Hello,
I recently removed an old graphics card from my PC (Geforce GTX670) and installed an AMD Ryzen 5 5600G with internal GPU instead.
After uninstalling the NVIDIA driver, I installed the AMD driver. Since then, lightdm sometimes doesn’t start anymore and I have to go to the console and type sudo systemctl start lightdm.service
This is the output of
$ sudo systemctl status lightdm.service
× lightdm.service - Light Display Manager
Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Mon 2022-04-04 15:12:30 CEST; 3h 35min ago
Docs: man:lightdm(1)
Process: 928 ExecStart=/usr/bin/lightdm (code=exited, status=1/FAILURE)
Main PID: 928 (code=exited, status=1/FAILURE)
CPU: 43ms
Apr 04 15:12:30 Waldorf systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
Apr 04 15:12:30 Waldorf systemd[1]: Stopped Light Display Manager.
Apr 04 15:12:30 Waldorf systemd[1]: lightdm.service: Start request repeated too quickly.
Apr 04 15:12:30 Waldorf systemd[1]: lightdm.service: Failed with result 'exit-code'.
Apr 04 15:12:30 Waldorf systemd[1]: Failed to start Light Display Manager.
Where else can I look for information? What can go wrong here?
Here is the config:
$ lightdm --show-config
[Seat:*]
A greeter-session=lightdm-slick-greeter
A user-session=cinnamon
A session-wrapper=/etc/lightdm/Xsession
[LightDM]
A run-directory=/run/lightdm
[VNCServer]
Sources:
A /etc/lightdm/lightdm.conf
