utils>=450.51.06' required by cuda
:: removing nvidia-450xx-utils breaks dependency 'nvidia-utils' required by nvtop
Error: pacman failed!
Error: script failed!
[ljohnson@kise-005 Desktop]$ yay -R nvtop
checking dependencies...
Packages (1) nvtop-1.0.0-2
Total Removed Size: 0.06 MiB
:: Do you want to remove these packages? [Y/n]
(1/1) removing nvtop [######################] 100%
(1/1) Arming ConditionNeedsUpdate...
Starting
> Removing video-nvidia-450xx...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-nvidia-450xx/MHWDCONFIGv
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
:: removing nvidia-450xx-utils breaks dependency 'nvidia-utils>=450.51.06' required by cuda
[ljohnson@kise-005 Desktop]$ yay -R cuda
Packages (1) cuda-11.0.3-1
Total Removed Size: 5169.80 MiB
(1/1) removing cuda [#################] 100%
(1/4) Reloading system manager configuration...
(2/4) Arming ConditionNeedsUpdate...
(3/4) Updating module dependencies...
(4/4) Updating the desktop file MIME type cache...
> Successfully removed video-nvidia-450xx
Starting
Using config ‘video-nvidia-455xx’ for device: 0000:01:00.0 (0300:10de:1b82) Display controller nVidia Corporation GP104 [GeForce GTX 1070 Ti]
Installing video-nvidia-455xx…
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-455xx/MHWDCONFIG
core is up to date
extra is up to date
community is up to date
multilib is up to date
resolving dependencies…
Packages (5) lib32-nvidia-455xx-utils-455.28-1 linux54-nvidia-455xx-455.28-3 linux58-nvidia-455xx-455.28-3 linux59-nvidia-455xx-455.28-2 nvidia-455xx-utils-455.28-2
Total Download Size: 167.10 MiB
Total Installed Size: 479.46 MiB
:: Retrieving packages…
downloading nvidia-455xx-utils-455.28-2-x86_64.pkg.tar.zst…
downloading linux54-nvidia-455xx-455.28-3-x86_64.pkg.tar.zst…
downloading linux58-nvidia-455xx-455.28-3-x86_64.pkg.tar.zst…
downloading linux59-nvidia-455xx-455.28-2-x86_64.pkg.tar.zst…
downloading lib32-nvidia-455xx-utils-455.28-1-x86_64.pkg.tar.zst…
checking keyring…
checking package integrity…
loading package files…
checking for file conflicts…
checking available disk space…
:: Processing package changes…
installing nvidia-455xx-utils…
==> If you run into trouble with CUDA not being available, run nvidia-modprobe first.
Optional dependencies for nvidia-455xx-utils
gtk3: nvidia-settings [installed]
xorg-server-devel: nvidia-xconfig
opencl-nvidia: OpenCL support [installed]
installing lib32-nvidia-455xx-utils…
Optional dependencies for lib32-nvidia-455xx-utils
lib32-opencl-nvidia-455xx
installing linux54-nvidia-455xx…
In order to use nvidia module, reboot the system.
installing linux58-nvidia-455xx…
installing linux59-nvidia-455xx…
:: Running post-transaction hooks…
(1/6) Creating system user accounts…
(2/6) Reloading system manager configuration…
(3/6) Arming ConditionNeedsUpdate…
(4/6) Updating module dependencies…
(5/6) Updating Kernel initcpios for Nvidia-DRM…
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: ‘default’
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.72-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: ‘fallback’
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
[ljohnson@kise-005 Desktop]$ yay -S cuda
Total Installed Size: 5169.80 MiB
(1/1) checking keys in keyring [#################] 100%
(1/1) checking package integrity [#################] 100%
(1/1) loading package files [#################] 100%
(1/1) checking for file conflicts [#################] 100%
(1/1) checking available disk space [#################] 100%
(1/1) installing cuda [#################] 100%
The cuda binaries are in /opt/cuda/bin
The cuda samples are in /opt/cuda/samples
The cuda docs are in /opt/cuda/doc
You need to relogin in order for the cuda binaries to appear in your PATH
Optional dependencies for cuda
gdb: for cuda-gdb [installed]
java-runtime=8: for nsight and nvvp [installed]
(1/1) Arming ConditionNeedsUpdate…
[ljohnson@kise-005 Desktop]$ yay -S nvtop
Total Installed Size: 0.06 MiB
(1/1) installing nvtop [#################] 100%
