I am a Linux newbie, l
Did a full install of Manjaro GNOME 21.1.6 on a new budget laptop CHUWI Gemibook Pro with Celeron N5100 that I bought specially for this OS.
Everything is working except:
- Touchpad
- Internal Sound
At the moment I am using bluetooth mouse and speakers as workaround.
I searched around many forums, it appears as of now the touchpad and internal sound driver (everest codecs as i read) are currently not supported.
Is there anything i can do here to contribute information so a development on Manjaro can be made?
Thank you
Info: Quad Core model: Intel Celeron N5100 bits: 64 type: MCP arch: Tremont
family: 6 model-id: 9C (156) stepping: 0 microcode: 1D cache: L2: 4 MiB
bogomips: 8912
Speed: 788 MHz min/max: 800/2800 MHz Core speeds (MHz): 1: 788 2: 800 3: 775
4: 800
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est flexpriority flush_l1d fpu fsgsbase fxsr gfni ht hwp hwp_act_window
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt lahf_lm
lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr nonstop_tsc
nopl nx pae pat pbe pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx
vnmi vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
### Configuration dump generated at Thu Nov 18 21:32:44 2021
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-null-sink sink_name=auto_null sink_properties='device.description="Dummy Output"'
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:1 xauthority=/run/user/1000/.mutter-Xwaylandauth.NCZ2C1
load-module module-x11-cork-request display=:1 xauthority=/run/user/1000/.mutter-Xwaylandauth.NCZ2C1
load-module module-x11-xsmp display=:1 xauthority=/run/user/1000/.mutter-Xwaylandauth.NCZ2C1 session_manager=local/willyam-gemibookpro:@/tmp/.ICE-unix/1174,unix/willyam-gemibookpro:/tmp/.ICE-unix/1174
load-module module-cli-protocol-unix
set-sink-volume auto_null 0x78c1
set-sink-mute auto_null no
suspend-sink auto_null yes
set-source-volume auto_null.monitor 0x10000
set-source-mute auto_null.monitor no
suspend-source auto_null.monitor yes
set-card-profile alsa_card.pci-0000_00_1f.3 off
set-default-sink auto_null
set-default-source auto_null.monitor
### EOF
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
Simple mixer control 'IEC958',6
Mono: Playback [on]
The Touchpad not found:
libinput list-devices 1 ✘
Device: Power Button
Kernel: /dev/input/event3
Group: 1
Seat: seat0, default
Capabilities: keyboard
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: n/a
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Accel profiles: n/a
Rotation: n/a
Device: Video Bus
Kernel: /dev/input/event9
Group: 2
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: Lid Switch
Kernel: /dev/input/event0
Group: 3
Capabilities: switch
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Kernel: /dev/input/event1
Group: 4
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: Sleep Button
Kernel: /dev/input/event2
Group: 5
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: Logitech M325
Kernel: /dev/input/event17
Group: 6
Capabilities: pointer
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: button
Click methods: none
Accel profiles: flat *adaptive
Rotation: n/a
Device: USB 2.0 Camera: USB Camera
Kernel: /dev/input/event8
Group: 7
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: Intel HID events
Kernel: /dev/input/event5
Group: 8
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: Intel HID 5 button array
Kernel: /dev/input/event6
Group: 9
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: AT Translated Set 2 keyboard
Kernel: /dev/input/event4
Group: 10
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Touchpad issue is resolved by switching Kernel version to LTS (5.10.83-1) or 5.15.6-2.
Internal Audio issue still not resolved.
Tried the following Resolve Dummy Audio Output. No go.
