limepanel multiple monitor
Hello everyone,
I am using bspwm withe limepanel. The second monitor is connected with xrandr.
There is an empty space instead of panel which remains completely unchanged on the primary monitor. Is it possible to remove this useless gap in the second monitor or mirror the limepanel to the second (possibly all) connecting monitors.
Thanks
Yes, both are possible afaik. See man bspc on how to set top padding per monitor. You can then put that command at the end of your bspwmrc.
This is what I needed to do based on @Chrysostomus comment.
bspc config -m <foo> top_padding -10
where foo is the name of the monitor.
