i recently switched from an NVIDIA gpu to an AMD RX6600. i removed video-nvidia, installed video-linux. i recreated my xorg.conf file. however, lightdm fails to start. when i turn on my computer i get [failed] light display manager
. here’s where it gets weird though. if i switch to tty2 and run sudo systemctl start lightDM
everything works perfectly and i can log in, i3 starts and everything works as expected. i got xorg logs from both the autostart that failed and the manual start that succeeded. i made a diff of the two logs and noted some diffrences.
the good log file includes the line:
[0] (II) xfree86: Adding drm device (/dev/dri/card0)
[0] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:2a:00.0/0000:2b:00.0/0000:2c:00.0/drm/card0
the bad log does not contain this log, and it continues to complane about no drm device.
[0] Kernel modesetting enabled.
[0] Failed to open DRM device for pci:0000:2a:00.0: No such file or directory
[0] Failed to open DRM device for pci:0000:2b:00.0: No such file or directory
[0] Failed to open DRM device for pci:0000:2c:00.0: No such file or directory
[0] Failed to open DRM device for pci:0000:2c:00.1: No such file or directory
[0] (EE) Screen 0 deleted because of no matching config section.
[0] (II) UnloadModule: "amdgpu"
[0] (EE) Device(s) detected, but none match those in the config file.
[0] (EE)
Fatal server error:
[0] (EE) no screens found(EE)
[0] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[0] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[0] (EE)
[0] (EE) Server terminated with error (1). Closing log file.
any idea why it might be doing this? ive tried every other forum out there and none seem to address this.
