Lightdm delayed login after update 20220102
Happy New Year!!
hangs after enter password in lightdm login box.
running startx from tty is successful…normal desktop etc.
inxi
  Kernel: 5 10 89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11 1 0
    parameters: BOOT_IMAGE= boot vmlinuz-5 10-x86_64
    root=UUID=fc78c783-d447-4b7e-a61a-a4e12ee0710a rw quiet
    udev log_priority=3 audit=0
  Console: tty 2 DM: LightDM 1 30 0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Acer product: Nitro AN515-51 v: V1 13
    serial: <superuser required>
  Mobo: KBL model: Freed_KLS v: V1 13 serial: <superuser required>
    UEFI: Insyde v: 1 13 date: 12 26 2017
  ID-1: BAT1 charge: 40 6 Wh (100 0%) condition: 40 6 48 9 Wh (82 9%)
    volts: 16 5 min: 15 2 model: COMPAL PABAS0241231 type: Li-ion
    serial: <filter> status: Full
  RAM: total: 7 65 GiB used: 507 8 MiB (6 5%)
  RAM Report:
    permissions: Unable to run dmidecode  Root privileges required
  Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
    family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEA
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 897 high: 900 min max: 800 3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 889 2: 900 3: 900 4: 900
    bogomips: 20004
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
    hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
    lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
    pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
    xsaves xtopology xtpr
  Type: l1tf
    mitigation: usercopy swapgs barriers and __user pointer sanitization
  Device-1: Intel HD Graphics 630 vendor: Acer Incorporated ALI driver: i915
    v: kernel bus-ID: 00:02 0 chip-ID: 8086:591b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile]
    vendor: Acer Incorporated ALI driver: nvidia v: 495 44
    alternate: nouveau,nvidia_drm bus-ID: 01:00 0 chip-ID: 10de:1c8d
    class-ID: 0300
  Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 1-9:4
    chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
  Display: server: X org 1 21 1 2 driver: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa tty: 240x67
  Message: Unable to show advanced data  Required tool glxinfo missing
  Device-1: Intel CM238 HD Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 00:1f 3 chip-ID: 8086:a171
    class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: 01:00 1 chip-ID: 10de:0fb9 class-ID: 0403
  Sound Server-1: ALSA v: k5 10 89-1-MANJARO running: yes
  Sound Server-2: JACK v: 1 9 19 running: no
  Sound Server-3: PulseAudio v: 15 0 running: no
  Device-1: Qualcomm Atheros QCA6174 802 11ac Wireless Network Adapter
    vendor: Lite-On driver: ath10k_pci v: kernel bus-ID: 02:00 0
    chip-ID: 168c:003e class-ID: 0280
  Device-2: Realtek RTL8111 8168 8411 PCI Express Gigabit Ethernet
    vendor: Acer Incorporated ALI driver: r8168 v: 8 049 02-NAPI modules: r8169
    port: 3000 bus-ID: 03:00 1 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0f1 state: down mac: <filter>
  WAN IP: No WAN IP found  Connected to web? SSL issues?
  Device-1: Lite-On type: USB driver: btusb v: 0 8 bus-ID: 1-7:3
    chip-ID: 04ca:3016 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: N A rfk-block:
    hardware: no software: no address: see --recommends
  Message: No logical block device data found
  Message: No RAID data found
  Local Storage: total: 465 76 GiB used: 133 05 GiB (28 6%)
  SMART Message: Required tool smartctl not installed  Check --recommends
  ID-1:  dev nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
    size: 465 76 GiB block-size: physical: 512 B logical: 512 B speed: 31 6 Gb s
    lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7 temp: 33 9 C scheme: GPT
  Message: No optical or floppy data found
  ID-1:   raw-size: 20 GiB size: 19 56 GiB (97 81%) used: 17 78 GiB (90 9%)
    fs: ext4 dev:  dev nvme0n1p7 maj-min: 259:7 label: root
    uuid: fc78c783-d447-4b7e-a61a-a4e12ee0710a
  ID-2:  boot efi raw-size: 100 MiB size: 96 MiB (96 00%)
    used: 25 2 MiB (26 3%) fs: vfat dev:  dev nvme0n1p2 maj-min: 259:2
    label: N A uuid: 22FE-0530
  ID-3:  home raw-size: 25 GiB size: 24 48 GiB (97 93%)
    used: 15 61 GiB (63 7%) fs: ext4 dev:  dev nvme0n1p8 maj-min: 259:8
    label: home uuid: 686e10cc-b4dc-4aba-9ee5-462860135b7c
  ID-4:  mnt raw-size: 187 28 GiB size: 187 28 GiB (100 00%)
    used: 99 64 GiB (53 2%) fs: ntfs dev:  dev nvme0n1p9 maj-min: 259:9
    label: data uuid: 349EEE827CCCD419
  Alert: No swap data was found
  ID-1:  dev nvme0n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs label: Recovery
    uuid: 1E18979618976C11
  ID-2:  dev nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N A uuid: N A
  ID-3:  dev nvme0n1p4 maj-min: 259:4 size: 98 71 GiB fs: ntfs label: N A
    uuid: E2B69C17B69BEA75
  ID-4:  dev nvme0n1p5 maj-min: 259:5 size: 811 MiB fs: ntfs label: N A
    uuid: 7CCC30A3CC30599A
  ID-5:  dev nvme0n1p6 maj-min: 259:6 size: 507 MiB fs: ntfs label: N A
    uuid: 6AAA3FEFAA3FB683
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2 0
    speed: 480 Mb s chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 1-5:2 info: Xenta [T3] 2 4GHz and IR Air Mouse Remote Control
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1 1
    speed: 12 Mb s power: 100mA chip-ID: 1d57:ad03 class-ID: 0301
  Device-2: 1-7:3 info: Lite-On type: Bluetooth driver: btusb interfaces: 2
    rev: 2 0 speed: 12 Mb s power: 100mA chip-ID: 04ca:3016 class-ID: e001
  Device-3: 1-9:4 info: Quanta HD Webcam type: Video driver: uvcvideo
    interfaces: 2 rev: 2 0 speed: 480 Mb s power: 500mA chip-ID: 0408:a060
  Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3 0 speed: 5 Gb s
dmesg
[    0 139555] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0 534251] resource sanity check: requesting [mem 0xfdffe800-0xfe0007ff], which spans more than pnp 00:00 [mem 0xfdb00000-0xfdffffff]
[    0 534254] caller pmc_core_probe+0x7e/0x410 mapping multiple BARs
[    1 131809] usb: port power management may be unreliable
[    1 624194] acpi_call: loading out-of-tree module taints kernel
[    1 861429] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1 861432] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1 861433] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1 861434] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[    1 906174] nvidia: module license 'NVIDIA' taints kernel
[    1 906175] Disabling lock debugging due to kernel taint
[    2 112499] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  495 44  Fri Oct 22 06:13:12 UTC 2021
[    2 117744] r8168  Copyright (C) 2021 Realtek NIC software team <nicfae@realtek com>
[    2 563342] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint
[    2 626095] FAT-fs (nvme0n1p2): Volume was not properly unmounted  Some data may be corrupt  Please run fsck
[    2 630752] urandom_read: 1 callbacks suppressed
[    3 753942] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[    4 092305] rtsx_pci 0000:03:00 0: VPD access failed   This is likely a firmware bug on this device   Contact the card vendor for a firmware update
[    4 097590] r8168 0000:03:00 1: invalid short VPD tag 00 at offset 1
[    4 700658] ACPI Warning: \_SB PCI0 PEG0 PEGP _DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
Before I thought to try startx i thought this could be graphic driver issue from a previous experience. I uninstalled optimus-switch (noting optimus-manager was issue for some in this update, however unrelated it may be). Tried free/nonfree drivers with no change.
I also noted a post to rollback systemd which also had no effect.
I don’t think its related to python update, no packages come up when i run the suggested command.
Thank you for your assistance.
which driver did you use ? nvidia or nouveau ?
and please send Xorg.log
mhwd
> Installed PCI configs:
         network-r8168            2016.04.20                true            PCI
video-hybrid-intel-nvidia-prime            2021.12.18               false            PCI
xorg (dates before update)
[  1257.571]
X.Org X Server 1.21.1.2
[  1257.577] Current Operating System: Linux abo 5.10.89-1-MANJARO #1 SMP PREEMPT Wed Dec 29 18:09:17 UTC 2021 x86_64
[  1257.577] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=fc78c783-d447-4b7e-a61a-a4e12ee0710a rw quiet udev.log_priority=3 audit=0
[  1257.581]
[  1257.582] Current version of pixman: 0.40.0
[  1257.585] 	Before reporting problems, check http://wiki.x.org
[  1257.585] Markers: (--) probed, (**) from config file, (==) default setting,
[  1257.593] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jan  3 15:02:19 2022
[  1257.595] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  1257.596] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  1257.596] (==) ServerLayout "layout"
[  1257.596] (==) No screen section available. Using defaults.
[  1257.596] (**) |-->Screen "Default Screen Section" (0)
[  1257.596] (**) |   |-->Monitor "<default monitor>"
[  1257.597] (==) No monitor specified for screen "Default Screen Section".
[  1257.597] (==) Automatically adding devices
[  1257.597] (==) Automatically enabling devices
[  1257.597] (==) Automatically adding GPU devices
[  1257.597] (==) Automatically binding GPU devices
[  1257.597] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  1257.597] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[  1257.597] 	Entry deleted from font path.
[  1257.597] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  1257.597] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[  1257.597] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[  1257.597] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[  1257.597] (==) ModulePath set to "/usr/lib/xorg/modules"
[  1257.597] (II) The server relies on udev to provide the list of input devices.
[  1257.597] (II) Module ABI versions:
[  1257.597] 	X.Org ANSI C Emulation: 0.4
[  1257.597] 	X.Org Video Driver: 25.2
[  1257.597] 	X.Org XInput driver : 24.4
[  1257.597] 	X.Org Server Extension : 10.0
[  1257.597] (++) using VT number 2
[  1257.599] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_34
[  1257.599] (II) xfree86: Adding drm device (/dev/dri/card0)
[  1257.599] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[  1257.600] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[  1257.600] (II) xfree86: Adding drm device (/dev/dri/card1)
[  1257.600] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card1
[  1257.601] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[  1257.602] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[  1257.602] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[  1257.603] (--) PCI:*(0@0:2:0) 8086:591b:1025:118a rev 4, Mem @ 0xa2000000/16777216, 0xb0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[  1257.603] (--) PCI: (1@0:0:0) 10de:1c8d:1025:118b rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[  1257.603] (II) Open ACPI successful (/var/run/acpid.socket)
[  1257.603] (II) LoadModule: "glx"
[  1257.603] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  1257.604] (II) Module glx: vendor="X.Org Foundation"
[  1257.604] 	compiled for 1.21.1.2, module version = 1.0.0
[  1257.604] 	ABI class: X.Org Server Extension, version 10.0
[  1257.604] (II) Applying OutputClass "intel" to /dev/dri/card1
[  1257.604] 	loading driver: modesetting
[  1257.604] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[  1257.604] 	loading driver: nvidia
[  1257.604] (==) Matched modesetting as autoconfigured driver 0
[  1257.604] (==) Matched nvidia as autoconfigured driver 1
[  1257.604] (==) Matched nouveau as autoconfigured driver 2
[  1257.604] (==) Matched nv as autoconfigured driver 3
[  1257.604] (==) Matched fbdev as autoconfigured driver 4
[  1257.604] (==) Matched vesa as autoconfigured driver 5
[  1257.604] (==) Assigned the driver to the xf86ConfigLayout
[  1257.604] (II) LoadModule: "modesetting"
[  1257.604] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[  1257.607] (II) Module modesetting: vendor="X.Org Foundation"
[  1257.607] 	compiled for 1.21.1.2, module version = 1.21.1
[  1257.607] 	Module class: X.Org Video Driver
[  1257.607] 	ABI class: X.Org Video Driver, version 25.2
[  1257.607] (II) LoadModule: "nvidia"
[  1257.607] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[  1257.607] (II) Module nvidia: vendor="NVIDIA Corporation"
[  1257.607] 	compiled for 1.6.99.901, module version = 1.0.0
[  1257.607] (II) LoadModule: "nouveau"
[  1257.607] (WW) Warning, couldn't open module nouveau
[  1257.607] (EE) Failed to load module "nouveau" (module does not exist, 0)
[  1257.607] (II) LoadModule: "nv"
[  1257.608] (WW) Warning, couldn't open module nv
[  1257.608] (EE) Failed to load module "nv" (module does not exist, 0)
[  1257.608] (II) LoadModule: "fbdev"
[  1257.608] (WW) Warning, couldn't open module fbdev
[  1257.608] (EE) Failed to load module "fbdev" (module does not exist, 0)
[  1257.608] (II) LoadModule: "vesa"
[  1257.608] (WW) Warning, couldn't open module vesa
[  1257.608] (EE) Failed to load module "vesa" (module does not exist, 0)
[  1257.608] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[  1257.608] (II) NVIDIA dlloader X Driver  495.44  Fri Oct 22 06:11:21 UTC 2021
[  1257.608] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[  1257.608] (II) modeset(0): using drv /dev/dri/card1
[  1257.608] (II) systemd-logind: releasing fd for 226:0
[  1257.609] (II) Loading sub module "fb"
[  1257.609] (II) LoadModule: "fb"
[  1257.609] (II) Module "fb" already built-in
[  1257.609] (II) Loading sub module "wfb"
[  1257.609] (II) LoadModule: "wfb"
[  1257.609] (II) Loading /usr/lib/xorg/modules/libwfb.so
[  1257.609] (II) Module wfb: vendor="X.Org Foundation"
[  1257.609] 	compiled for 1.21.1.2, module version = 1.0.0
[  1257.609] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  1257.609] (II) Loading sub module "ramdac"
[  1257.609] (II) LoadModule: "ramdac"
[  1257.609] (II) Module "ramdac" already built-in
[  1257.610] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[  1257.610] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[  1257.610] (==) modeset(0): RGB weight 888
[  1257.610] (==) modeset(0): Default visual is TrueColor
[  1257.610] (II) Loading sub module "glamoregl"
[  1257.610] (II) LoadModule: "glamoregl"
[  1257.610] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[  1257.613] (II) Module glamoregl: vendor="X.Org Foundation"
[  1257.613] 	compiled for 1.21.1.2, module version = 1.0.1
[  1257.613] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  1257.839] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 630 (KBL GT2)
[  1257.839] (II) modeset(0): glamor initialized
[  1257.839] (==) modeset(0): VariableRefresh: disabled
[  1257.839] (==) modeset(0): AsyncFlipSecondaries: disabled
[  1257.839] (II) modeset(0): Output eDP-1 has no monitor section
[  1257.840] (II) modeset(0): EDID for output eDP-1
[  1257.840] (II) modeset(0): Manufacturer: BOE  Model: 6c6  Serial#: 0
[  1257.840] (II) modeset(0): Year: 2016  Week: 1
[  1257.840] (II) modeset(0): EDID Version: 1.4
[  1257.840] (II) modeset(0): Digital Display Input
[  1257.840] (II) modeset(0): 6 bits per channel
[  1257.840] (II) modeset(0): Digital interface is DisplayPort
[  1257.840] (II) modeset(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[  1257.840] (II) modeset(0): Gamma: 2.20
[  1257.840] (II) modeset(0): No DPMS capabilities specified
[  1257.840] (II) modeset(0): Supported color encodings: RGB 4:4:4
[  1257.840] (II) modeset(0): First detailed timing is preferred mode
[  1257.840] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[  1257.840] (II) modeset(0): redX: 0.585 redY: 0.363   greenX: 0.350 greenY: 0.579
[  1257.840] (II) modeset(0): blueX: 0.162 blueY: 0.143   whiteX: 0.312 whiteY: 0.328
[  1257.840] (II) modeset(0): Manufacturer's mask: 0
[  1257.840] (II) modeset(0): Supported detailed timing:
[  1257.840] (II) modeset(0): clock: 152.6 MHz   Image Size:  344 x 194 mm
[  1257.841] (II) modeset(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2230 h_border: 0
[  1257.841] (II) modeset(0): v_active: 1080  v_sync: 1083  v_sync_end 1089 v_blanking: 1140 v_border: 0
[  1257.841] (II) modeset(0):  BOE CQ
[  1257.841] (II) modeset(0):  NV156FHM-N42
[  1257.841] (II) modeset(0): EDID (in hex):
[  1257.841] (II) modeset(0): 	00ffffffffffff0009e5c60600000000
[  1257.841] (II) modeset(0): 	011a01049522137802c9a0955d599429
[  1257.841] (II) modeset(0): 	24505400000001010101010101010101
[  1257.841] (II) modeset(0): 	0101010101019c3b803671383c403020
[  1257.841] (II) modeset(0): 	360058c21000001a0000000000000000
[  1257.841] (II) modeset(0): 	00000000000000000000000000fe0042
[  1257.841] (II) modeset(0): 	4f452043510a202020202020000000fe
[  1257.841] (II) modeset(0): 	004e5631353646484d2d4e34320a00cd
[  1257.841] (II) modeset(0): Printing probed modes for output eDP-1
[  1257.841] (II) modeset(0): Modeline "1920x1080"x60.0  152.60  1920 1968 2000 2230  1080 1083 1089 1140 +hsync -vsync (68.4 kHz eP)
[  1257.841] (II) modeset(0): Modeline "1920x1080"x120.0  356.38  1920 2080 2288 2656  1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[  1257.841] (II) modeset(0): Modeline "1920x1080"x119.9  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[  1257.841] (II) modeset(0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[  1257.841] (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[  1257.841] (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[  1257.841] (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[  1257.841] (II) modeset(0): Modeline "1600x900"x120.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[  1257.841] (II) modeset(0): Modeline "1600x900"x119.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
[  1257.841] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
[  1257.841] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "1440x810"x120.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[  1257.841] (II) modeset(0): Modeline "1440x810"x119.9  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[  1257.841] (II) modeset(0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
[  1257.841] (II) modeset(0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "1280x800"x120.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[  1257.841] (II) modeset(0): Modeline "1280x800"x119.9  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[  1257.841] (II) modeset(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
[  1257.841] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[  1257.841] (II) modeset(0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[  1257.841] (II) modeset(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[  1257.841] (II) modeset(0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[  1257.841] (II) modeset(0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[  1257.841] (II) modeset(0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[  1257.841] (II) modeset(0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[  1257.841] (II) modeset(0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[  1257.841] (II) modeset(0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[  1257.841] (II) modeset(0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[  1257.841] (II) modeset(0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[  1257.841] (II) modeset(0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[  1257.841] (II) modeset(0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[  1257.841] (II) modeset(0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[  1257.841] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[  1257.841] (II) modeset(0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[  1257.841] (II) modeset(0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[  1257.841] (II) modeset(0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[  1257.841] (II) modeset(0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[  1257.841] (II) modeset(0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[  1257.841] (II) modeset(0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[  1257.841] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[  1257.841] (II) modeset(0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[  1257.841] (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[  1257.841] (II) modeset(0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[  1257.841] (II) modeset(0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[  1257.841] (II) modeset(0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[  1257.841] (II) modeset(0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[  1257.841] (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[  1257.841] (II) modeset(0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[  1257.841] (II) modeset(0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[  1257.841] (II) modeset(0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[  1257.841] (II) modeset(0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[  1257.841] (II) modeset(0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[  1257.841] (II) modeset(0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[  1257.841] (II) modeset(0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[  1257.841] (II) modeset(0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[  1257.841] (II) modeset(0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[  1257.841] (II) modeset(0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[  1257.841] (II) modeset(0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[  1257.841] (II) modeset(0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[  1257.841] (II) modeset(0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[  1257.841] (II) modeset(0): Output eDP-1 connected
[  1257.841] (II) modeset(0): Using exact sizes for initial modes
[  1257.841] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[  1257.841] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[  1257.841] (==) modeset(0): DPI set to (96, 96)
[  1257.841] (II) Loading sub module "fb"
[  1257.841] (II) LoadModule: "fb"
[  1257.841] (II) Module "fb" already built-in
[  1257.841] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[  1257.842] (==) NVIDIA(G0): RGB weight 888
[  1257.842] (==) NVIDIA(G0): Default visual is TrueColor
[  1257.842] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[  1257.842] (**) Option "AllowNVIDIAGpuScreens"
[  1257.842] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[  1257.842] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[  1257.842] (**) NVIDIA(G0): Enabling 2D acceleration
[  1257.842] (II) Loading sub module "glxserver_nvidia"
[  1257.842] (II) LoadModule: "glxserver_nvidia"
[  1257.842] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[  1257.850] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[  1257.850] 	compiled for 1.6.99.901, module version = 1.0.0
[  1257.850] 	Module class: X.Org Server Extension
[  1257.850] (II) NVIDIA GLX Module  495.44  Fri Oct 22 06:08:29 UTC 2021
[  1257.850] (II) NVIDIA: The X server supports PRIME Render Offload.
[  1257.856] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[  1257.856] (--) NVIDIA(0):     DFP-0
[  1257.857] (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce GTX 1050 (GP107-A) at PCI:1:0:0
[  1257.857] (II) NVIDIA(G0):     (GPU-0)
[  1257.857] (--) NVIDIA(G0): Memory: 4194304 kBytes
[  1257.857] (--) NVIDIA(G0): VideoBIOS: 86.07.40.00.12
[  1257.857] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[  1257.857] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  1257.857] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  1257.857] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[  1257.857] (II) NVIDIA(G0): Validated MetaModes:
[  1257.857] (II) NVIDIA(G0):     "NULL"
[  1257.857] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[  1257.857] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
[  1257.857] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[  1257.916] (==) modeset(0): Backing store enabled
[  1257.916] (==) modeset(0): Silken mouse enabled
[  1257.997] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[  1257.997] (==) modeset(0): DPMS enabled
[  1257.997] (II) modeset(0): [DRI2] Setup complete
[  1257.997] (II) modeset(0): [DRI2]   DRI driver: iris
[  1257.997] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
[  1257.998] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[  1257.998] (II) NVIDIA:     access.
[  1258.049] (II) NVIDIA(G0): Setting mode "NULL"
[  1258.055] (==) NVIDIA(G0): Disabling shared memory pixmaps
[  1258.055] (==) NVIDIA(G0): Backing store enabled
[  1258.055] (==) NVIDIA(G0): Silken mouse enabled
[  1258.055] (==) NVIDIA(G0): DPMS enabled
[  1258.055] (II) Loading sub module "dri2"
[  1258.056] (II) LoadModule: "dri2"
[  1258.056] (II) Module "dri2" already built-in
[  1258.056] (II) NVIDIA(G0): [DRI2] Setup complete
[  1258.056] (II) NVIDIA(G0): [DRI2]   VDPAU driver: nvidia
[  1258.056] (II) Initializing extension Generic Event Extension
[  1258.056] (II) Initializing extension SHAPE
[  1258.056] (II) Initializing extension MIT-SHM
[  1258.056] (II) Initializing extension XInputExtension
[  1258.056] (II) Initializing extension XTEST
[  1258.056] (II) Initializing extension BIG-REQUESTS
[  1258.056] (II) Initializing extension SYNC
[  1258.056] (II) Initializing extension XKEYBOARD
[  1258.056] (II) Initializing extension XC-MISC
[  1258.056] (II) Initializing extension SECURITY
[  1258.057] (II) Initializing extension XFIXES
[  1258.057] (II) Initializing extension RENDER
[  1258.057] (II) Initializing extension RANDR
[  1258.057] (II) Initializing extension COMPOSITE
[  1258.057] (II) Initializing extension DAMAGE
[  1258.057] (II) Initializing extension MIT-SCREEN-SAVER
[  1258.057] (II) Initializing extension DOUBLE-BUFFER
[  1258.057] (II) Initializing extension RECORD
[  1258.057] (II) Initializing extension DPMS
[  1258.057] (II) Initializing extension Present
[  1258.058] (II) Initializing extension DRI3
[  1258.058] (II) Initializing extension X-Resource
[  1258.058] (II) Initializing extension XVideo
[  1258.058] (II) Initializing extension XVideo-MotionCompensation
[  1258.058] (II) Initializing extension GLX
[  1258.058] (II) Indirect GLX disabled.
[  1258.063] (II) AIGLX: Loaded and initialized iris
[  1258.063] (II) GLX: Initialized DRI2 GL provider for screen 0
[  1258.063] (II) Initializing extension XFree86-VidModeExtension
[  1258.063] (II) Initializing extension XFree86-DGA
[  1258.063] (II) Initializing extension XFree86-DRI
[  1258.063] (II) Initializing extension DRI2
[  1258.064] (II) Initializing extension NV-GLX
[  1258.064] (II) Initializing extension NV-CONTROL
[  1258.064] (II) modeset(0): Damage tracking initialized
[  1258.064] (II) modeset(0): Setting screen physical size to 508 x 285
[  1258.095] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[  1258.095] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  1258.095] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  1258.095] (**) Power Button: Applying InputClass "system-keyboard"
[  1258.095] (II) LoadModule: "libinput"
[  1258.095] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  1258.096] (II) Module libinput: vendor="X.Org Foundation"
[  1258.097] 	compiled for 1.21.1, module version = 1.2.0
[  1258.097] 	Module class: X.Org XInput Driver
[  1258.097] 	ABI class: X.Org XInput driver, version 24.4
[  1258.097] (II) Using input driver 'libinput' for 'Power Button'
[  1258.097] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 47 paused 0
[  1258.097] (**) Power Button: always reports core events
[  1258.097] (**) Option "Device" "/dev/input/event3"
[  1258.097] (**) Option "_source" "server/udev"
[  1258.099] (II) event3  - Power Button: is tagged by udev as: Keyboard
[  1258.099] (II) event3  - Power Button: device is a keyboard
[  1258.099] (II) event3  - Power Button: device removed
[  1258.099] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[  1258.099] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  1258.099] (**) Option "xkb_model" "pc105"
[  1258.099] (**) Option "xkb_layout" "us"
[  1258.100] (II) config/udev: Adding input device Video Bus (/dev/input/event14)
[  1258.100] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[  1258.100] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[  1258.100] (**) Video Bus: Applying InputClass "system-keyboard"
[  1258.100] (II) Using input driver 'libinput' for 'Video Bus'
[  1258.100] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 50 paused 0
[  1258.101] (**) Video Bus: always reports core events
[  1258.101] (**) Option "Device" "/dev/input/event14"
[  1258.101] (**) Option "_source" "server/udev"
[  1258.101] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[  1258.101] (II) event14 - Video Bus: device is a keyboard
[  1258.101] (II) event14 - Video Bus: device removed
[  1258.101] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input15/event14"
[  1258.101] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[  1258.101] (**) Option "xkb_model" "pc105"
[  1258.101] (**) Option "xkb_layout" "us"
[  1258.102] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[  1258.102] (II) event14 - Video Bus: device is a keyboard
[  1258.103] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[  1258.103] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[  1258.103] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[  1258.103] (**) Video Bus: Applying InputClass "system-keyboard"
[  1258.103] (II) Using input driver 'libinput' for 'Video Bus'
[  1258.103] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 51 paused 0
[  1258.103] (**) Video Bus: always reports core events
[  1258.103] (**) Option "Device" "/dev/input/event13"
[  1258.103] (**) Option "_source" "server/udev"
[  1258.104] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[  1258.104] (II) event13 - Video Bus: device is a keyboard
[  1258.104] (II) event13 - Video Bus: device removed
[  1258.104] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input14/event13"
[  1258.104] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[  1258.104] (**) Option "xkb_model" "pc105"
[  1258.104] (**) Option "xkb_layout" "us"
[  1258.105] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[  1258.105] (II) event13 - Video Bus: device is a keyboard
[  1258.105] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[  1258.105] (II) No input driver specified, ignoring this device.
[  1258.105] (II) This device may have been added with another device file.
[  1258.106] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[  1258.106] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  1258.106] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  1258.106] (**) Power Button: Applying InputClass "system-keyboard"
[  1258.106] (II) Using input driver 'libinput' for 'Power Button'
[  1258.106] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 52 paused 0
[  1258.107] (**) Power Button: always reports core events
[  1258.107] (**) Option "Device" "/dev/input/event2"
[  1258.107] (**) Option "_source" "server/udev"
[  1258.107] (II) event2  - Power Button: is tagged by udev as: Keyboard
[  1258.107] (II) event2  - Power Button: device is a keyboard
[  1258.107] (II) event2  - Power Button: device removed
[  1258.107] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[  1258.107] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[  1258.107] (**) Option "xkb_model" "pc105"
[  1258.107] (**) Option "xkb_layout" "us"
[  1258.108] (II) event2  - Power Button: is tagged by udev as: Keyboard
[  1258.108] (II) event2  - Power Button: device is a keyboard
[  1258.108] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[  1258.108] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[  1258.108] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[  1258.108] (**) Sleep Button: Applying InputClass "system-keyboard"
[  1258.108] (II) Using input driver 'libinput' for 'Sleep Button'
[  1258.109] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 53 paused 0
[  1258.109] (**) Sleep Button: always reports core events
[  1258.109] (**) Option "Device" "/dev/input/event1"
[  1258.109] (**) Option "_source" "server/udev"
[  1258.110] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[  1258.110] (II) event1  - Sleep Button: device is a keyboard
[  1258.110] (II) event1  - Sleep Button: device removed
[  1258.110] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[  1258.110] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[  1258.110] (**) Option "xkb_model" "pc105"
[  1258.110] (**) Option "xkb_layout" "us"
[  1258.111] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[  1258.111] (II) event1  - Sleep Button: device is a keyboard
[  1258.111] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event15)
[  1258.111] (II) No input driver specified, ignoring this device.
[  1258.111] (II) This device may have been added with another device file.
[  1258.111] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event16)
[  1258.112] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event17)
[  1258.112] (II) No input driver specified, ignoring this device.
[  1258.112] (II) This device may have been added with another device file.
[  1258.112] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event18)
[  1258.113] (II) config/udev: Adding input device LXD Gaming Mouse (/dev/input/event8)
[  1258.113] (**) LXD Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[  1258.113] (**) LXD Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[  1258.113] (**) LXD Gaming Mouse: Applying InputClass "system-keyboard"
[  1258.113] (II) Using input driver 'libinput' for 'LXD Gaming Mouse'
[  1258.113] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 54 paused 0
[  1258.113] (**) LXD Gaming Mouse: always reports core events
[  1258.113] (**) Option "Device" "/dev/input/event8"
[  1258.113] (**) Option "_source" "server/udev"
[  1258.114] (II) event8  - LXD Gaming Mouse: is tagged by udev as: Keyboard
[  1258.114] (II) event8  - LXD Gaming Mouse: device is a keyboard
[  1258.115] (II) event8  - LXD Gaming Mouse: device removed
[  1258.115] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:1D57:AD03.0001/input/input9/event8"
[  1258.115] (II) XINPUT: Adding extended input device "LXD Gaming Mouse" (type: KEYBOARD, id 11)
[  1258.115] (**) Option "xkb_model" "pc105"
[  1258.115] (**) Option "xkb_layout" "us"
[  1258.116] (II) event8  - LXD Gaming Mouse: is tagged by udev as: Keyboard
[  1258.116] (II) event8  - LXD Gaming Mouse: device is a keyboard
[  1258.116] (II) config/udev: Adding input device LXD Gaming Mouse (/dev/input/event10)
[  1258.116] (**) LXD Gaming Mouse: Applying InputClass "evdev pointer catchall"
[  1258.116] (**) LXD Gaming Mouse: Applying InputClass "libinput pointer catchall"
[  1258.116] (II) Using input driver 'libinput' for 'LXD Gaming Mouse'
[  1258.117] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 55 paused 0
[  1258.117] (**) LXD Gaming Mouse: always reports core events
[  1258.117] (**) Option "Device" "/dev/input/event10"
[  1258.117] (**) Option "_source" "server/udev"
[  1258.118] (II) event10 - LXD Gaming Mouse: is tagged by udev as: Mouse
[  1258.118] (II) event10 - LXD Gaming Mouse: device is a pointer
[  1258.119] (II) event10 - LXD Gaming Mouse: device removed
[  1258.119] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:1D57:AD03.0002/input/input11/event10"
[  1258.119] (II) XINPUT: Adding extended input device "LXD Gaming Mouse" (type: MOUSE, id 12)
[  1258.119] (**) Option "AccelerationScheme" "none"
[  1258.119] (**) LXD Gaming Mouse: (accel) selected scheme none/0
[  1258.119] (**) LXD Gaming Mouse: (accel) acceleration factor: 2.000
[  1258.119] (**) LXD Gaming Mouse: (accel) acceleration threshold: 4
[  1258.120] (II) event10 - LXD Gaming Mouse: is tagged by udev as: Mouse
[  1258.120] (II) event10 - LXD Gaming Mouse: device is a pointer
[  1258.120] (II) config/udev: Adding input device LXD Gaming Mouse (/dev/input/mouse1)
[  1258.120] (II) No input driver specified, ignoring this device.
[  1258.120] (II) This device may have been added with another device file.
[  1258.121] (II) config/udev: Adding input device LXD Gaming Mouse Consumer Control (/dev/input/event11)
[  1258.121] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[  1258.121] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[  1258.121] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[  1258.121] (II) Using input driver 'libinput' for 'LXD Gaming Mouse Consumer Control'
[  1258.122] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 56 paused 0
[  1258.122] (**) LXD Gaming Mouse Consumer Control: always reports core events
[  1258.122] (**) Option "Device" "/dev/input/event11"
[  1258.122] (**) Option "_source" "server/udev"
[  1258.123] (II) event11 - LXD Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[  1258.123] (II) event11 - LXD Gaming Mouse Consumer Control: device is a keyboard
[  1258.123] (II) event11 - LXD Gaming Mouse Consumer Control: device removed
[  1258.123] (II) libinput: LXD Gaming Mouse Consumer Control: needs a virtual subdevice
[  1258.123] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:1D57:AD03.0002/input/input12/event11"
[  1258.123] (II) XINPUT: Adding extended input device "LXD Gaming Mouse Consumer Control" (type: MOUSE, id 13)
[  1258.123] (**) Option "AccelerationScheme" "none"
[  1258.123] (**) LXD Gaming Mouse Consumer Control: (accel) selected scheme none/0
[  1258.123] (**) LXD Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
[  1258.123] (**) LXD Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
[  1258.124] (II) event11 - LXD Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[  1258.124] (II) event11 - LXD Gaming Mouse Consumer Control: device is a keyboard
[  1258.125] (II) config/udev: Adding input device LXD Gaming Mouse System Control (/dev/input/event12)
[  1258.125] (**) LXD Gaming Mouse System Control: Applying InputClass "evdev keyboard catchall"
[  1258.125] (**) LXD Gaming Mouse System Control: Applying InputClass "libinput keyboard catchall"
[  1258.125] (**) LXD Gaming Mouse System Control: Applying InputClass "system-keyboard"
[  1258.125] (II) Using input driver 'libinput' for 'LXD Gaming Mouse System Control'
[  1258.125] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 57 paused 0
[  1258.125] (**) LXD Gaming Mouse System Control: always reports core events
[  1258.125] (**) Option "Device" "/dev/input/event12"
[  1258.125] (**) Option "_source" "server/udev"
[  1258.126] (II) event12 - LXD Gaming Mouse System Control: is tagged by udev as: Keyboard
[  1258.126] (II) event12 - LXD Gaming Mouse System Control: device is a keyboard
[  1258.127] (II) event12 - LXD Gaming Mouse System Control: device removed
[  1258.127] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:1D57:AD03.0002/input/input13/event12"
[  1258.127] (II) XINPUT: Adding extended input device "LXD Gaming Mouse System Control" (type: KEYBOARD, id 14)
[  1258.127] (**) Option "xkb_model" "pc105"
[  1258.127] (**) Option "xkb_layout" "us"
[  1258.128] (II) event12 - LXD Gaming Mouse System Control: is tagged by udev as: Keyboard
[  1258.128] (II) event12 - LXD Gaming Mouse System Control: device is a keyboard
[  1258.128] (II) config/udev: Adding input device HD WebCam: HD WebCam (/dev/input/event9)
[  1258.128] (**) HD WebCam: HD WebCam: Applying InputClass "evdev keyboard catchall"
[  1258.129] (**) HD WebCam: HD WebCam: Applying InputClass "libinput keyboard catchall"
[  1258.129] (**) HD WebCam: HD WebCam: Applying InputClass "system-keyboard"
[  1258.129] (II) Using input driver 'libinput' for 'HD WebCam: HD WebCam'
[  1258.129] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 58 paused 0
[  1258.129] (**) HD WebCam: HD WebCam: always reports core events
[  1258.129] (**) Option "Device" "/dev/input/event9"
[  1258.129] (**) Option "_source" "server/udev"
[  1258.130] (II) event9  - HD WebCam: HD WebCam: is tagged by udev as: Keyboard
[  1258.130] (II) event9  - HD WebCam: HD WebCam: device is a keyboard
[  1258.130] (II) event9  - HD WebCam: HD WebCam: device removed
[  1258.130] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/input/input10/event9"
[  1258.130] (II) XINPUT: Adding extended input device "HD WebCam: HD WebCam" (type: KEYBOARD, id 15)
[  1258.130] (**) Option "xkb_model" "pc105"
[  1258.130] (**) Option "xkb_layout" "us"
[  1258.131] (II) event9  - HD WebCam: HD WebCam: is tagged by udev as: Keyboard
[  1258.131] (II) event9  - HD WebCam: HD WebCam: device is a keyboard
[  1258.132] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event19)
[  1258.132] (II) No input driver specified, ignoring this device.
[  1258.132] (II) This device may have been added with another device file.
[  1258.132] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[  1258.132] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[  1258.132] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[  1258.132] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[  1258.132] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[  1258.133] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 59 paused 0
[  1258.133] (**) AT Translated Set 2 keyboard: always reports core events
[  1258.133] (**) Option "Device" "/dev/input/event4"
[  1258.133] (**) Option "_source" "server/udev"
[  1258.134] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[  1258.134] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[  1258.134] (II) event4  - AT Translated Set 2 keyboard: device removed
[  1258.134] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[  1258.134] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[  1258.134] (**) Option "xkb_model" "pc105"
[  1258.134] (**) Option "xkb_layout" "us"
[  1258.135] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[  1258.135] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[  1258.136] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event7)
[  1258.136] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[  1258.136] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[  1258.136] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[  1258.137] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 60 paused 0
[  1258.137] (**) SynPS/2 Synaptics TouchPad: always reports core events
[  1258.137] (**) Option "Device" "/dev/input/event7"
[  1258.137] (**) Option "_source" "server/udev"
[  1258.137] (II) event7  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[  1258.138] (II) event7  - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[  1258.139] (II) event7  - SynPS/2 Synaptics TouchPad: device is a touchpad
[  1258.139] (II) event7  - SynPS/2 Synaptics TouchPad: device removed
[  1258.139] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input6/event7"
[  1258.139] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 17)
[  1258.140] (**) Option "AccelerationScheme" "none"
[  1258.140] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[  1258.140] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[  1258.140] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[  1258.140] (II) event7  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[  1258.141] (II) event7  - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[  1258.142] (II) event7  - SynPS/2 Synaptics TouchPad: device is a touchpad
[  1258.142] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[  1258.142] (II) No input driver specified, ignoring this device.
[  1258.142] (II) This device may have been added with another device file.
[  1258.143] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[  1258.143] (II) No input driver specified, ignoring this device.
[  1258.143] (II) This device may have been added with another device file.
[  1258.145] (II) config/udev: Adding input device Acer WMI hotkeys (/dev/input/event6)
[  1258.145] (**) Acer WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[  1258.145] (**) Acer WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[  1258.145] (**) Acer WMI hotkeys: Applying InputClass "system-keyboard"
[  1258.145] (II) Using input driver 'libinput' for 'Acer WMI hotkeys'
[  1258.145] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 61 paused 0
[  1258.145] (**) Acer WMI hotkeys: always reports core events
[  1258.145] (**) Option "Device" "/dev/input/event6"
[  1258.145] (**) Option "_source" "server/udev"
[  1258.146] (II) event6  - Acer WMI hotkeys: is tagged by udev as: Keyboard
[  1258.146] (II) event6  - Acer WMI hotkeys: device is a keyboard
[  1258.146] (II) event6  - Acer WMI hotkeys: device removed
[  1258.146] (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event6"
[  1258.146] (II) XINPUT: Adding extended input device "Acer WMI hotkeys" (type: KEYBOARD, id 18)
[  1258.146] (**) Option "xkb_model" "pc105"
[  1258.146] (**) Option "xkb_layout" "us"
[  1258.171] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[  1258.171] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[  1258.171] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[  1258.171] (II) Using input driver 'libinput' for 'LXD Gaming Mouse Consumer Control'
[  1258.171] (II) systemd-logind: returning pre-existing fd for /dev/input/event11 13:75
[  1258.171] (**) LXD Gaming Mouse Consumer Control: always reports core events
[  1258.171] (**) Option "Device" "/dev/input/event11"
[  1258.171] (**) Option "_source" "_driver/libinput"
[  1258.171] (II) libinput: LXD Gaming Mouse Consumer Control: is a virtual subdevice
[  1258.171] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:1D57:AD03.0002/input/input12/event11"
[  1258.171] (II) XINPUT: Adding extended input device "LXD Gaming Mouse Consumer Control" (type: KEYBOARD, id 19)
[  1258.171] (**) Option "xkb_model" "pc105"
[  1258.171] (**) Option "xkb_layout" "us"
[  1258.779] (II) modeset(0): EDID vendor "BOE", prod id 1734
[  1258.779] (II) modeset(0): Printing DDC gathered Modelines:
[  1258.779] (II) modeset(0): Modeline "1920x1080"x0.0  152.60  1920 1968 2000 2230  1080 1083 1089 1140 +hsync -vsync (68.4 kHz eP)
[  1258.796] (II) modeset(0): EDID vendor "BOE", prod id 1734
[  1258.796] (II) modeset(0): Printing DDC gathered Modelines:
[  1258.796] (II) modeset(0): Modeline "1920x1080"x0.0  152.60  1920 1968 2000 2230  1080 1083 1089 1140 +hsync -vsync (68.4 kHz eP)
[  1258.796] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  1258.796] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  1258.796] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[  7171.628] (EE) event10 - LXD Gaming Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
lightdm
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.30.0, UID=0 PID=767
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0.01s] DEBUG: Monitoring logind for seats
[+0.01s] DEBUG: New seat added from logind: seat0
[+0.01s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.01s] DEBUG: Seat seat0 has property CanMultiSession=no
[+0.01s] DEBUG: Seat seat0: Starting
[+0.01s] DEBUG: Seat seat0: Creating greeter session
[+0.01s] DEBUG: Seat seat0: Creating display server of type x
[+0.01s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+0.01s] DEBUG: Using VT 7
[+0.01s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.01s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.01s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.01s] DEBUG: XServer 0: Launching X Server
[+0.01s] DEBUG: Launching process 773: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.01s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.01s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.01s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.01s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.01s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+1.84s] DEBUG: Got signal 10 from process 773
[+1.84s] DEBUG: XServer 0: Got signal from X server :0
[+1.84s] DEBUG: XServer 0: Connecting to XServer :0
[+1.95s] DEBUG: Seat seat0: Display server ready, starting session authentication
[+1.95s] DEBUG: Session pid=792: Started with service 'lightdm-greeter', username 'lightdm'
[+1.97s] DEBUG: Session pid=792: Authentication complete with return value 0: Success
[+1.97s] DEBUG: Seat seat0: Session authenticated, running command
[+1.97s] DEBUG: Session pid=792: Running command /usr/bin/lightdm-gtk-greeter
[+1.97s] DEBUG: Creating shared data directory /var/lib/lightdm-data/lightdm
[+1.97s] DEBUG: Session pid=792: Logging to /var/log/lightdm/seat0-greeter.log
[+2.13s] DEBUG: Activating VT 7
[+2.13s] DEBUG: Activating login1 session c1
[+2.13s] DEBUG: Seat seat0 changes active session to c1
[+2.13s] DEBUG: Session c1 is already active
[+2.35s] DEBUG: Greeter connected version=1.30.0 api=1 resettable=false
[+2.54s] DEBUG: Greeter start authentication for darren
[+2.54s] DEBUG: Session pid=845: Started with service 'lightdm', username 'darren'
[+2.55s] DEBUG: Session pid=845: Got 1 message(s) from PAM
[+2.55s] DEBUG: Prompt greeter with 1 message(s)
[+6.42s] DEBUG: Continue authentication
[+6.46s] DEBUG: Session pid=845: Authentication complete with return value 0: Success
[+6.46s] DEBUG: Authenticate result for user darren: Success
[+6.46s] DEBUG: User darren authorized
[+6.46s] DEBUG: Greeter sets language en_US.utf8
[+6.52s] DEBUG: Greeter requests session xfce
[+6.52s] DEBUG: Seat seat0: Stopping greeter; display server will be re-used for user session
[+6.52s] DEBUG: Terminating login1 session c1
[+6.53s] DEBUG: Session pid=792: Sending SIGTERM
[+6.56s] DEBUG: Greeter closed communication channel
[+6.56s] DEBUG: Session pid=792: Exited with return value 0
[+6.56s] DEBUG: Seat seat0: Session stopped
[+6.56s] DEBUG: Seat seat0: Greeter stopped, running session
[+6.56s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session0
[+6.57s] DEBUG: Session pid=845: Running command /etc/lightdm/Xsession startxfce4
[+6.57s] DEBUG: Creating shared data directory /var/lib/lightdm-data/darren
[+6.57s] DEBUG: Session pid=845: Logging to .xsession-errors
[+6.77s] DEBUG: Activating VT 7
[+6.77s] DEBUG: Activating login1 session 2
[+6.77s] DEBUG: Seat seat0 changes active session to
[+6.77s] DEBUG: Seat seat0 changes active session to 2
[+6.77s] DEBUG: Session 2 is already active
[+9.72s] DEBUG: Seat seat0 changes active session to
[+14.90s] DEBUG: Seat seat0 changes active session to 4
[+27.14s] DEBUG: Got signal 15 from process 1
[+27.14s] DEBUG: Caught Terminated signal, shutting down
[+27.14s] DEBUG: Stopping display manager
[+27.14s] DEBUG: Seat seat0: Stopping
[+27.14s] DEBUG: Seat seat0: Stopping display server
[+27.14s] DEBUG: Sending signal 15 to process 773
[+27.14s] DEBUG: Seat seat0: Stopping session
[+27.14s] DEBUG: Terminating login1 session 2
[+27.14s] DEBUG: Session pid=845: Sending SIGTERM
[+27.14s] DEBUG: Session pid=845: Exited with return value 0
[+27.14s] DEBUG: Seat seat0: Session stopped
[+27.20s] DEBUG: Process 773 exited with return value 0
[+27.20s] DEBUG: XServer 0: X server stopped
[+27.20s] DEBUG: Releasing VT 7
[+27.20s] DEBUG: XServer 0: Removing X server authority /run/lightdm/root/:0
[+27.20s] DEBUG: Seat seat0: Display server stopped
[+27.20s] DEBUG: Seat seat0: Stopped
[+27.20s] DEBUG: Display manager stopped
[+27.20s] DEBUG: Stopping daemon
[+27.20s] DEBUG: Exiting with return value 0
thanks
edit: Before the update i had optimus-switch installed, and set to intel mode, with the same drivers as above. I uninstalled it incase of issue.
The error log indicates that it’s because of plymouth. If you removed it, you should check if it’s still enabled somewhere because it tries to run it.
Near in this thread : https://forum.manjaro.org/t/x-wouldn-t-start-properly-after-upgrade/97217/14
The kernel module is not loaded
sudo modprobe nvidia
and try :
sudo systemctl disable plymouth.service
This i do have everyday in my ligthdm.log. And it runs without problem. This is a false positive :wink:
The real problem lies here:
Thank you, i had a look at plymouth on arch wiki, couldn’t find any of the related systemd services or config files, no mention of plymouth in lightdm config.
i’ll look at the nvidia config.
  1. start your desktop with startx
  2. look what module is used in /var/log/Xorg.log
  3. look what module is loaded with lsmod
  4. Then if you know for sure, include this module (nvidia or nouveau) in your initramdisk (mkinitcpio.conf)
  • MODULES=(btrfs nouveau) ?
here is mine to compare:
cat /etc/mkinitcpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(piix ide_disk reiserfs)
#akf
# nouveau hier einzutragen aktiviert kms frühzeitig.
#MODULES=(btrfs)
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image.  This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way.  This is useful for config files.
FILES=()
# HOOKS
# This is the most important setting in this file.  The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added.  Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
##   This setup specifies all modules in the MODULES setting above.
##   No raid, lvm2, or encrypted root is needed.
#    HOOKS=(base)
##   This setup will autodetect all modules for your system and should
##   work as a sane default
#    HOOKS=(base udev autodetect block filesystems)
##   This setup will generate a 'full' image which supports most systems.
##   No autodetection is done.
#    HOOKS=(base udev block filesystems)
##   This setup assembles a pata mdadm array with an encrypted root FS.
##   Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
#    HOOKS=(base udev block mdadm encrypt filesystems)
##   This setup loads an lvm2 volume group on a usb device.
#    HOOKS=(base udev block lvm2 filesystems)
##   NOTE: If you have /usr on a separate partition, you MUST include the
#    usr, fsck and shutdown hooks.
#akf
HOOKS=(base udev systemd autodetect modconf block keyboard sd-vconsole filesystems bootsplash-manjaro)
#HOOKS=(base systemd autodetect modconf block keyboard sd-vconsole filesystems bootsplash-manjaro)
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#akf
COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
xorg log reports nvidia is loaded ok, while failing nouveau and others as posted above.
lsmod|grep nvidia
nvidia_uvm           1179648  0
nvidia_drm             73728  2
nvidia_modeset       1155072  3 nvidia_drm
drm_kms_helper        270336  2 nvidia_drm,i915
nvidia              36954112  90 nvidia_uvm,nvidia_modeset
drm                   569344  14 drm_kms_helper,nvidia,nvidia_drm,i915
lsmod|grep nouveau is blank
my etc/mkinitcpio.conf
MODULES=()
adding nvidia to the above has no effect.
when unistalling optimus-switch it does state xorg won’t work until another optimus setup is used.
perhaps i naively assumed simply reinstalling the hybrid nvidia driver alone would be enough.
i might try bumblebee, though it won’t explain why it went wrong in the first place.
I’ve gone through optimus-switch setup again. I can still progress with startx.
No change to lightdm issue, however it appears to switch correctly between intel(modesetting) and nvidia drivers from xorg, lsmod output.
Can i disbale lightdm with systemd or otherwise to prevent locking up while i’m away from the machine?
thanks for all the help so far, i am grateful.
Is nouveau installed, even you don´t use it `?
nouveau is not installed(intentionally), not sure why xorg tries to load in nvidia mode yet. my mhwd list is shown above.
I feel that optimus switch is working correctly, the system starts with desired intel/nvidia mode on demand. Might not be graphical related issue.
Here is the xorg log from intel(modesetting driver) mode. (nvidia is completly disabled as intended per optimus switch)
[   181.136]
[   181.137] Current Operating System: Linux abo 5.10.89-1-MANJARO #1 SMP PREEMPT Wed Dec 29 18:09:17 UTC 2021 x86_64
[   181.137] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=fc78c783-d447-4b7e-a61a-a4e12ee0710a rw quiet udev.log_priority=3 audit=0
[   181.137]
[   181.137] Current version of pixman: 0.40.0
[   181.137] 	Before reporting problems, check http://wiki.x.org
[   181.137] Markers: (--) probed, (**) from config file, (==) default setting,
[   181.137] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jan  4 21:00:50 2022
[   181.137] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   181.137] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   181.137] (==) ServerLayout "layout"
[   181.137] (==) No screen section available. Using defaults.
[   181.137] (**) |-->Screen "Default Screen Section" (0)
[   181.137] (**) |   |-->Monitor "<default monitor>"
[   181.137] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[   181.137] (**) |   |-->Device "Intel Graphics"
[   181.137] (==) No monitor specified for screen "Default Screen Section".
[   181.137] (==) Automatically adding devices
[   181.137] (==) Automatically enabling devices
[   181.137] (==) Automatically adding GPU devices
[   181.137] (==) Automatically binding GPU devices
[   181.137] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   181.137] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[   181.137] 	Entry deleted from font path.
[   181.137] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   181.137] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[   181.137] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[   181.137] (==) FontPath set to:
[   181.137] (==) ModulePath set to "/usr/lib/xorg/modules"
[   181.137] (II) The server relies on udev to provide the list of input devices.
[   181.137] (II) Module ABI versions:
[   181.137] 	X.Org ANSI C Emulation: 0.4
[   181.137] 	X.Org Video Driver: 25.2
[   181.137] 	X.Org XInput driver : 24.4
[   181.137] 	X.Org Server Extension : 10.0
[   181.138] (++) using VT number 7
[   181.138] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   181.138] (II) xfree86: Adding drm device (/dev/dri/card0)
[   181.138] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[   181.153] (--) PCI:*(0@0:2:0) 8086:591b:1025:118a rev 4, Mem @ 0xa2000000/16777216, 0xb0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[   181.154] (II) Open ACPI successful (/var/run/acpid.socket)
[   181.154] (II) LoadModule: "glx"
[   181.154] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   181.157] (II) Module glx: vendor="X.Org Foundation"
[   181.158] 	compiled for 1.21.1.2, module version = 1.0.0
[   181.158] 	ABI class: X.Org Server Extension, version 10.0
[   181.158] (II) LoadModule: "intel"
[   181.158] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[   181.158] (II) Module intel: vendor="X.Org Foundation"
[   181.158] 	compiled for 1.21.1.1, module version = 2.99.917
[   181.158] 	Module class: X.Org Video Driver
[   181.158] 	ABI class: X.Org Video Driver, version 25.2
[   181.158] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[   181.159] (II) intel: Driver for Intel(R) HD Graphics
[   181.159] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[   181.159] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[   181.174] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200917
[   181.174] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[   181.193] (--) intel(0): gen9 engineering sample
[   181.193] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[   181.193] (II) intel(0): Creating default Display subsection in Screen section
[   181.193] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[   181.193] (==) intel(0): RGB weight 888
[   181.193] (==) intel(0): Default visual is TrueColor
[   181.193] (**) intel(0): Option "DRI" "3"
[   181.193] (**) intel(0): Option "TearFree" "true"
[   181.194] (II) intel(0): Output eDP1 has no monitor section
[   181.195] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[   181.195] (II) intel(0): Enabled output eDP1
[   181.195] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[   181.195] (II) intel(0): Output VIRTUAL1 has no monitor section
[   181.195] (II) intel(0): Enabled output VIRTUAL1
[   181.195] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0
[   181.195] (**) intel(0): TearFree enabled
[   181.195] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[   181.195] (==) intel(0): DPI set to (96, 96)
[   181.195] (II) Loading sub module "dri3"
[   181.195] (II) LoadModule: "dri3"
[   181.195] (II) Module "dri3" already built-in
[   181.195] (II) Loading sub module "dri2"
[   181.195] (II) LoadModule: "dri2"
[   181.195] (II) Module "dri2" already built-in
[   181.195] (II) Loading sub module "present"
[   181.195] (II) LoadModule: "present"
[   181.195] (II) Module "present" already built-in
[   181.196] (II) intel(0): SNA initialized with Kabylake (gen9) backend
[   181.196] (==) intel(0): Backing store enabled
[   181.196] (==) intel(0): Silken mouse enabled
[   181.196] (II) intel(0): HW Cursor enabled
[   181.196] (==) intel(0): DPMS enabled
[   181.197] (==) intel(0): Display hotplug detection enabled
[   181.197] (II) intel(0): [DRI2] Setup complete
[   181.197] (II) intel(0): [DRI2]   DRI driver: i965
[   181.197] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[   181.197] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[   181.197] (II) intel(0): hardware support for Present enabled
[   181.197] (II) Initializing extension Generic Event Extension
[   181.197] (II) Initializing extension SHAPE
[   181.197] (II) Initializing extension MIT-SHM
[   181.198] (II) Initializing extension XInputExtension
[   181.198] (II) Initializing extension XTEST
[   181.198] (II) Initializing extension BIG-REQUESTS
[   181.199] (II) Initializing extension SYNC
[   181.199] (II) Initializing extension XKEYBOARD
[   181.199] (II) Initializing extension XC-MISC
[   181.200] (II) Initializing extension SECURITY
[   181.200] (II) Initializing extension XFIXES
[   181.200] (II) Initializing extension RENDER
[   181.201] (II) Initializing extension RANDR
[   181.201] (II) Initializing extension COMPOSITE
[   181.201] (II) Initializing extension DAMAGE
[   181.202] (II) Initializing extension MIT-SCREEN-SAVER
[   181.202] (II) Initializing extension DOUBLE-BUFFER
[   181.202] (II) Initializing extension RECORD
[   181.203] (II) Initializing extension DPMS
[   181.203] (II) Initializing extension Present
[   181.203] (II) Initializing extension DRI3
[   181.203] (II) Initializing extension X-Resource
[   181.204] (II) Initializing extension XVideo
[   181.204] (II) Initializing extension XVideo-MotionCompensation
[   181.204] (II) Initializing extension GLX
[   181.219] (II) AIGLX: Loaded and initialized i965
[   181.219] (II) GLX: Initialized DRI2 GL provider for screen 0
[   181.219] (II) Initializing extension XFree86-VidModeExtension
[   181.219] (II) Initializing extension XFree86-DGA
[   181.219] (II) Initializing extension XFree86-DRI
[   181.219] (II) Initializing extension DRI2
[   181.223] (II) intel(0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[   181.231] (II) intel(0): Setting screen physical size to 508 x 285
[   181.261] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[   181.261] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   181.261] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   181.261] (**) Power Button: Applying InputClass "system-keyboard"
[   181.261] (II) LoadModule: "libinput"
[   181.261] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   181.262] (II) Module libinput: vendor="X.Org Foundation"
[   181.262] 	compiled for 1.21.1, module version = 1.2.0
[   181.262] 	Module class: X.Org XInput Driver
[   181.262] 	ABI class: X.Org XInput driver, version 24.4
[   181.262] (II) Using input driver 'libinput' for 'Power Button'
[   181.262] (**) Power Button: always reports core events
[   181.262] (**) Option "Device" "/dev/input/event3"
[   181.262] (**) Option "_source" "server/udev"
[   181.264] (II) event3  - Power Button: is tagged by udev as: Keyboard
[   181.264] (II) event3  - Power Button: device is a keyboard
[   181.264] (II) event3  - Power Button: device removed
[   181.285] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[   181.285] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   181.285] (**) Option "xkb_model" "pc105"
[   181.285] (**) Option "xkb_layout" "us"
[   181.286] (II) event3  - Power Button: is tagged by udev as: Keyboard
[   181.286] (II) event3  - Power Button: device is a keyboard
[   181.287] (II) config/udev: Adding input device Video Bus (/dev/input/event18)
[   181.287] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   181.287] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   181.287] (**) Video Bus: Applying InputClass "system-keyboard"
[   181.287] (II) Using input driver 'libinput' for 'Video Bus'
[   181.287] (**) Video Bus: always reports core events
[   181.287] (**) Option "Device" "/dev/input/event18"
[   181.287] (**) Option "_source" "server/udev"
[   181.287] (II) event18 - Video Bus: is tagged by udev as: Keyboard
[   181.287] (II) event18 - Video Bus: device is a keyboard
[   181.287] (II) event18 - Video Bus: device removed
[   181.305] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input19/event18"
[   181.305] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[   181.305] (**) Option "xkb_model" "pc105"
[   181.305] (**) Option "xkb_layout" "us"
[   181.306] (II) event18 - Video Bus: is tagged by udev as: Keyboard
[   181.306] (II) event18 - Video Bus: device is a keyboard
[   181.307] (II) config/udev: Adding input device Video Bus (/dev/input/event17)
[   181.307] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   181.307] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   181.307] (**) Video Bus: Applying InputClass "system-keyboard"
[   181.307] (II) Using input driver 'libinput' for 'Video Bus'
[   181.307] (**) Video Bus: always reports core events
[   181.307] (**) Option "Device" "/dev/input/event17"
[   181.307] (**) Option "_source" "server/udev"
[   181.308] (II) event17 - Video Bus: is tagged by udev as: Keyboard
[   181.308] (II) event17 - Video Bus: device is a keyboard
[   181.308] (II) event17 - Video Bus: device removed
[   181.325] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input18/event17"
[   181.325] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[   181.325] (**) Option "xkb_model" "pc105"
[   181.325] (**) Option "xkb_layout" "us"
[   181.327] (II) event17 - Video Bus: is tagged by udev as: Keyboard
[   181.327] (II) event17 - Video Bus: device is a keyboard
[   181.328] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[   181.328] (II) No input driver specified, ignoring this device.
[   181.328] (II) This device may have been added with another device file.
[   181.329] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[   181.329] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   181.329] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   181.329] (**) Power Button: Applying InputClass "system-keyboard"
[   181.329] (II) Using input driver 'libinput' for 'Power Button'
[   181.329] (**) Power Button: always reports core events
[   181.329] (**) Option "Device" "/dev/input/event2"
[   181.329] (**) Option "_source" "server/udev"
[   181.330] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   181.331] (II) event2  - Power Button: device is a keyboard
[   181.331] (II) event2  - Power Button: device removed
[   181.348] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[   181.349] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[   181.349] (**) Option "xkb_model" "pc105"
[   181.349] (**) Option "xkb_layout" "us"
[   181.351] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   181.351] (II) event2  - Power Button: device is a keyboard
[   181.353] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[   181.353] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[   181.353] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[   181.353] (**) Sleep Button: Applying InputClass "system-keyboard"
[   181.353] (II) Using input driver 'libinput' for 'Sleep Button'
[   181.353] (**) Sleep Button: always reports core events
[   181.353] (**) Option "Device" "/dev/input/event1"
[   181.353] (**) Option "_source" "server/udev"
[   181.355] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[   181.355] (II) event1  - Sleep Button: device is a keyboard
[   181.355] (II) event1  - Sleep Button: device removed
[   181.372] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[   181.372] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[   181.372] (**) Option "xkb_model" "pc105"
[   181.372] (**) Option "xkb_layout" "us"
[   181.374] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[   181.374] (II) event1  - Sleep Button: device is a keyboard
[   181.376] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event8)
[   181.376] (II) No input driver specified, ignoring this device.
[   181.376] (II) This device may have been added with another device file.
[   181.377] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event9)
[   181.377] (II) No input driver specified, ignoring this device.
[   181.377] (II) This device may have been added with another device file.
[   181.378] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event10)
[   181.378] (II) No input driver specified, ignoring this device.
[   181.378] (II) This device may have been added with another device file.
[   181.379] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event7)
[   181.379] (II) No input driver specified, ignoring this device.
[   181.379] (II) This device may have been added with another device file.
[   181.382] (II) config/udev: Adding input device LXD Gaming Mouse (/dev/input/event12)
[   181.382] (**) LXD Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[   181.382] (**) LXD Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[   181.382] (**) LXD Gaming Mouse: Applying InputClass "system-keyboard"
[   181.382] (II) Using input driver 'libinput' for 'LXD Gaming Mouse'
[   181.382] (**) LXD Gaming Mouse: always reports core events
[   181.382] (**) Option "Device" "/dev/input/event12"
[   181.382] (**) Option "_source" "server/udev"
[   181.385] (II) event12 - LXD Gaming Mouse: is tagged by udev as: Keyboard
[   181.385] (II) event12 - LXD Gaming Mouse: device is a keyboard
[   181.386] (II) event12 - LXD Gaming Mouse: device removed
[   181.405] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:1D57:AD03.0001/input/input13/event12"
[   181.405] (II) XINPUT: Adding extended input device "LXD Gaming Mouse" (type: KEYBOARD, id 11)
[   181.405] (**) Option "xkb_model" "pc105"
[   181.405] (**) Option "xkb_layout" "us"
[   181.409] (II) event12 - LXD Gaming Mouse: is tagged by udev as: Keyboard
[   181.409] (II) event12 - LXD Gaming Mouse: device is a keyboard
[   181.412] (II) config/udev: Adding input device LXD Gaming Mouse (/dev/input/event14)
[   181.412] (**) LXD Gaming Mouse: Applying InputClass "evdev pointer catchall"
[   181.412] (**) LXD Gaming Mouse: Applying InputClass "libinput pointer catchall"
[   181.412] (II) Using input driver 'libinput' for 'LXD Gaming Mouse'
[   181.412] (**) LXD Gaming Mouse: always reports core events
[   181.412] (**) Option "Device" "/dev/input/event14"
[   181.412] (**) Option "_source" "server/udev"
[   181.415] (II) event14 - LXD Gaming Mouse: is tagged by udev as: Mouse
[   181.415] (II) event14 - LXD Gaming Mouse: device is a pointer
[   181.416] (II) event14 - LXD Gaming Mouse: device removed
[   181.458] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:1D57:AD03.0002/input/input15/event14"
[   181.458] (II) XINPUT: Adding extended input device "LXD Gaming Mouse" (type: MOUSE, id 12)
[   181.459] (**) Option "AccelerationScheme" "none"
[   181.459] (**) LXD Gaming Mouse: (accel) selected scheme none/0
[   181.459] (**) LXD Gaming Mouse: (accel) acceleration factor: 2.000
[   181.459] (**) LXD Gaming Mouse: (accel) acceleration threshold: 4
[   181.462] (II) event14 - LXD Gaming Mouse: is tagged by udev as: Mouse
[   181.463] (II) event14 - LXD Gaming Mouse: device is a pointer
[   181.465] (II) config/udev: Adding input device LXD Gaming Mouse (/dev/input/mouse1)
[   181.465] (II) No input driver specified, ignoring this device.
[   181.465] (II) This device may have been added with another device file.
[   181.467] (II) config/udev: Adding input device LXD Gaming Mouse Consumer Control (/dev/input/event15)
[   181.467] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[   181.467] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[   181.467] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[   181.467] (II) Using input driver 'libinput' for 'LXD Gaming Mouse Consumer Control'
[   181.467] (**) LXD Gaming Mouse Consumer Control: always reports core events
[   181.467] (**) Option "Device" "/dev/input/event15"
[   181.467] (**) Option "_source" "server/udev"
[   181.470] (II) event15 - LXD Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[   181.471] (II) event15 - LXD Gaming Mouse Consumer Control: device is a keyboard
[   181.471] (II) event15 - LXD Gaming Mouse Consumer Control: device removed
[   181.482] (II) libinput: LXD Gaming Mouse Consumer Control: needs a virtual subdevice
[   181.482] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:1D57:AD03.0002/input/input16/event15"
[   181.482] (II) XINPUT: Adding extended input device "LXD Gaming Mouse Consumer Control" (type: MOUSE, id 13)
[   181.482] (**) Option "AccelerationScheme" "none"
[   181.482] (**) LXD Gaming Mouse Consumer Control: (accel) selected scheme none/0
[   181.482] (**) LXD Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
[   181.482] (**) LXD Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
[   181.486] (II) event15 - LXD Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[   181.486] (II) event15 - LXD Gaming Mouse Consumer Control: device is a keyboard
[   181.488] (II) config/udev: Adding input device LXD Gaming Mouse System Control (/dev/input/event16)
[   181.489] (**) LXD Gaming Mouse System Control: Applying InputClass "evdev keyboard catchall"
[   181.489] (**) LXD Gaming Mouse System Control: Applying InputClass "libinput keyboard catchall"
[   181.489] (**) LXD Gaming Mouse System Control: Applying InputClass "system-keyboard"
[   181.489] (II) Using input driver 'libinput' for 'LXD Gaming Mouse System Control'
[   181.489] (**) LXD Gaming Mouse System Control: always reports core events
[   181.489] (**) Option "Device" "/dev/input/event16"
[   181.489] (**) Option "_source" "server/udev"
[   181.492] (II) event16 - LXD Gaming Mouse System Control: is tagged by udev as: Keyboard
[   181.492] (II) event16 - LXD Gaming Mouse System Control: device is a keyboard
[   181.493] (II) event16 - LXD Gaming Mouse System Control: device removed
[   181.515] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:1D57:AD03.0002/input/input17/event16"
[   181.515] (II) XINPUT: Adding extended input device "LXD Gaming Mouse System Control" (type: KEYBOARD, id 14)
[   181.515] (**) Option "xkb_model" "pc105"
[   181.515] (**) Option "xkb_layout" "us"
[   181.519] (II) event16 - LXD Gaming Mouse System Control: is tagged by udev as: Keyboard
[   181.519] (II) event16 - LXD Gaming Mouse System Control: device is a keyboard
[   181.522] (II) config/udev: Adding input device HD WebCam: HD WebCam (/dev/input/event13)
[   181.522] (**) HD WebCam: HD WebCam: Applying InputClass "evdev keyboard catchall"
[   181.522] (**) HD WebCam: HD WebCam: Applying InputClass "libinput keyboard catchall"
[   181.522] (**) HD WebCam: HD WebCam: Applying InputClass "system-keyboard"
[   181.522] (II) Using input driver 'libinput' for 'HD WebCam: HD WebCam'
[   181.522] (**) HD WebCam: HD WebCam: always reports core events
[   181.522] (**) Option "Device" "/dev/input/event13"
[   181.522] (**) Option "_source" "server/udev"
[   181.525] (II) event13 - HD WebCam: HD WebCam: is tagged by udev as: Keyboard
[   181.525] (II) event13 - HD WebCam: HD WebCam: device is a keyboard
[   181.525] (II) event13 - HD WebCam: HD WebCam: device removed
[   181.578] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/input/input14/event13"
[   181.579] (II) XINPUT: Adding extended input device "HD WebCam: HD WebCam" (type: KEYBOARD, id 15)
[   181.579] (**) Option "xkb_model" "pc105"
[   181.579] (**) Option "xkb_layout" "us"
[   181.582] (II) event13 - HD WebCam: HD WebCam: is tagged by udev as: Keyboard
[   181.582] (II) event13 - HD WebCam: HD WebCam: device is a keyboard
[   181.584] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event19)
[   181.584] (II) No input driver specified, ignoring this device.
[   181.584] (II) This device may have been added with another device file.
[   181.585] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[   181.585] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   181.585] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[   181.585] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[   181.585] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[   181.585] (**) AT Translated Set 2 keyboard: always reports core events
[   181.586] (**) Option "Device" "/dev/input/event4"
[   181.586] (**) Option "_source" "server/udev"
[   181.588] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   181.588] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[   181.590] (II) event4  - AT Translated Set 2 keyboard: device removed
[   181.602] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[   181.602] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[   181.602] (**) Option "xkb_model" "pc105"
[   181.602] (**) Option "xkb_layout" "us"
[   181.605] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   181.605] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[   181.608] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event11)
[   181.608] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[   181.608] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[   181.608] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[   181.608] (**) SynPS/2 Synaptics TouchPad: always reports core events
[   181.608] (**) Option "Device" "/dev/input/event11"
[   181.608] (**) Option "_source" "server/udev"
[   181.610] (II) event11 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[   181.612] (II) event11 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[   181.615] (II) event11 - SynPS/2 Synaptics TouchPad: device is a touchpad
[   181.615] (II) event11 - SynPS/2 Synaptics TouchPad: device removed
[   181.656] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event11"
[   181.656] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 17)
[   181.659] (**) Option "AccelerationScheme" "none"
[   181.659] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[   181.659] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[   181.659] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[   181.662] (II) event11 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[   181.663] (II) event11 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[   181.665] (II) event11 - SynPS/2 Synaptics TouchPad: device is a touchpad
[   181.667] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[   181.667] (II) No input driver specified, ignoring this device.
[   181.667] (II) This device may have been added with another device file.
[   181.668] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[   181.668] (II) No input driver specified, ignoring this device.
[   181.669] (II) This device may have been added with another device file.
[   181.675] (II) config/udev: Adding input device Acer WMI hotkeys (/dev/input/event6)
[   181.675] (**) Acer WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[   181.675] (**) Acer WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[   181.675] (**) Acer WMI hotkeys: Applying InputClass "system-keyboard"
[   181.675] (II) Using input driver 'libinput' for 'Acer WMI hotkeys'
[   181.675] (**) Acer WMI hotkeys: always reports core events
[   181.675] (**) Option "Device" "/dev/input/event6"
[   181.675] (**) Option "_source" "server/udev"
[   181.677] (II) event6  - Acer WMI hotkeys: is tagged by udev as: Keyboard
[   181.677] (II) event6  - Acer WMI hotkeys: device is a keyboard
[   181.677] (II) event6  - Acer WMI hotkeys: device removed
[   181.699] (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event6"
[   181.699] (II) XINPUT: Adding extended input device "Acer WMI hotkeys" (type: KEYBOARD, id 18)
[   181.699] (**) Option "xkb_model" "pc105"
[   181.699] (**) Option "xkb_layout" "us"
[   181.701] (II) event6  - Acer WMI hotkeys: is tagged by udev as: Keyboard
[   181.701] (II) event6  - Acer WMI hotkeys: device is a keyboard
[   181.731] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[   181.731] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[   181.731] (**) LXD Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[   181.731] (II) Using input driver 'libinput' for 'LXD Gaming Mouse Consumer Control'
[   181.731] (**) LXD Gaming Mouse Consumer Control: always reports core events
[   181.731] (**) Option "Device" "/dev/input/event15"
[   181.731] (**) Option "_source" "_driver/libinput"
[   181.731] (II) libinput: LXD Gaming Mouse Consumer Control: is a virtual subdevice
[   181.731] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:1D57:AD03.0002/input/input16/event15"
[   181.731] (II) XINPUT: Adding extended input device "LXD Gaming Mouse Consumer Control" (type: KEYBOARD, id 19)
[   181.731] (**) Option "xkb_model" "pc105"
[   181.732] (**) Option "xkb_layout" "us"
[   183.198] (II) intel(0): EDID vendor "BOE", prod id 1734
[   183.198] (II) intel(0): Printing DDC gathered Modelines:
[   183.198] (II) intel(0): Modeline "1920x1080"x0.0  152.60  1920 1968 2000 2230  1080 1083 1089 1140 +hsync -vsync (68.4 kHz eP)
[   211.167] (II) event3  - Power Button: device removed
[   211.192] (II) event18 - Video Bus: device removed
[   211.212] (II) event17 - Video Bus: device removed
[   211.245] (II) event2  - Power Button: device removed
[   211.285] (II) event1  - Sleep Button: device removed
[   211.325] (II) event12 - LXD Gaming Mouse: device removed
[   211.352] (II) event14 - LXD Gaming Mouse: device removed
[   211.392] (II) event16 - LXD Gaming Mouse System Control: device removed
[   211.432] (II) event13 - HD WebCam: HD WebCam: device removed
[   211.485] (II) event4  - AT Translated Set 2 keyboard: device removed
[   211.512] (II) event11 - SynPS/2 Synaptics TouchPad: device removed
[   211.575] (II) event6  - Acer WMI hotkeys: device removed
[   211.605] (II) event15 - LXD Gaming Mouse Consumer Control: device removed
[   211.632] (II) AIGLX: Suspending AIGLX clients for VT switch
[   231.970] (II) UnloadModule: "libinput"
[   231.972] (II) Server terminated successfully (0). Closing log file.
Here is journalctl covering the start of lightdm, login attempt and subsequent lockup. (again intel mode of optimus switch)
Jan 04 21:00:47 abo dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.37' (uid=0 pid=899 comm="/usr/lib/polkit-1/polkit-agent-helper-1 darren ")
Jan 04 21:00:47 abo dbus-daemon[397]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 04 21:00:47 abo polkit-agent-helper-1[899]: pam_systemd_home(polkit-1:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 04 21:00:50 abo polkitd[400]: Operator of unix-process:893:17863 successfully authenticated as unix-user:darren to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.36 [systemctl start lightdm] (owned by unix-user:darren)
Jan 04 21:00:50 abo systemd[1]: Starting Light Display Manager...
Jan 04 21:00:50 abo systemd[1]: Started Light Display Manager.
Jan 04 21:00:50 abo polkitd[400]: Unregistered Authentication Agent for unix-process:893:17863 (system bus name :1.35, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Jan 04 21:00:50 abo acpid[393]: client connected from 911[0:0]
Jan 04 21:00:50 abo acpid[393]: 1 client rule loaded
Jan 04 21:00:50 abo lightdm[923]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=620) by (uid=0)
Jan 04 21:00:50 abo systemd[1]: Created slice User Slice of UID 620.
Jan 04 21:00:50 abo systemd[1]: Starting User Runtime Directory /run/user/620...
Jan 04 21:00:50 abo systemd-logind[402]: New session c2 of user lightdm.
Jan 04 21:00:50 abo systemd[1]: Finished User Runtime Directory /run/user/620.
Jan 04 21:00:50 abo systemd[1]: Starting User Manager for UID 620...
Jan 04 21:00:50 abo dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.44' (uid=0 pid=928 comm="(systemd) ")
Jan 04 21:00:50 abo dbus-daemon[397]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 04 21:00:50 abo systemd[928]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 04 21:00:50 abo systemd[928]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Jan 04 21:00:50 abo systemd[928]: pam_unix(systemd-user:session): session opened for user lightdm(uid=620) by (uid=0)
Jan 04 21:00:50 abo systemd[928]: pam_env(systemd-user:session): deprecated reading of user environment enabled
Jan 04 21:00:50 abo systemd[928]: Queued start job for default target Main User Target.
Jan 04 21:00:50 abo systemd[928]: Created slice User Application Slice.
Jan 04 21:00:50 abo systemd[928]: Reached target Paths.
Jan 04 21:00:50 abo systemd[928]: Reached target Timers.
Jan 04 21:00:50 abo systemd[928]: Starting D-Bus User Message Bus Socket...
Jan 04 21:00:50 abo systemd[928]: Listening on GnuPG network certificate management daemon.
Jan 04 21:00:50 abo systemd[928]: Listening on GCR ssh-agent wrapper.
Jan 04 21:00:50 abo systemd[928]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 04 21:00:50 abo systemd[928]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jan 04 21:00:50 abo systemd[928]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jan 04 21:00:50 abo systemd[928]: Listening on GnuPG cryptographic agent and passphrase cache.
Jan 04 21:00:50 abo systemd[928]: Listening on p11-kit server.
Jan 04 21:00:50 abo systemd[928]: Listening on Sound System.
Jan 04 21:00:50 abo systemd[928]: Listening on D-Bus User Message Bus Socket.
Jan 04 21:00:50 abo systemd[928]: Reached target Sockets.
Jan 04 21:00:50 abo systemd[928]: Reached target Basic System.
Jan 04 21:00:50 abo systemd[1]: Started User Manager for UID 620.
Jan 04 21:00:50 abo systemd[928]: Starting Update XDG user dir configuration...
Jan 04 21:00:50 abo systemd[1]: Started Session c2 of User lightdm.
Jan 04 21:00:50 abo systemd[928]: Finished Update XDG user dir configuration.
Jan 04 21:00:50 abo systemd[928]: Reached target Main User Target.
Jan 04 21:00:50 abo systemd[928]: Startup finished in 88ms.
Jan 04 21:00:50 abo systemd[928]: Started D-Bus User Message Bus.
Jan 04 21:00:50 abo dbus-daemon[946]: [session uid=620 pid=946] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=620 pid=940 comm="/usr/bin/lightdm-gtk-greeter ")
Jan 04 21:00:50 abo systemd[928]: Starting Accessibility services bus...
Jan 04 21:00:50 abo dbus-daemon[946]: [session uid=620 pid=946] Successfully activated service 'org.a11y.Bus'
Jan 04 21:00:50 abo systemd[928]: Started Accessibility services bus.
Jan 04 21:00:50 abo dbus-daemon[946]: [session uid=620 pid=946] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=620 pid=940 comm="/usr/bin/lightdm-gtk-greeter ")
Jan 04 21:00:50 abo systemd[928]: Starting Virtual filesystem service...
Jan 04 21:00:50 abo dbus-daemon[946]: [session uid=620 pid=946] Successfully activated service 'org.gtk.vfs.Daemon'
Jan 04 21:00:50 abo systemd[928]: Started Virtual filesystem service.
Jan 04 21:00:51 abo polkitd[400]: <no filename>:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
Jan 04 21:00:51 abo polkitd[400]: <no filename>:4: subject=[Subject pid=940 user='lightdm' groups=lightdm seat='seat0' session='c2' local=true active=true]
Jan 04 21:00:51 abo at-spi-bus-launcher[953]: dbus-daemon[953]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=620 pid=940 comm="/usr/bin/lightdm-gtk-greeter ")
Jan 04 21:00:51 abo at-spi-bus-launcher[979]: dbus-daemon[979]: writing oom_score_adj error: Permission denied
Jan 04 21:00:51 abo at-spi-bus-launcher[953]: dbus-daemon[953]: Successfully activated service 'org.a11y.atspi.Registry'
Jan 04 21:00:51 abo at-spi-bus-launcher[979]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 04 21:00:51 abo dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.47' (uid=0 pid=977 comm="lightdm --session-child 12 19 ")
Jan 04 21:00:51 abo dbus-daemon[397]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 04 21:00:51 abo lightdm[977]: pam_systemd_home(lightdm:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 04 21:01:01 abo CROND[983]: (root) CMD (run-parts /etc/cron.hourly)
Jan 04 21:01:01 abo anacron[992]: Anacron started on 2022-01-04
Jan 04 21:01:01 abo CROND[982]: (root) CMDEND (run-parts /etc/cron.hourly)
Jan 04 21:01:01 abo anacron[992]: Will run job `cron.daily' in 12 min.
Jan 04 21:01:01 abo anacron[992]: Jobs will be executed sequentially
Jan 04 21:01:11 abo lightdm[977]: gkr-pam: unable to locate daemon control file
Jan 04 21:01:11 abo lightdm[977]: gkr-pam: stashed password to try later in open session
Jan 04 21:01:11 abo systemd[1]: Stopping Session c2 of User lightdm...
Jan 04 21:01:11 abo lightdm[923]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Jan 04 21:01:11 abo systemd[1]: session-c2.scope: Deactivated successfully.
Jan 04 21:01:11 abo systemd[1]: Stopped Session c2 of User lightdm.
Jan 04 21:01:11 abo systemd[1]: session-c2.scope: Consumed 1.067s CPU time.
Jan 04 21:01:11 abo systemd-logind[402]: Removed session c2.
Jan 04 21:01:11 abo lightdm[977]: pam_unix(lightdm:session): session opened for user darren(uid=1000) by (uid=0)
Jan 04 21:01:11 abo systemd-logind[402]: New session 6 of user darren.
Jan 04 21:01:11 abo systemd[1]: Started Session 6 of User darren.
Jan 04 21:01:11 abo lightdm[977]: pam_env(lightdm:session): deprecated reading of user environment enabled
Jan 04 21:01:11 abo lightdm[977]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
Jan 04 21:01:11 abo lightdm[977]: Error opening audit socket: Protocol not supported
Jan 04 21:01:21 abo systemd[1]: Stopping User Manager for UID 620...
Jan 04 21:01:21 abo systemd[928]: Activating special unit Exit the Session...
Jan 04 21:01:21 abo systemd[928]: Stopped target Main User Target.
Jan 04 21:01:21 abo systemd[928]: Stopping Accessibility services bus...
Jan 04 21:01:21 abo gvfsd[955]: A connection to the bus can't be made
Jan 04 21:01:21 abo systemd[928]: Stopping D-Bus User Message Bus...
Jan 04 21:01:21 abo systemd[928]: Stopping Virtual filesystem service...
Jan 04 21:01:21 abo systemd[1]: run-user-620-gvfs.mount: Deactivated successfully.
Jan 04 21:01:21 abo systemd[928]: Stopped Virtual filesystem service.
Jan 04 21:01:21 abo systemd[928]: Stopped Accessibility services bus.
Jan 04 21:01:21 abo systemd[928]: Stopped D-Bus User Message Bus.
Jan 04 21:01:21 abo systemd[928]: Stopped target Basic System.
Jan 04 21:01:21 abo systemd[928]: Stopped target Paths.
Jan 04 21:01:21 abo systemd[928]: Stopped target Sockets.
Jan 04 21:01:21 abo systemd[928]: Stopped target Timers.
Jan 04 21:01:21 abo systemd[928]: Closed D-Bus User Message Bus Socket.
Jan 04 21:01:21 abo systemd[928]: Closed GnuPG network certificate management daemon.
Jan 04 21:01:21 abo systemd[928]: Closed GCR ssh-agent wrapper.
Jan 04 21:01:21 abo systemd[928]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 04 21:01:21 abo systemd[928]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 04 21:01:21 abo systemd[928]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 04 21:01:21 abo systemd[928]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 04 21:01:21 abo systemd[928]: Closed p11-kit server.
Jan 04 21:01:21 abo systemd[928]: Closed Sound System.
Jan 04 21:01:21 abo systemd[928]: Removed slice User Application Slice.
Jan 04 21:01:21 abo systemd[928]: Reached target Shutdown.
Jan 04 21:01:21 abo systemd[928]: Finished Exit the Session.
Jan 04 21:01:21 abo systemd[928]: Reached target Exit the Session.
Jan 04 21:01:21 abo systemd[932]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Jan 04 21:01:21 abo systemd[1]: user@620.service: Deactivated successfully.
Jan 04 21:01:21 abo systemd[1]: Stopped User Manager for UID 620.
Jan 04 21:01:21 abo systemd[1]: Stopping User Runtime Directory /run/user/620...
Jan 04 21:01:21 abo systemd[1]: run-user-620.mount: Deactivated successfully.
Jan 04 21:01:21 abo systemd[1]: user-runtime-dir@620.service: Deactivated successfully.
Jan 04 21:01:21 abo systemd[1]: Stopped User Runtime Directory /run/user/620.
Jan 04 21:01:21 abo systemd[1]: Removed slice User Slice of UID 620.
Jan 04 21:01:21 abo systemd[1]: user-620.slice: Consumed 1.260s CPU time.
Jan 04 21:01:22 abo acpid[393]: client 911[0:0] has disconnected
Jan 04 21:01:38 abo polkitd[400]: Registered Authentication Agent for unix-process:1018:22944 (system bus name :1.51 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Jan 04 21:01:38 abo dbus-daemon[397]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.53' (uid=0 pid=1024 comm="/usr/lib/polkit-1/polkit-agent-helper-1 darren ")
Jan 04 21:01:38 abo dbus-daemon[397]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 04 21:01:38 abo polkit-agent-helper-1[1024]: pam_systemd_home(polkit-1:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 04 21:01:40 abo polkitd[400]: Operator of unix-process:1018:22944 successfully authenticated as unix-user:darren to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.52 [systemctl stop lightdm] (owned by unix-user:darren)
Jan 04 21:01:40 abo systemd[1]: Stopping Light Display Manager...
Jan 04 21:01:40 abo systemd[1]: Stopping Session 6 of User darren...
Jan 04 21:01:40 abo lightdm[977]: Error opening audit socket: Protocol not supported
Jan 04 21:01:40 abo lightdm[977]: pam_unix(lightdm:session): session closed for user darren
Jan 04 21:01:40 abo systemd[1]: session-6.scope: Deactivated successfully.
Jan 04 21:01:40 abo systemd[1]: Stopped Session 6 of User darren.
Jan 04 21:01:40 abo systemd[1]: lightdm.service: Deactivated successfully.
Jan 04 21:01:40 abo systemd[1]: Stopped Light Display Manager.
Jan 04 21:01:40 abo systemd-logind[402]: Removed session 6.
Jan 04 21:01:40 abo polkitd[400]: Unregistered Authentication Agent for unix-process:1018:22944 (system bus name :1.51, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Jan 04 21:01:41 abo acpid[393]: client 911[0:0] has disconnected
I had noted the homed error, rolling back systemd didn’t resolve it, might try again to reassure myself.
thanks again.
It seems lightdm has not crashed, desktop loads after 2 minutes. I will flag this thread as it maybe better served in different location with modified title-delayed login
Once loaded it works fine; suspends resumes, multimedia keys(brightness,backlight etc), this is not the case if i stop lightdm and use startx/startxfce4 from tty.
If i logout, stop and start lightdm from tty later in my session it still hangs.
I’ve installed rng-tools, (i had haveged for a while, didn’t know it was outdated until troubleshooting this issue):
in tty before login attempt following boot;
cat /proc/sys/kernel/random/entropy_avail
4032
journalctl (-r reverse log)
Jan 21 22:54:58 abo systemd[1]: Stopped Getty on tty2.
Jan 21 22:54:58 abo systemd[1]: getty@tty2.service: Scheduled restart job, restart counter is at 2.
Jan 21 22:54:58 abo systemd-logind[388]: Session 6 logged out. Waiting for processes to exit.
Jan 21 22:54:58 abo systemd[1]: session-6.scope: Deactivated successfully.
Jan 21 22:54:57 abo systemd[1]: getty@tty2.service: Deactivated successfully.
Jan 21 22:54:57 abo login[1099]: pam_unix(login:session): session closed for user darren
Jan 21 22:54:53 abo sudo[2545]: pam_unix(sudo:session): session closed for user root
Jan 21 22:54:41 abo NetworkManager[456]: <info>  [1642805681.2168] agent-manager: agent[1e96d60d3c102b3a,:1.123/org.freedesktop.nm-applet/1000]: agent registered
Jan 21 22:54:40 abo polkitd[387]: Registered Authentication Agent for unix-session:8 (system bus name :1.121 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Jan 21 22:54:21 abo pulseaudio[2634]: GetManagedObjects() failed: org.freedesktop.systemd1.NoSuchUnit: Unit dbus-org.bluez.service not found.
Jan 21 22:54:21 abo systemd[794]: Started Sound Service.
Jan 21 22:54:21 abo pulseaudio[2634]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jan 21 22:54:21 abo dbus-daemon[385]: [system] Activation via systemd failed for unit 'dbus-org.bluez.service': Unit dbus-org.bluez.service not found.
Jan 21 22:54:21 abo dbus-daemon[385]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.118' (uid=1000 pid=2634 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
Jan 21 22:54:21 abo rtkit-daemon[948]: Supervising 3 threads of 1 processes of 1 users.
Jan 21 22:54:21 abo rtkit-daemon[948]: Successfully made thread 2640 of process 2634 owned by '1000' RT at priority 5.
Jan 21 22:54:21 abo rtkit-daemon[948]: Supervising 2 threads of 1 processes of 1 users.
Jan 21 22:54:21 abo rtkit-daemon[948]: Successfully made thread 2639 of process 2634 owned by '1000' RT at priority 5.
Jan 21 22:54:21 abo rtkit-daemon[948]: Supervising 1 threads of 1 processes of 1 users.
Jan 21 22:54:20 abo rtkit-daemon[948]: Supervising 1 threads of 1 processes of 1 users.
Jan 21 22:54:20 abo rtkit-daemon[948]: Successfully made thread 2634 of process 2634 owned by '1000' high priority at nice level -11.
Jan 21 22:54:20 abo systemd[794]: Starting Sound Service...
Jan 21 22:54:04 abo gpg-agent[2606]: listening on: std=3 extra=5 browser=6 ssh=4
Jan 21 22:54:04 abo gpg-agent[2606]: using fd 6 for browser socket (/run/user/1000/gnupg/S.gpg-agent.browser)
Jan 21 22:54:04 abo gpg-agent[2606]: using fd 5 for extra socket (/run/user/1000/gnupg/S.gpg-agent.extra)
Jan 21 22:54:04 abo gpg-agent[2606]: using fd 4 for ssh socket (/run/user/1000/gnupg/S.gpg-agent.ssh)
Jan 21 22:54:04 abo gpg-agent[2606]: using fd 3 for std socket (/run/user/1000/gnupg/S.gpg-agent)
Jan 21 22:54:04 abo gpg-agent[2606]: gpg-agent (GnuPG) 2.2.32 starting in supervised mode.
Jan 21 22:54:04 abo systemd[794]: Started GnuPG cryptographic agent and passphrase cache.
Jan 21 22:54:04 abo gpg-agent[2603]: listening on: std=3 extra=5 browser=6 ssh=4
Jan 21 22:54:04 abo gpg-agent[2603]: using fd 6 for browser socket (/run/user/1000/gnupg/S.gpg-agent.browser)
Jan 21 22:54:04 abo gpg-agent[2603]: using fd 5 for extra socket (/run/user/1000/gnupg/S.gpg-agent.extra)
Jan 21 22:54:04 abo gpg-agent[2603]: using fd 4 for ssh socket (/run/user/1000/gnupg/S.gpg-agent.ssh)
Jan 21 22:54:04 abo gpg-agent[2603]: using fd 3 for std socket (/run/user/1000/gnupg/S.gpg-agent)
Jan 21 22:54:04 abo gpg-agent[2603]: gpg-agent (GnuPG) 2.2.32 starting in supervised mode.
Jan 21 22:54:04 abo at-spi-bus-launcher[2594]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 21 22:54:04 abo at-spi-bus-launcher[899]: dbus-daemon[899]: Successfully activated service 'org.a11y.atspi.Registry'
Jan 21 22:54:04 abo at-spi-bus-launcher[2594]: dbus-daemon[2594]: writing oom_score_adj error: Permission denied
Jan 21 22:54:04 abo at-spi-bus-launcher[899]: dbus-daemon[899]: Activating service name='org.a11y.atspi.Registry' requested by ':1.33' (uid=1000 pid=2566 comm="xfce4-session ")
Jan 21 22:52:04 abo systemd[1]: user-620.slice: Consumed 1.139s CPU time.
Jan 21 22:52:04 abo systemd[1]: Removed slice User Slice of UID 620.
Jan 21 22:52:04 abo systemd[1]: Stopped User Runtime Directory /run/user/620.
Jan 21 22:52:04 abo systemd[1]: user-runtime-dir@620.service: Deactivated successfully.
Jan 21 22:52:04 abo systemd[1]: run-user-620.mount: Deactivated successfully.
Jan 21 22:52:04 abo systemd[1]: Stopping User Runtime Directory /run/user/620...
Jan 21 22:52:04 abo systemd[1]: Stopped User Manager for UID 620.
Jan 21 22:52:04 abo systemd[1]: user@620.service: Deactivated successfully.
Jan 21 22:52:04 abo systemd[2494]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Jan 21 22:52:04 abo systemd[2490]: Reached target Exit the Session.
Jan 21 22:52:04 abo systemd[2490]: Finished Exit the Session.
Jan 21 22:52:04 abo systemd[2490]: Reached target Shutdown.
Jan 21 22:52:04 abo systemd[2490]: Removed slice User Application Slice.
Jan 21 22:52:04 abo systemd[2490]: Closed Sound System.
Jan 21 22:52:04 abo systemd[2490]: Closed p11-kit server.
Jan 21 22:52:04 abo systemd[2490]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 21 22:52:04 abo systemd[2490]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 21 22:52:04 abo systemd[2490]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 21 22:52:04 abo systemd[2490]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 21 22:52:04 abo systemd[2490]: Closed GCR ssh-agent wrapper.
Jan 21 22:52:04 abo systemd[2490]: Closed GnuPG network certificate management daemon.
Jan 21 22:52:04 abo systemd[2490]: Closed D-Bus User Message Bus Socket.
Jan 21 22:52:04 abo systemd[2490]: Stopped target Timers.
Jan 21 22:52:04 abo systemd[2490]: Stopped target Sockets.
Jan 21 22:52:04 abo systemd[2490]: Stopped target Paths.
Jan 21 22:52:04 abo systemd[2490]: Stopped target Basic System.
Jan 21 22:52:04 abo systemd[2490]: Stopped Virtual filesystem service.
Jan 21 22:52:04 abo systemd[1]: run-user-620-gvfs.mount: Deactivated successfully.
Jan 21 22:52:04 abo systemd[2490]: Stopped D-Bus User Message Bus.
Jan 21 22:52:04 abo systemd[2490]: Stopped Accessibility services bus.
Jan 21 22:52:04 abo systemd[2490]: Stopping Virtual filesystem service...
Jan 21 22:52:04 abo systemd[2490]: Stopping D-Bus User Message Bus...
Jan 21 22:52:04 abo gvfsd[2517]: A connection to the bus can't be made
Jan 21 22:52:04 abo systemd[2490]: Stopping Accessibility services bus...
Jan 21 22:52:04 abo systemd[2490]: Stopped target Main User Target.
Jan 21 22:52:04 abo systemd[2490]: Activating special unit Exit the Session...
Jan 21 22:52:04 abo systemd[1]: Stopping User Manager for UID 620...
Jan 21 22:51:54 abo lightdm[2539]: Error opening audit socket: Protocol not supported
Jan 21 22:51:54 abo lightdm[2539]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
Jan 21 22:51:54 abo lightdm[2539]: pam_env(lightdm:session): deprecated reading of user environment enabled
Jan 21 22:51:54 abo systemd[1]: Started Session 8 of User darren.
Jan 21 22:51:54 abo systemd-logind[388]: New session 8 of user darren.
Jan 21 22:51:54 abo lightdm[2539]: pam_unix(lightdm:session): session opened for user darren(uid=1000) by (uid=0)
Jan 21 22:51:54 abo systemd-logind[388]: Removed session c3.
Jan 21 22:51:54 abo systemd[1]: Stopped Session c3 of User lightdm.
Jan 21 22:51:54 abo systemd[1]: session-c3.scope: Deactivated successfully.
Jan 21 22:51:53 abo lightdm[2485]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Jan 21 22:51:53 abo systemd[1]: Stopping Session c3 of User lightdm...
Jan 21 22:51:53 abo lightdm[2539]: gkr-pam: stashed password to try later in open session
Jan 21 22:51:53 abo lightdm[2539]: gkr-pam: unable to locate daemon control file
Jan 21 22:51:39 abo sudo[2545]: pam_unix(sudo:session): session opened for user root(uid=0) by darren(uid=1000)
Jan 21 22:51:39 abo sudo[2545]:   darren : TTY=tty2 ; PWD=/home/darren ; USER=root ; COMMAND=/usr/bin/journalctl --follow
Jan 21 22:51:38 abo sudo[2545]: pam_systemd_home(sudo:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 21 22:51:38 abo dbus-daemon[385]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 21 22:51:38 abo dbus-daemon[385]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.110' (uid=0 pid=2545 comm="sudo journalctl --follow ")
Jan 21 22:51:16 abo lightdm[2539]: pam_systemd_home(lightdm:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 21 22:51:16 abo dbus-daemon[385]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 21 22:51:16 abo at-spi-bus-launcher[2541]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 21 22:51:16 abo dbus-daemon[385]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.109' (uid=0 pid=2539 comm="lightdm --session-child 12 19 ")
Jan 21 22:51:16 abo at-spi-bus-launcher[2515]: dbus-daemon[2515]: Successfully activated service 'org.a11y.atspi.Registry'
Jan 21 22:51:16 abo at-spi-bus-launcher[2541]: dbus-daemon[2541]: writing oom_score_adj error: Permission denied
Jan 21 22:51:16 abo at-spi-bus-launcher[2515]: dbus-daemon[2515]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=620 pid=2502 comm="/usr/bin/lightdm-gtk-greeter ")
Jan 21 22:51:16 abo polkitd[387]: <no filename>:4: subject=[Subject pid=2502 user='lightdm' groups=lightdm seat='seat0' session='c3' local=true active=true]
Jan 21 22:51:16 abo polkitd[387]: <no filename>:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
Jan 21 22:51:16 abo systemd[2490]: Started Virtual filesystem service.
Jan 21 22:51:16 abo dbus-daemon[2508]: [session uid=620 pid=2508] Successfully activated service 'org.gtk.vfs.Daemon'
Jan 21 22:51:16 abo systemd[2490]: Starting Virtual filesystem service...
Jan 21 22:51:16 abo dbus-daemon[2508]: [session uid=620 pid=2508] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=620 pid=2502 comm="/usr/bin/lightdm-gtk-greeter ")
Jan 21 22:51:16 abo systemd[2490]: Started Accessibility services bus.
Jan 21 22:51:16 abo dbus-daemon[2508]: [session uid=620 pid=2508] Successfully activated service 'org.a11y.Bus'
Jan 21 22:51:16 abo systemd[2490]: Starting Accessibility services bus...
Jan 21 22:51:16 abo dbus-daemon[2508]: [session uid=620 pid=2508] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=620 pid=2502 comm="/usr/bin/lightdm-gtk-greeter ")
Jan 21 22:51:16 abo systemd[2490]: Started D-Bus User Message Bus.
Jan 21 22:51:16 abo systemd[2490]: Startup finished in 85ms.
xsessionerrors
/usr/bin/iceauth:  creating new authority file /run/user/1000/ICEauthority
gpg-agent: a gpg-agent is already running - not starting a new one
(wrapper-2.0:938): libnotify-WARNING **: 22:14:48.564: Failed to connect to proxy
** (xfce4-power-manager:1014): WARNING **: 22:15:12.398: Failed to get name owner: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name 'org.freedesktop.PowerManagement': no such name
** (xfce4-power-manager:1014): WARNING **: 22:15:12.398: Failed to get name owner: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name 'org.xfce.PowerManager': no such name
(xfce4-power-manager:1014): GLib-GObject-WARNING **: 22:15:12.514: ../glib/gobject/gsignal.c:2614: signal 'Changed' is invalid for instance '0x55b3370194f0' of type 'GDBusProxy'
(xfce4-power-manager:1014): xfce4-power-manager-WARNING **: 22:15:12.619: could not map keysym 1008ffa8 to keycode
(xfce4-power-manager:1014): xfce4-power-manager-WARNING **: 22:15:12.642: It seems the kernel brightness switch handling value was not restored properly on exit last time, xfce4-power-manager will try to restore it this time.
(xfce4-power-manager:1014): xfce4-power-manager-WARNING **: 22:15:12.642: Unable to set the kernel brightness switch parameter to 0.
(xfce4-power-manager:1014): xfce4-power-manager-WARNING **: 22:15:12.643: Failed to get keyboard max brightness level : GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Object does not exist at path “/org/freedesktop/UPower/KbdBacklight”
(xfce4-power-manager:1014): xfce4-power-manager-WARNING **: 22:15:12.659: ../panel-plugins/power-manager-plugin/power-manager-button.c:858: invalid property id 2 for "show-panel-label" of type 'GParamInt' in 'PowerManagerButton'
(xfce4-power-manager:1014): xfce4-power-manager-WARNING **: 22:15:12.659: ../panel-plugins/power-manager-plugin/power-manager-button.c:858: invalid property id 3 for "presentation-mode" of type 'GParamBoolean' in 'PowerManagerButton'
(xfce4-power-manager:1014): xfce4-power-manager-WARNING **: 22:15:12.659: ../panel-plugins/power-manager-plugin/power-manager-button.c:858: invalid property id 4 for "show-presentation-indicator" of type 'GParamBoolean' in 'PowerManagerButton'
** Message: 22:15:42.937: updates_checker.vala:71: check updates
** Message: 22:15:43.623: updates_checker.vala:101: 0 updates found
lightdm
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.30.0, UID=0 PID=2467
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf.d/lightdm.conf
[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0.00s] DEBUG: Monitoring logind for seats
[+0.00s] DEBUG: New seat added from logind: seat0
[+0.00s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.00s] DEBUG: Seat seat0 has property CanMultiSession=no
[+0.00s] DEBUG: Seat seat0: Starting
[+0.00s] DEBUG: Seat seat0: Creating greeter session
[+0.00s] DEBUG: Seat seat0: Creating display server of type x
[+0.00s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+0.00s] DEBUG: Using VT 7
[+0.00s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.00s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.00s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.00s] DEBUG: XServer 0: Launching X Server
[+0.00s] DEBUG: Launching process 2473: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.00s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.00s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.01s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.01s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+0.04s] DEBUG: Seat seat0 changes active session to 4
[+0.72s] DEBUG: Got signal 10 from process 2473
[+0.72s] DEBUG: XServer 0: Got signal from X server :0
[+0.72s] DEBUG: XServer 0: Connecting to XServer :0
[+0.72s] DEBUG: Launching process 2482: /usr/local/bin/optimus.sh
[+0.73s] DEBUG: Process 2482 exited with return value 0
[+0.73s] DEBUG: Seat seat0: Exit status of /usr/local/bin/optimus.sh: 0
[+0.73s] DEBUG: Seat seat0: Display server ready, starting session authentication
[+0.73s] DEBUG: Session pid=2485: Started with service 'lightdm-greeter', username 'lightdm'
[+0.74s] DEBUG: Session pid=2485: Authentication complete with return value 0: Success
[+0.74s] DEBUG: Seat seat0: Session authenticated, running command
[+0.74s] DEBUG: Session pid=2485: Running command /usr/bin/lightdm-gtk-greeter
[+0.74s] DEBUG: Creating shared data directory /var/lib/lightdm-data/lightdm
[+0.74s] DEBUG: Session pid=2485: Logging to /var/log/lightdm/seat0-greeter.log
[+0.86s] DEBUG: Activating VT 7
[+0.86s] DEBUG: Activating login1 session c3
[+0.86s] DEBUG: Seat seat0 changes active session to c3
[+0.86s] DEBUG: Session c3 is already active
[+0.99s] DEBUG: Greeter connected version=1.30.0 api=1 resettable=false
[+1.11s] DEBUG: Greeter start authentication for darren
[+1.11s] DEBUG: Session pid=2539: Started with service 'lightdm', username 'darren'
[+1.12s] DEBUG: Session pid=2539: Got 1 message(s) from PAM
[+1.12s] DEBUG: Prompt greeter with 1 message(s)
[+3.24s] DEBUG: Seat seat0 changes active session to 6
[+35.28s] DEBUG: Seat seat0 changes active session to c3
[+35.28s] DEBUG: Session c3 is already active
[+38.42s] DEBUG: Continue authentication
[+38.44s] DEBUG: Session pid=2539: Authentication complete with return value 0: Success
[+38.44s] DEBUG: Authenticate result for user darren: Success
[+38.44s] DEBUG: User darren authorized
[+38.44s] DEBUG: Greeter sets language en_US.utf8
[+38.48s] DEBUG: Greeter requests session xfce
[+38.48s] DEBUG: Seat seat0: Stopping greeter; display server will be re-used for user session
[+38.48s] DEBUG: Terminating login1 session c3
[+38.49s] DEBUG: Session pid=2485: Sending SIGTERM
[+38.51s] DEBUG: Greeter closed communication channel
[+38.51s] DEBUG: Session pid=2485: Exited with return value 0
[+38.51s] DEBUG: Seat seat0: Session stopped
[+38.51s] DEBUG: Seat seat0: Greeter stopped, running session
[+38.51s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session0
[+38.51s] DEBUG: Session pid=2539: Running command /etc/lightdm/Xsession startxfce4
[+38.51s] DEBUG: Creating shared data directory /var/lib/lightdm-data/darren
[+38.51s] DEBUG: Session pid=2539: Logging to .xsession-errors
[+38.54s] DEBUG: Activating VT 7
[+38.54s] DEBUG: Activating login1 session 8
[+38.54s] DEBUG: Seat seat0 changes active session to
[+38.54s] DEBUG: Seat seat0 changes active session to 8
[+38.54s] DEBUG: Session 8 is already active
[+41.56s] DEBUG: Seat seat0 changes active session to 6
[+62.50s] DEBUG: Seat seat0 changes active session to 8
[+62.50s] DEBUG: Session 8 is already active
[+64.53s] DEBUG: Seat seat0 changes active session to 6
[+205.15s] DEBUG: Seat seat0 changes active session to 8
[+205.15s] DEBUG: Session 8 is already active
[+209.03s] DEBUG: Seat seat0 changes active session to 6
[+222.53s] DEBUG: Seat seat0 changes active session to
[+225.60s] DEBUG: Seat seat0 changes active session to 8
[+225.60s] DEBUG: Session 8 is already active
Thanks again for the assist.
