Hi
I started using Manjaro just recently.
I used to organize my pictures using file ratings (1-5 “stars”) on Windows.
I’m looking for a file manager that can display the ratings and sort by it.
Is there one you could suggest or is there a plugin for files(nautilus) that enables it to display more file attributes?
Any suggestions are much appreciated
Thanks a lot!
gThumb displays the rating in the browser only after opening the “comment” window and saving it again, but that is a workaround I can live with.
