Hello,
basicly I do have problem with Network Manager. My setup is a little strange maybe. Maybe it is the reason. Can’t tell.
I have a laptop connected to MikroTik router via two interfaces: ethernet and wifi. There is a ethernet switch between
laptop and router. If the power goes down this switch is off and ethernet connection is not working. So this is why I use wifi also (mean to be the backup connection). All at the same time! Both have default route present when up. But the metric differs - what is obvious.
Wifi route have “less priority” metric - so ethernet link is used. To not complicate the setup both interfaces gets the
same IP address from DHCP server (dnsmasq):
[worker ~]# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.1.254 0.0.0.0 UG 20 0 0 lan1
0.0.0.0 192.168.1.254 0.0.0.0 UG 40 0 0 wifi
10.0.0.0 192.168.1.70 255.0.0.0 UG 20 0 0 lan1
10.0.0.0 192.168.1.70 255.0.0.0 UG 40 0 0 wifi
192.168.1.0 0.0.0.0 255.255.255.0 U 20 0 0 lan1
192.168.1.0 0.0.0.0 255.255.255.0 U 40 0 0 wifi
This is easy and simple setup. It was working for years. Nota bene: when I’m using wifi or lan1 separately (both not ON at the same time), everything is perfectly fine.
But since some time (couple of months), it started to be a problem that after couple of minutes, after enabling wifi and lan1 connections in Network Manager I can see warning that my wired connection is limited or local only - it means there is no internet connectivity, and metric for lan1 default route changes to “lower priority”:
0.0.0.0 192.168.1.254 0.0.0.0 UG 20020 0 0 lan1
and boom I’m using wifi
gru 23 15:15:15 worker.localnet NetworkManager[962]: [1640268915.0899] manager: NetworkManager state is now CONNECTED_SITE
gru 23 15:15:15 worker.localnet NetworkManager[962]: [1640268915.0923] manager: NetworkManager state is now CONNECTED_LOCAL
gru 23 15:15:15 worker.localnet NetworkManager[962]: [1640268915.0928] manager: NetworkManager state is now CONNECTED_SITE
gru 23 15:15:15 worker.localnet NetworkManager[962]: [1640268915.0933] policy: set ‘
Sebleczone Frelki xD’ (wifi) as default for IPv4 routing and DNS
gru 23 15:15:15 worker.localnet kded5[4103504]: plasma-nm: Network connectivity limited, scheduling notification
gru 23 15:15:15 worker.localnet systemd[1]: Starting Network Manager Script Dispatcher Service…
gru 23 15:15:15 worker.localnet dbus-daemon[960]: [system] Activating via systemd: service name=‘org.freedesktop.nm_dispatcher’ unit=‘dbus-org.freedesktop.nm-dispatcher.service’ requested by ‘:1.6’ (uid=0 pid=962 comm="/usr/bin/NetworkManager --no-daemon ")
gru 23 15:15:15 worker.localnet dbus-daemon[960]: [system] Successfully activated service ‘org.freedesktop.nm_dispatcher’
gru 23 15:15:15 worker.localnet systemd[1]: Started Network Manager Script Dispatcher Service.
gru 23 15:15:25 worker.localnet systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
lan1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.10 netmask 255.255.255.0 broadcast 192.168.1.255
ether 54:e1:ad:3a:8c:ad txqueuelen 2000 (Ethernet)
RX packets 23481082 bytes 27655080488 (25.7 GiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 16167860 bytes 9945333222 (9.2 GiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
wifi: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 34:f6:4b:0b:b2:ec txqueuelen 2000 (Ethernet)
RX packets 59727 bytes 56292842 (53.6 MiB)
TX packets 17056 bytes 4200689 (4.0 MiB)
This really drives me crazy. How Network Manager decides that lan1 connection in somewhat limited? Is there any internet “connectivity” check
or something? How to fix this test?
I would be very grateful for any idea.
