LightDM and NetworkManager fail to start after update
Both my laptops are fine after the update.
But on my ancient Dell Optiplex 380, NetworkManager and LightDM suddenly failed to start. It's running kernel 5.3.
journalctl -u NetworkManager:
https://pastebin.com/jqYY3B7q
journalctl -u lightdm:
https://pastebin.com/EHKfbF7d
Do they restart from TTY?
Is Xorg not working (startx fails) as well?
Have you set lightdm config option "Wait-for-graphical-target" (or similar)?
Nope, both failed to start in a tty ever since I've completed the update. sudo pacman -Syyu ran successfully, then I rebooted.
journalctl -xe | grep NetworkManager:
https://pastebin.com/YFJDDWhT
journalctl -xe | grep lightdm
https://pastebin.com/LyHyU4WL
Nope, I did not set any lightdm config option "Wait-for-graphical-target" (or similar).
Incidentally, I just realized my old Logitech webcam failed too after the update.
journalctl -xe | grep v4l
https://pastebin.com/DBzTXhgg
Have you tried older LTS kernels such as 4.19 & 4.14.
Also please post:
inxi -Fxxxz
If you are using the GTK greeter - have you tried the slick-greeter and vice-versa?
I ran into that problem earlier last week. Solution here.
Since I can't boot and can't connect to the internet from the installed system itself, I had to manjaro-chroot -a into it, from there every time I tried to change the kernel this happens, I tried looking around but I'm not quite sure what to do:
https://hastebin.com/orenokugal.shell
Also the output of inxi -Fxxxz (from within the chroot):
https://hastebin.com/acerarikak.makefile
Sorry for the extremely late reply, I've been too busy and too tired the past 2 weeks.
Thanks, but this computer does not have anything Nvidia.
Sorry for the late reply.
