When one installs the lightdm-settings application, some additional files are created that are not part of the application, namely the add-autologin-group.service. While this is helpful I guess, for some situations, it is not a universally desired action. Any chance these could be placed into another package? Like maybe lightdm-settings-autologin? It adds a group and then changes user’s group on a reboot, if you do not see the warning and disable the service before the next reboot. This is a pretty drastic security change that is made automatically, and one that is not exactly expected.
Done, thank you.
