred terminology). You can also use n (“next”) and p (“previous”).
The Up and Down Arrows control the volume for the currently selected device. You can also use + or - for the same purpose.
M toggles muting for the current channel (both left and right). If the hardware supports it
When ALSA mixer controls are adjusted to your liking, use this command save the settings:
sudo alsactl store
Settings are saved to /var/lib/alsa/asound.state and should be restored automatically when system is booted.
Settings can also be restored with:
sudo alsactl restore
I now realize that when I posted the output of sudo alsa-info.sh --upload I did have everything muted. However, using
I think I’ve found the issue. When using the headphone jack, the Master and Headphones outputs slide up and down together. When using Line Out, only the Master changes when I adjust the volume and there is no corresponding change to Line Out. Even if I manually move Line Out up, there is still no output.
I’ll have to try reverting later and see how this behavior differs when things were working.
Had a chance to revert and compare the behaviors of the alsa mixer:
Before the update:
Volume   Master   PCM   Line Out
Muted    0        0     0
2%       0        97    18         (Can begin to hear audio)
4%       0        97    46
6%       0        98    73
8%       0        98    100
10%      2        100   100
After the update:
Muted    0        0     0
2%       0        12    0
4%       0        41    0
6%       0        69    0
8%       0        98    0
10%      2        100   0          (Still cannot hear audio)
What is the expected behavior here? It seems odd to me that so many levels would be changed by the volume scroll at different times. I’m also not sure why I’m able to hear audio when the Master is still set at 0.
Changing Line Out to 100 does not fix the audio issue. I can hear a pop out of my speakers when I start to play audio, but there is no sound after that.
Just did the big system update that includes pipewire 1.6.6 and the behavior has changed.
Now when I set Line Out to 100, I can begin to hear audio once the Master volume starts to kick on at 10%. This is closer to the behavior I would expect, but not sure if that is the intended behavior. Is there a way to configure this?
