Tell nemo to open application using gtk-launch instead of xdg-open
I wrote a .desktop file with this content:
[Desktop Entry]
Version=1.0
Type=Application
Name=xls_to_csv
Comment=convert xls to csv using ssconvert
Exec=/path/to/xls_to_csv.sh %u
Icon=edit-copy
Path=
Terminal=false
StartupNotify=false
Actions=
Categories=Copy;Utility
and placed it in ~/local/share/applications.
Next I added this “application” as an “open with” alternative in nemo file manager, so I can right-click on an .xlsx-file, choose open with → xls_to_csv.desktop
This doesn’t seem to work. When I run the command in terminal I get the output
xdg-open: unexpected argument 'test.xlsx'
An alternative seems to be to use gtk-launch, at least in the terminal it works.
Now my question is how to tell nemo to ues gtk-launch for executing my xsl_to_csv.desktop file instead of xdg-open?
System is Manjaro sway edition.
Maybe try
Exec=/usr/bin/sh -c '/path/to/xls_to_csv.sh %u'
For nemo this didn’t change anything.
In terminal probably I can’t really test this, or is there another way than doing it like this?
$ xdg-open ~/.local/share/applications/xls_to_csv.desktop test.xlsx
Try 'xdg-open --help' for more information.
Why not making it into Nemo Action and add it in ~/.local/share/nemo/actions ?
You will have to change
into
[Nemo Action]
I’m sure you can find plenty of references and explanations here:
https://askubuntu.com/questions/190535/is-it-possible-to-use-nautilus-actions-with-nemo-file-manager
https://askubuntu.com/questions/419532/nemo-custom-action-sh-script-does-not-execute
Also, since i guess you do have ~/.local/bin/ and is in the $PATH, why not add your script there and no need to provide /the/longest/path/to/execute/a/small/script
Not sure how your .sh is done, but if in terminal you have to specify the file to convert it, then you also have to do to your context menu (regardless that is a .desktop file or .nemo_action file) how to work on your right clicked file, otherwise will not do anything i guess.
