Hello Everyone,
Hope you all are well. I installed Manjaro XFCE 21.0.7 on my desktop 4 days ago. But yet, I couldn’t start Libreoffice 7.1.4-1 (Fresh). When I run libreoffice
command, I got this message:
/usr/lib/libreoffice/program/soffice.bin: error while loading shared libraries: libboost_locale.so.1.76.0: cannot open shared object file: No such file or directory
What should I try next?
$ inxi -Fxz
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Xfce 4.16.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: H310M S2H 2.0 v: x.x serial: <filter>
UEFI-[Legacy]: American Megatrends v: F11 date: 03/08/2019
Info: Quad Core model: Intel Core i3-8100 bits: 64 type: MCP
arch: Kaby Lake note: check rev: B cache: L2: 6 MiB
bogomips: 28808
Speed: 800 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800
Device-1: Intel 8th Gen Core Processor Gaussian Mixture Model
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Cubeternet GL-UPC822 UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:2
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.4
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.18 running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
vendor: Gigabyte driver: r8168 v: 8.048.03-NAPI port: e000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 111.79 GiB used: 49.17 GiB (44.0%)
ID-1: /dev/sda vendor: GALAX model: GAMER L TA1D0120A size: 111.79 GiB
ID-1: / size: 109.51 GiB used: 49.17 GiB (44.9%) fs: ext4 dev: /dev/sda4
System Temperatures: cpu: 27.8 C mobo: 16.8 C
Processes: 211 Uptime: 1h 35m Memory: 7.65 GiB used: 2.24 GiB (29.3%)
Init: systemd Compilers: gcc: 11.1.0 Packages: 1238 Shell: Bash v: 5.1.8
inxi: 3.3.04
