I recently updated my system and after a reboot I now have an Arch logo instead of the Manjaro “M” in the upper left corner in Gnome. Also my start menu disappeared when I click the button. Is there a way to make this like it was before? Any help is really appreciated. Thank you!
The arc-menu extension is disabled already. I can only enable it and then I get a menu that is similar to the Manjaro one but it looks a bit different.
A similar thing happened to me, except that it showed the Fedora icon instead of Arch. Here’s how I fixed it: Right-click on the start button and select “ArcMenu Settings”. Go to “Button Appearance” on the left and then by “Icon Appearance” press the button called “Browse Icons”. You can choose the Manjaro icon in there.
